Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By khanmomar
Thread: GS 150 electric problem
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Default GS 150 electric problem
    Hi guys today when i was returning from work the headlight of my bike went dim, the horn stopped working and then at signal the bike turned off. the self start did not work either.
    And then sfter i got home the headlights statrted working at idle rpms but when i increase rpms everything goes off again
    Pls help guys.
    My friend says that the battery needs charging but i am sure that gs150 has a generator
    So whats the problem?
    khanmomar's Avatar
    Aug 2008
    57
    527
    3 Post(s)
    2 Thread(s)
    GS150 comes with a very low quality main fuse located under the seat. Change it and everything should be fine and please dont take it to ordinary electricians, they'll mess up things. either do it yourself or take it to a suzuki certified electrician.
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    yes first check fuses.. and ground faults.. by checking if no wire is bare wire is touching other wire or body... or wire is not chewed in some fitting./.
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Thankyou very much ill check the fuses and also the wires
