Results 1 to 10 of 10
Like Tree16Likes
  • 4 Post By Silver_Knife
  • 4 Post By asjdsm
  • 4 Post By talhabinomar
  • 1 Post By v8
  • 1 Post By Xulfiqar
  • 2 Post By RX115
Thread: CG 125 Rear Disk Brakes ?
    zuhaibonline's Avatar
    Oct 2006
    33
    9
    Lightbulb CG 125 Rear Disk Brakes ?
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Quote Originally Posted by zuhaibonline View Post
    Assalam-o-Alaikum!
    Can I install Disk Brake system on CG-125 Rear Wheel?
    Plz guide me with ur professional experience!
    Thanx!
    Yes you can install.. But you have to find the Rim of acquired size which will support disc brake system. The cost of the improvement will be around 10 to 15K. There are some of experts here which are offering there services for such modifications. You can approach them for more appropriate guidance
    Oct 2006
    33
    9
    Thanks, can u guide me how much braking will improve? and how much will be the cost of replacing brake pads of disk brakes? like we replace brake shoe in drum brakes. and if we compare disk brake with drum brakes, how often do i've to replace brake pads?
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    your choice of disk brakes on rear is very rare choice.
    front brake needs to povide more braking power then rear .. front brke must provide 60-70% of breaking power normally.. so u will obviously be going against norms.. and may be dangrous..
    u may ask about disk braks on front wheel..
    remember motorcycle is not like cycle in breaking..
    talhabinomar's Avatar
    May 2011
    26
    2,469
    38 Post(s)
    If you install the disk brake on rear wheel then the chances of skidding increases because it is more powerful then drum brakes and in the case of emergency brake you may apply it and the bike will skid and you can not handle it. Better to put it on the Front wheel for better performance. Putting any thing else other then factory fitted will decrease your bike's performance. It is my opinion any member have right to disagree with me.
    v8
    v8 is offline
    v8's Avatar
    Mar 2009
    Dubai
    34
    4,720
    12 Post(s)
    4 Thread(s)
    It won't be safe to do that. Put that in front wheel, but 125 stock front-brake is already good enough. (At-least it was good for 90s models when I used to have ride on my friends 125s)
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Useless... Braking power comes from tires completely, not brakes for these small bikes.
    Invest on good tires, maintain 32Psi rear tire air pressure, as stated on each tire do not exceed 35Psi level.
    I keep 30-33Psi
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3987 Post(s)
    94 Thread(s)
    6
    when I was riding in Karachi nearly all motorcycle users had dead front brakes, and some of them told horror stories of front disc brakes locking up, HOW STUPID does one need to be to lock up a front disc brake on a motorcycle, I have been riding for ages and in Pakistan both my front and rear brakes on my little motorcycle (yam rx115) wore out at the same time. (more than a year at minimum)
    Site Banned Follow
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Braking will improve alot. But as said by other members especially asjdsm that there are alot of chances of tyre being skipped. I suggest you to modify front brake as disc. And you will enjoy the good braking. Plus the mechanism of front tyre is far more simply then rear one. So less mechanical issues. Junaidakhtar01 is the guy who's been doing this.. May be he can help you out.
    PakWheels Forums - View Profile: junaidakhtar01
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    cg,s suspension is not suitable for disk brake,s coz u know suspension plays 50% role in braking, disk brakes would require soft suspensions rather cg,s engine braking is enough for good braking, plz stick to stock brakes....
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
Tags for this Thread
