Results 1 to 6 of 6
Like Tree4Likes
  • 4 Post By imranbhatti
Thread: interrogation.... 15w40 oil instead of 20w50 oil
    afatifa's Avatar
    Apr 2009
    28
    829
    Default interrogation.... 15w40 oil instead of 20w50 oil
    salam to all pakwheelers,,,
    currently i m using castrol gtx 20w50 ( cost 410rs) oil for my honda 125 1991......m getting a 4 lt rimula 15w40 from a frnd for free. is it ok if i use this oil for my bike,,,,my bike engine got overhauled ( pura engine bana tha ) 7 months before.
    please do response me thank you all
    Regards:
    Shaikh Atif
    Angeldust's Avatar
    Jan 2012
    Tirana
    41
    148
    No problem for 15-40,good move for the incoming winter.
    talhabinomar's Avatar
    May 2011
    26
    2,469
    38 Post(s)
    It as good as 20W. But it is little thinner in Viscosity.
    afatifa's Avatar
    Apr 2009
    28
    829
    thank you guys.... but will that thinner think ask my engine to make more noooise??? like those khachar pachar sounds..
    May 2011
    26
    2,469
    38 Post(s)
    No. It will not make any Noise. Trust the oil and pour it.
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Quote Originally Posted by afatifa View Post
    20W-50 Oils definately suppresess engine noises. Regardes of the performance, if u would switch to any 10W-40,15W-40 or 20W-40 Oil u will found it bit noisy for ur bike.One more thing i wud like add is Rimula is designed to be used is Diesel engines which have diffrent X tics (Though these multi grade oils also meets some of the standrds of spark ignited engines) but i it can harm the wet clutch system in motorbikes so i will say NO to use of Rimula in Motor bike engine.
    Exploring Machines is my Passion...
