Results 1 to 7 of 7
Thread: >>> Tappet noise in Deluxe
    pico's Avatar
    Jul 2007
    Rawalpindi
    28
    1,024
    3 Post(s)
    Default >>> Tappet noise in Deluxe
    AOA,
    I have a deluxe 2012, 1400km driven, the problem is that the tappet noise is more than normal, i got it adjusted two times, once from honda antenna dealer and the next time from a local honda mechanic, but the noise still exist.....
    the mechanics ofcourse say that this is genuine noise but after owning three 125s i do know what the normal noise level should be.
    when i went to the local mechanic initially he said that yes there is tappet noise but after adjusting the tapets when the noise remained he said that this is genuine noise.
    So What else could be the reason of the tappet noise apart from tapet adjustment???
    Thanks.
    ALWAYS TRY EVERYTHING IN YOUR LIFE , BUT NEVER BECOME THE SLAVE OF ANYTHING.
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    what honda center you had been?
    legend will revive soon
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Quote Originally Posted by pico View Post
    AOA,
    Thanks.
    Depends on the life of the engine.. If engine is new then probably the noise is from tappets.. Ask them to adjust it by guage..
    pico's Avatar
    Jul 2007
    Rawalpindi
    28
    1,024
    3 Post(s)
    Quote Originally Posted by hidalgo View Post
    honda antenna shop near chandni chowk
    pico's Avatar
    Jul 2007
    Rawalpindi
    28
    1,024
    3 Post(s)
    currently im using zic4t, isnt it better than caltex???
    adjustment was done using feeler guage.
    pico's Avatar
    Jul 2007
    Rawalpindi
    28
    1,024
    3 Post(s)
    currently im using zic4t, isnt it better than catex???
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    try using good engine oil.. 20w50 caltex..and did they adjusted it with bare hands ? and most importantly did they verified that the setting is correct by checking with feeler giuage..
