Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By vickytulla
Thread: Which company aftermarket carb for cg is best ? any experience ?
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    Default Which company aftermarket carb for cg is best ? any experience ?
    hii
    as the title says it all .. kis company ka cg 125 ka carb best ha .? any positive/negative experience ..
    as far as 70 is concerned then CRLF is the worst ever aftermarket carb for 70 . its float is made of tin and will quickly get zang .. and its float lever is made of equally poor metal strip ... only a surgeon could handle it without disturbing it .. itni buri quality ha uski ..
    i expect to use it on altered chonda .. which is currenlty 104cc but will bump it to 110cc .. after new piston swap ..
    so want a good carb for that .
    thanks
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    What about Cab of Cd 100 ?
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    i have it (janyan cd100 carb) .. and i slapped it onto stock dhoom 70 and it was awesome response .. pick and speed was definitely improved ..sans air filter .. and its now lying .. i will try it on my alter version ... but i want a cg type carb ..
    the reason i am hesitant to use cd 100 carb is that it will cause cold startup issues as outlined by other cd100 userss .. and i cant find its jets .. if i get its jet of 40 number then i will surely slap it on my bike and see .. but since all altered bikes has cg and its very tunable as we have a lot of jet variations available thats the reason i want to give it a try..
    Quote Originally Posted by talhabinomar View Post
    dared3vil19's Avatar
    Nov 2012
    73
    Quote Originally Posted by asjdsm View Post
    what was the effect on millage after installing cd-100 carb?
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    ii only used that for 10-20 km .. and removed that .. as filter lag nai raha tha .. carb ki filter side bhoth motti ha 70 ki nisbat .. so i removed it as i do not like filterless ride .. i also checked 70 carb without filter . but it was no difference with filtered or unfiltered..
    Quote Originally Posted by dared3vil19 View Post
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    hmmmmmm
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    i have same carb used in chinqi rwksha .. but it came stock hero70
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    i have it (janyan cd100 carb) .. and i slapped it onto ......
    the reason i am hesitant to use cd 100 carb is that it will cause cold startup issues as outlined by other cd100 userss .. and i cant find its jets .. ..give it a try..
    But now not to worry brother, You may get the carb of Pridor which has no such issue. Now the CD-100 owners are changing thei carbs with the new one of Pridor.
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    had used chinese carb in CG works with smile and gives same milage and throttle response with 1/4 of the price...
