Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By devilskreed
  • 1 Post By makniazi
Thread: Help regarding cd70
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Question Help regarding cd70
    AOA all i have a honda cd70 1999 it has 1 lakh and 12 thousand km on it was bought 10 years back by my father engine never opened pick of the bike is awesome till now and it is giving 40-45 km/lit which i think is good enough for 13 years old bike now the problem is that it is giving trouble in cold starts and in the morning the clutch wont work for the fist 1-2 min after the bike starts and there is also a ticking sound coming from the engine only 1-2 min after starting the bike after half hour or more
    thanks
    regards
    All you need in this life is ignorance and confidence, and then success is sure.
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Bump....
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    what happens when u rev it hard and abruptly standing idle?
    Does it gives any smoke from the silencer?
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    no smoke it was giving a bad average 35-38 km/l today i changed its jets main 72 pilot 35 will check the mileage tomorrow
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    cold start problem is common in all bikes. use choke in morning. ticking sound while cold start also seems normal. to avoid jerks in morning tight the clutch screw little bit.
    mileage can be improved by tuning.
    (Always use Honda Genuine Oil )
    The best car safety device is a rear-view mirror with a cop in it.
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by waqar19 View Post
    And why is that?
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    @waqar19 i feel zipex is much better than honda oil and using zipex oil
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by makniazi View Post
    thanks
    regards
    Plz elaborate and describe clearly...
    I think you have connecting rod making noise that is why ur bike makes ticking sound...
    + it can also indicate a very loose piston.
    U might need an overhaul later, bdw what is meant by clutch does not work?
    Sent from my Nexus S using Tapatalk 2
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Quote Originally Posted by Automotorsport_Lover View Post
    its like loose clutch cable.
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    @Automotorsport_Lover its like when i start the bike in the morning and activate the clutch and put the bike into gear the bike starts moving (clutch activated) and also doesn't go back to neutral and have to keep the bike start for 1-2 min and then it starts working and works fine the whole day
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Yea happens, dont worry...
    just maintain more throttle when she does that. thanks to our decades old tec!
