Results 1 to 5 of 5
Thread: Suzuki GS 150 Tappet Settings
    Haji_John's Avatar
    Dec 2011
    Rawalpindi
    88
    2 Post(s)
    Default Suzuki GS 150 Tappet Settings
    Hi guys i have adjusted the valves of my gs 150 by myself yesterday but after i started the bike a strange clicking sound started coming from the tappets.
    Here are my settings for both valves:
    INTAKE 0.05mm
    EXHAUST 0.13mm
    These settings were for the first try.On my 2nd try i lowered the exhaust valve to 0.05mm but still the clicking sound did not stop.
    And yes i always brought my piston to the top dead center before performing both tries.
    The settings written on the maintainance chart in the suzuki service centre were 0.04 to 0.07mm for intake and 0.13 to 0.18mm for exhaust
    Pls help out guys?
    Similar Threads:
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    first are u damn sure u did settings at tdc of compression stroke ?
    and are have u used correct sized feeler guage ?
    try setting both at min values ...
    Haji_John's Avatar
    Dec 2011
    Rawalpindi
    88
    2 Post(s)
    Yeah i am damn sure that i did these settings at top dead centre and not on the bottom dead centre ( aligned the T with the mark )and yes the correct feeler guages were used.
    what are the correct settings for both intake and exhaust
    Haji_John's Avatar
    Dec 2011
    Rawalpindi
    88
    2 Post(s)
    So ok if i was not at the compression stroke then what should i do to be at compression stoke and not at the bottom
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    there are two top dead centers.. one is compression one is suction,,,
    u should be at top dead center of compression not suction..
    to make it sure that you are at tdc of compression stroke.. when u move the flywheel it will become hard to rotate it as it will be making coimpression.. try moving with hand to feel it.. with long socket etc u cant feel the force needed..
