Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By asjdsm
  • 1 Post By Maggi
Thread: Question for SP-70...
    Predator1983's Avatar
    Mar 2012
    52
    Default Question for SP-70...
    hi guys, i recently bought a SuperPower 70 2010 model in black as slight used from a friend of mine. When i got it tuned first time the bike began "missing" upon achieving higher speeds. Bike use to run fine if i keep it near 40 or 50 km/hr. but when i throttle it to go faster it begins missing like the bike behave when it running out of fuel.
    i went to mechenic to get it checked. he checked everything then he removed the seat, n checked the Air filter housing (some mechenic call it LOTA) the end point of that housing was too narrow. so he wider it with help of blade n cutoff extra rubber. then he again tested the bike, but nothing changed. then he again tuned the bike but still their was no change. after that he again put a wire on end of air housing and made it narrow again. or in other words decreased the air intake.
    then the bike somewhat get better. but the problem is still there. i some time feel that bike is missing when i use to accelerate alot on 3rd gear or 4th gear. i also have noticed that there are petrol stains on carberator. most of the time i use to have smell of petrol. is there anything wrong with carberator ? or is there anything else thats causing the missing issue. should i put a CG-125 carb in my SP70 ? as i have new carb lying around.
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    i was facing the same problem an year before then i changed the carb to 125, alter spockets and now everything is perfect.
    Team DEKA
    Mar 2012
    52
    Quote Originally Posted by Maggi View Post
    u mean to say i should get 125 Carb fitted ? also have u installed any Air Filter with 125 carb ?
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    your problem is in carb .. mostly there is some leak b/w the path from carb to head .. also thoroguhly clean all the jets .. and screws ..
    and make sure ur float level is ok .. i suspet ur float level is out of order ...
    125 ka carb normal 70 pa shayad e fit ho...
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    Quote Originally Posted by Predator1983 View Post
    Not at all
    Team DEKA
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    125 ka fit nai hoga..Agar ho bhi jayay thuka thuki kar kay to economy ki waat laga day ga
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    Quote Originally Posted by devilskreed View Post
    https://www.pakwheels.com/forums/bik...ittle-upgrades bhai maze se lagta hay koi problem hi nahi hay
    Team DEKA
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    best possible steroid for 70 cc . 125 carb
    legend will revive soon
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Fuel consumption to barh gai ho gi jnap..Thus my point is still valid..Btw nice rocket you made
    Juste's Avatar
    Aug 2011
    1,982
    23 Post(s)
    I guess there is also something wrong with carb.
    31.5497 N, 74.3436 E
