Results 1 to 15 of 15
Like Tree7Likes
  • 1 Post By getscorpion
  • 1 Post By sjehsan
  • 1 Post By r1
  • 1 Post By aximaxim
Thread: Help needed i'm tense about this rust!
    FM3o5's Avatar
    Jul 2012
    24
    216
    2 Post(s)
    Question Help needed i'm tense about this rust!
    AoA all
    Hope you are doing great, i m tense about this rust which u can see in the images below, i like to keep my bike neat and clean, i wash it twice a month or sometimes thrice a month. how to prevent from this rust? what should i do?
    thanks in advance.
    Help needed im tense about this rust! -1108522Help needed im tense about this rust! -1108523Help needed im tense about this rust! -1108528Help needed im tense about this rust! -1108534Help needed im tense about this rust! -1108540Help needed im tense about this rust! -1108543
    <FM>
    getscorpion's Avatar
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    nothing serious ... use WD40 on these areas to keep them away from further rust formation..
    Rise from the ashes,.....
    sjehsan's Avatar
    Mar 2009
    28
    3,086
    47 Post(s)
    3 Thread(s)
    WD40 is the best option!
    Sent from my own Desktop Computer using my own Keyboard !!!
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Give a coat of WD40 every week and forget everything..
    Dream is not that which you see while sleeping it is something that does not let you sleep.
    FM3o5's Avatar
    Jul 2012
    24
    216
    2 Post(s)
    Thanks all. :-)
    <FM>
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by FM3o5 View Post
    Thanks all. :-)
    Actually WD-40 will ruin the black paint on your Engine Block......WD40 has the tendency to eat up paint.
    Use WD40 everywhere else....... except on the engine.
    I'm afraid the only way to stop the block from the surface rust you have repaint the block with heat resistant paint. The aftermarket heat resistant paint is tougher than what it had originally. I think its cheap fix.....
    Bikes don't leak oil, they mark their territory.
    FM3o5's Avatar
    Jul 2012
    24
    216
    2 Post(s)
    Quote Originally Posted by aximaxim View Post
    thanks but someone told me if you paint your engine its value gets down? is it true?
    <FM>
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    Actually WD-40 will ruin the black paint on your Engine Block......WD40 has the tendency to eat up paint. Use WD40 everywhere else....... except on the engine. I'm afraid the only way to stop the block from the surface rust you have repaint the block with heat resistant paint. The aftermarket heat resistant paint is tougher than what it had originally. I think its cheap fix.....
    bro do u hv any idea where can i get high temp. paint spray cane here in khi .. i checked big paint shops and they hvn't got it ..
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    I think as long as your engine is sealed....... its ok to paint the block. Painting will not decrease the Resale value. Everyone knows now that newer bikers tend to rust at the engine block. No big deal.
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by getscorpion View Post
    These high temp paints come in both Aerosol Spray Paint cans and also in traditional tin packs. My brother painted his Chondas Engine block with a paint brush. It was satisfactory finish. It could have been better but he was too lazy to prep the area before painting and he applied a little too thick coat. Just dont make the same mistake.
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    yes but i failed to find spray can of high temp. paint here .... i hv plans to do the exhaust ....
  12. #12
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Try Tibet center......there are few very good old paint shops behind Tibet Center. I'm sure they will have wht you need....Matt Black high temp paint.
  13. #13
    FM3o5's Avatar
    Jul 2012
    24
    216
    2 Post(s)
    Thanks i'm looking to do something like this
    Help needed im tense about this rust! -1110009
    <FM>
  14. #14
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Good Choice! Great Color combo!
    Actually you can also achieve the "Black" in the above picture by Powder Coating. I'am pretty sure the person who did the paint job above must have taken the engine apart. So if you ready to lose your engine's virginity, take it apart for good results.
  15. #15
    FM3o5's Avatar
    Jul 2012
    24
    216
    2 Post(s)
    ADMIN Delete this thread.
    <FM>
