Results 1 to 4 of 4
Thread: Super Power SP-70 vibration need advice
    sunnyimran's Avatar
    Jul 2012
    28
    Default Super Power SP-70 vibration need advice
    assalam o alaikum,
    I have super power 78CC SP-70 bike. 2010 model. problem are:
    1- Handle is vibrating on speed 40 and above. right hand grip feels more vibration. due to vibration my hand is not active and difficult to control accelerator ( as riding in winter your hand freezes)
    2- how to adjust carburator for maximum mileage. when slowing down accelerator from 4th gear silencer shouts like misfire. ( silencer is not original super power. it is a modified one)
    3- spark plug is little brown in center while blackish on outer circle.
    4- battery ( when charge from dc-adaptor outside ) is charging , when in bike not charging. I have removed battery from bike, checked voltage on wires coming from charger it shows 12v dc approx and also bulb is lighting when connected to them
    please suggest the solutions
    thanks
    umerchaudhary's Avatar
    Apr 2007
    32
    1,202
    4 Post(s)
    2 Thread(s)
    For max mileage I would suggest you if you don't know don't touch mixture and set it from good mechanic it's place is right side on carburetor just 1 inch left from race setting screw
    sunnyimran's Avatar
    Jul 2012
    28
    thnx for the reply
    I know carbs very well and I have been maintaining two stroke engine bikes. but four stroke tuning carburator I do'nt know very well. so please guide some steps and I will try to follow
    any comments for other mentioned problems in my first post ?
    thanks
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    carb ko open kro jahan se race ki tar jati ha wo system bahar nikalo , take out needle , set needle clip to top most , than rest the ideal . that will reduce fuel consumption.
