Page 37 of 91 FirstFirst ... 2735363738394787 ... LastLast
Results 721 to 740 of 1806
Like Tree1841Likes
Thread: Bike Care and Detailing
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Dream is not that which you see while sleeping it is something that does not let you sleep.
  2. #721
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by r1 View Post
    Few days ago temp was -14 but now its normal in between -2 or -4. Which oil should i go?
    Well bhai 10w50 is the dream oil unfortunately i was not able to find it anywhere ..This viscosity rating is only available in fully synthetic blends
    But if temp is near 0 then 20w50 would do...Because pour point of 20w50 is nearly -28 degrees centigrade for LM..As a rule of thumb Pour point should be atleast 10 degrees lower than the lowest temperature your ride encounters in climate..
    so 20w50 will be fine till -15 degrees C
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  3. #722
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Asad at that i was using Motul 10w-40
    bike care and detailing -1104995
    Where did you get MOTUL :O
  4. #723
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Quote Originally Posted by devilskreed View Post
    From Chaman Pak/Afghan Border area
  5. #724
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Nice..What we cant get in isb it is readily available in chaman ..Nice
  6. #725
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    How can we remove reflective tape from paint areas and suspensions covers?
  7. #726
    getscorpion's Avatar
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    once a removed a huge piece of reflective tape successfully from side cover ... i used a blade to remove it .. there was much sticky residue left which was easily cleaned with petrol ...
    Rise from the ashes,.....
  8. #727
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Why do you want to remove them?
    Sent from my HTC One V using Tapatalk 2
  9. #728
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Kerosene Oil Works Very Good For Removing Tape Residue
  10. #729
    ahmad_yar's Avatar
    Apr 2009
    45
    6,809
    27
    735 Post(s)
    24 Thread(s)
    try to use cleaner waxes to remove sticker /tape residue as said oils are bit stronger on paint for this purpose
    www.facebook.com/AhmadYarsAutoSpa
  11. #730
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    I have purchased this amorall wash and wax shampoo from hyperstar...
    Expecting it better than FORMULA 1. I'll share experience using it as soon as wash my bike
  12. #731
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by ha125 View Post
    Man you live in a detailing eden..!!!!!!!!!!!!!!!!!!!Lahore!!!!!!!!!!!!!!!!!!! !!
  13. #732
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
  14. #733
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    Sir it is Dust Eden these days... dont worry ... you clean ur ride and go to even "Nukur wali pan shop" in your own town and bike starts looking like a dust Monkey...
  15. #734
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Hamza: Good going
  16. #735
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Am back in town today bike need detailing will do tomorrow or day after.
  17. #736
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Hamza: Good going
    Pleasure
  18. #737
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by vickytulla View Post
    Well compliment was w.r.t availability of detailing products and markets..like saca plus and stuff ,,otherwise pindi bi peechany nai bike ka bera gharak karnay main
  19. #738
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Thank GOD ma yehi samjha tha
  20. #739
    abuzerkhan's Avatar
    Sep 2008
    32
    342
    15 Post(s)
    very true yaar dhoop kab niklay gi.i have to wash my bike.its damn dirty now.
  21. #740
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Quote Originally Posted by abuzerkhan View Post
    Hun te meri v ho gai ae
    Naal e ma nawa shampoo v leiya waan ...
    Liken temperature 2?c SE kam hue to phir na
