I want to know which HID kit brand is best for bikes and what color temperature is well suited for bikes for e.g (4300K, 6000k, 7500K, 8000k, 10000k, 12000k). Also tell me its price and where to buy in Karachi. Thanks
I am selling germany USED H.i.D with very powerfull range if intrested then sms me on 03232889737
Post the pics and specs pls
Sent from my GT-S5830 using Tapatalk 2
check this https://www.pakwheels.com/forums/bikes-3-wheelers/194618-cg-125-leds-meter-3
PURE white is the brighest among all.. and in bikes is twice as bright as a cars hid.i have SLIM ballast hid kit for bikes . brand new (rs 1500) or text only 03452069057
In Super Power 125cc Bike headlight reflector is made of Plastic, Do I need to replace it with metal for HID or it is necessary to replace it ? I have heard some people says that due to intense heat Of HID bulb it melts the reflector, Is it true?
yes its true .. though it may not melt it but it will surely fade the reflectivness of the plastic reflector.. use metal one..
What are the battery requirements for HID. I have installed 4.5 Ampere dry battery in my super power125. Is this enough for HID ?
^^ what is the wattage of hid ? how many watts ?i will assume t to be 35 watts ..with 12volts battery that meands it is drawing 2.5 amps or lag baag current .. so it means that a 4.5 AH battery should last approx 1.5 hours idealy .. if battery is fully charged ... its a bit difficult scenaro .. so i shoul recomend 6-7 AH battery.. 4.5 wont last long and it may be over discharged which will qquickly damage battery ..
The problem I'm facing that the space for battery in my bike is too congested and the battery of that size is available in 5 AH max, I have the 7 AH battery but its size is big and wont be fit in my current bike. I'm very confused what I do.
a big zalzala is happening here.. Allah khair karayu will have to do some juggar.. ppl do it .. else its not poissivble .. tor por karni paray gi
Allah sab ko apnay Hifzo ammaan mein rakhay. Well ok now I know what I should do, when there is not a clean alternate way. Thanks for your precious opinion and guidelines asjdsm.
jab tak chalthi ha chalavo.. laikin behtha yahi ha ka bari battery laga lo..mechanic juggar karaka battery box ko kat koot ka jaga bana laitha hain bari battery ka lia.. is ka ilava koi chara nahi..
salam bro@cyberjunk14 mein ne new honda Cg125 lea hy to mein apni bike me HID lagwana chata hu to kis range tk thek rhe ge bike ki HID and kea krna ho ga full lights be change krna ho ge or heat hone pe kea is ke leye new fram use krna pare ga kea or is ke priice kea hain HID and 125 ke leye kon se HID ache rhe ge thanks
First of all whatta DIG?
Secondly. Yes you can install HID on your bike, it will cost somewhere near 1300rs (Slim Blaster). But you need to install a 12v dry cell battery and front headlamp with metallic and glass finish..
Do visit this thread, it will clear all your doubtshttps://www.pakwheels.com/forums/bikes-3-wheelers/166142-hid-cg-125-some-other-changes
thebaldgeek | electronic mods – ’82 is k bare main kiya khayal hai?
