han carb pe likha hy "dkni standard of japan pz22" .
aj main ik mazay ki bat bata hon jo maine notice ki. blkay 2 mazai ki batain.
1-once i took carbs measurements inside diameter with an ordinary transparent scale.(mean 2say not that much accurate but can still use these measurements).
carb from air box side is 2.8cm and from other side 2.1 or 2.2cm main foild is also 2.1cm-2.2cm , intake head is same, carb from air box side is 2.8cm and from other side 2.1 or 2.2cm main foild is also 2.1cm-2.2cm , intake head is same, but the "hadi" (a local word) is 2.0mm which should be 2.1cm or 2.2cm.ut the "hadi" (a local word) is 2.0mm which should be 2.1cm or 2.2cm.
2-i had two main jets labeled 85 but in pakistan never trust labels (pep pep pep pepepep)
the one im using now is wider than the other cant find above then that . needle is in the middle which best , if lower the needle than bad very bad , if raise the needle no torque.
