Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree10Likes
Thread: CG 125 Point carb req
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    Default CG 125 Point carb req
    AOA
    hey guys... does anyone know from where cg125 point carb can be bought ? new
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by voodoo View Post
    AOA
    Its available almost everywhere, you can find them very easily at markets like, water pump, Ghareebabad market, Akbar road market , Market Behind Dilpasand (MA Jinnah Road), etc etc.
    Buy from the nearest market as the price difference wont be that much. Beware of copies, and when I say beware I dont mean Chinese copies are bad......... they are not bad at all but shopkeepers sometimes sell you Chinese copies at AHL prices.
    Genuine AHL carb will set you back atleast 3,500 rupees (not sure of the exact price) whereas good Chinese copy cost a little over Rs.1,000.
    Bikes don't leak oil, they mark their territory.
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    ah ok.... actually there where a lot of CDI model carbs available but i couldn't seem to find the old POINT model one.
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Why do you wants the older Point Carb? How different is it from CDI carb? I dont think its that different.
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    there are two type of carb ever came with CG to pakistan, the old one with slim "salyeee and bore" and shorter float bowl.. then they upgraded it to a new carb with a bigger salyee, bore and floating bowl plus some changes in jets as well....
    Both carbs came in CDI version where as point CGs used to have smaller older carb only uptill 91. the bigger bore carb performs better.
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by vickytulla View Post
    Which Carb is this? I know its CG-125 carb, but which one? Can you tell the difference from the exterior?
    CG 125 Point carb req -1112955CG 125 Point carb req -1112956
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    It looks like a big Bowl below its the Bigger Slayee Carb..
    Quote Originally Posted by aximaxim View Post
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @vicky is there any difference between venturi of both carbs?
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    Sir gee venturi ? kia hota hai ?
    you mean the Sliding throttle cylinder ? and the needle ?
    Quote Originally Posted by RX115 View Post
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    VENTURI
    A constricted throat in the air passage of a carburetor, causing a reduction in pressure that results in fuel vapor being drawn out of the carburetor bowl. Let the pictures speak for themselves:
    CG 125 Point carb req -1113150
    CG 125 Point carb req -1113151
    CG 125 Point carb req -1113152
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    hmmmm got it I dont know if there is any difference in venturi or not .. may be a mechnic of 125 can, i jyst noticed this difference and asked the mechnic and he told me that old models have slimmer carbs then with powerplus introduction the crab was revised and the new carb is little bigger smilar in shape but with bigger bowl and different jets e.t.c..
    VENTURI
  12. #12
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    agreed... but the point model does not perform well running on a cdi carb... hence am on a look out for the old 91 carb...
  13. #13
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    that will be the one with small bowl and slimmer bore and jets .... you will hae to visit old bikes market for that, here in lahore it can be traced at bilal ganj easily dont hae any idea about karachi.
  14. #14
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    as per my knowledge the old carb has bigger venturi and also the over all volume of the carb
  15. #15
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    ^ ur right... it is bigger....
  16. #16
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    I think the carbs will not be vastly different and CDI carb will work just fine on a point model.
  17. #17
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    bro if the venturi size is difference, then both will work differently
    bigger venturi will must leads towards better pick up n top, and this is the only main difference
  18. #18
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    bhai jan shyid ap sahi kehty hon but mene tu jo dekha wo bataya, If you place both carb side by side the older one is slimmer more rounded and gives an over all smaller look (just compare the magnet tappa of Old CG and new CG or just compare the Clucth tapap of poiinter CG with new CG (now I hope you will get my point that which one looks slimmer and smaller ) ...
    May be inside the venture is bigger but the new carb had more corners and bigger bowl I keenly noticed it while I was planning to put a 125 carb on a Pointer RoadMaster and had to decide which one would be used in that old thumper to have better fuel ecnomy.
    may be venturi is bigger but it is not bigger by out side if dono ko sath rekh k dekhye ga (not talking about venturei thing its an inside thing and I dont know about it frankly ) ... but bowl of new one is bigger or uper wala hisa almost same hai with few different curves..
  19. #19
    krgemini's Avatar
    Jul 2011
    762
    7 Post(s)
    in karachi, there is a old parts market near Ranchore Line Bazaar where you can find mostly all spares for older models 125
    Regards,
    Kashif Rafiq
  20. #20
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by kashifrafiq View Post
    Rachor line may china ka maal bhara howa hai ab. agar mil bhi gaya purana tow re-jet kerwana bhi par sakta hai, butterfly ka kaam bhi ho sakta hai and rebuilt kit lekar sari internal seals change kerni per sakti hain........I really dont think its worth it. Naya lelo bhai........CDI wala unit itna different nahi hosakta. Loog 125 ka carb.....cd-200 may lagwatay hain.....meri cd-175 may bhi CG-125 ka CDI wala carb laga aya tha........adjustment hojati carb ki as per the engine requirement.
