Page 75 of 91 FirstFirst ... 2565737475767785 ... LastLast
Results 1,481 to 1,500 of 1806
Like Tree1841Likes
Thread: Bike Care and Detailing
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Dream is not that which you see while sleeping it is something that does not let you sleep.
  2. #1481
    mianaasim's Avatar
    Nov 2013
    264
    2 Post(s)
    @ahsan95 @sheikhmunda97 .
    Polish is recommended only in case of very bad condition/appearance of original paint or bi-annually. But if paint condition is good then plz don't use polish too often. Just wash with auto shampoo and wax it. Keep in mind wax must be of good quality (not formula1 nor cosmic).
    The reason is that polish a bit abrasive material and it will definitely peel some part of paint as the bikes are painted using one step system. The new cars are painted using two step system. Step 1 = Paint Step2 = Clear Coat. If the polish is used on a 2 step paint it will peel off some portion of clear coat and too regular use will peel off whole layer of clear coat.
    BUT
    Bikes are wearing only 1 step paint. Too regular use will only end up in removal of paint nothing else. It will then be more vulnerable to scratches.
    I think you are under impression that wax is only a protective layer, NO. WAX does not only protects the surface but gives depth and shine too. Having said all this, if u still want to use polish then u must have to use a quality sealent after polish and before wax.
  3. #1482
    kami717273's Avatar
    Jan 2014
    108
    3 Post(s)
    Quote Originally Posted by mianaasim View Post
    BUT
    Brother agar cosmic or formula1 wax use na karay to kon si wax use karay aap batao
  4. #1483
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Quote Originally Posted by kami717273 View Post
    Turtle wax.
    Sent from my Desire HD using Tapatalk 2
    4 wheels move the body 2 wheels move the soul
  5. #1484
    mianaasim's Avatar
    Nov 2013
    264
    2 Post(s)
    At Minimum : Turtle Wax.
  6. #1485
    sheikhmunda97's Avatar
    Nov 2011
    Kasur
    1,684
    8 Post(s)
    BUT
    Thank u very much sir
    And plz tell me about compond polish
    ALONE
    BUT HAPPY
  7. #1486
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Quote Originally Posted by sheikhmunda97 View Post
    Compund polish will also cut the paint. Just like in cars it removes thin layer of clear coat.
    Don't go for compound if you can bring out the required shine and depth by hands. But compound can remove the scratches introduced on the paint. Compound requires professional hands so proceed with caution if you are a newbie.
  8. #1487
    Nov 2011
    Kasur
    1,684
    8 Post(s)
    Quote Originally Posted by ahsan95 View Post
    Thanks bro
    ALONE
    BUT HAPPY
  9. #1488
    kami717273's Avatar
    Jan 2014
    108
    3 Post(s)
    Thanks bro
    Yar wd40 kis liya hoti ha.
  10. #1489
    Nov 2011
    Kasur
    1,684
    8 Post(s)
    It is used for loosens rusted parts,clean out moisture,clean the carbon on different parts of bikes and cars
    I normally use it on bike chain cover(iner part) car suspension shocks etc
    ALONE
    BUT HAPPY
  11. #1490
    wasifwaheed's Avatar
    Jun 2009
    32
    63
    a.o.a broters its time to wake-up , with new brand K2, you must try it 1st , as peoples are asking for chrome polish
    pls see the ink K2 ALUCHROM - Car Care
    its easily available in market, I also try this brand colour max and compound on my bike 07 model Honda 125.
  12. #1491
    Jun 2009
    32
    63
    Default honda 125 (2007) tanki polised by k2 colour max (black) .
    a.o.a
    I also wants a permission from the founder of this tread.
    brothers its 100% results , its like a mirror
    pls see the results. swirls removed successfully !
    and waxed.
  13. #1492
    Nov 2011
    Kasur
    1,684
    8 Post(s)
    Good work:thumbup:
    Plz share the price of these products and where u get it??
    ALONE
    BUT HAPPY
  14. #1493
    Jun 2009
    32
    63
    Good work:thumbup:
    brother I bought it from Montgomery road, Lahore. all products are in economical range.
  15. #1494
    usamanaeem's Avatar
    Jan 2013
    good result i also have a honda 125 2008 model.please share the steps to follow now i am using turtle wax but your result is owsum.
  16. #1495
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    After weekend wash n care... my bike's 4th year!
    Installed both new tires, installed 2.75-18 rim and tire on the rear. Somo rim costed me 680Rs, 270Rs for atlas honda cg125's front tire's spokes... these spokes turned out to be the perfect match for this rim. unfortunately could not find service cruiser in 2.75 size thats why the design is simple, but i am happy!
  17. #1496
    Jun 2009
    32
    63
    Good work:thumbup:
    brother thanks for your apriciation ! i will show you some more pictures
    thanks
  18. #1497
    Jun 2009
    32
    63
    thanks dear for great words , i use the following steps and wants to share with you.
    1- just take a look of current condition of paint (like how many old is ? and check the swirls on surface
    2- if swirls exist then use compound, but pls remember it should be safe cutter, which i found from k2 carso as shown in picture.
    3- smoothly rub on surface with the halp of some water.
    4-then wash with k2 express plus shampoo.
    5- then dry it
    6-and take a microfiber for polish
    7-and use k2 colour max in black colour.
    8-then you will found the results.
    thanks i m not a professional but i have a know how abt the automobile. if need any more help then also ask me, may b i can help you.
    thanks
  19. #1498
    kami717273's Avatar
    Jan 2014
    108
    3 Post(s)
    Yesterday i bought these.
    Black spray paint=150
    7cf=150
    cosmic wax=350
    wd40=280
    luster=10
  20. #1499
    Jun 2009
    32
    63
    Its also a good collection but regular brands not a special. With carring average results.
    Sent from my LG-P999 using PW Forums mobile app
  21. #1500
    Jun 2009
    32
    63
    Bhai new bike p to jo b polish lga do gy woh shine kry ge. Bus paint k liye safe hni chaheye.and long lasting b.aur protective from uv rays.
