Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Automotorsport_Lover
Thread: Is this bolt for rpm cable installation?
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    Question Is this bolt for rpm cable installation?
    Is this bolt for rpm cable installation? Can I use 150 speedometer and its rpm cable?
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    not sure if its for rpm unless one opens it and thorughly inspect it .
    or at least ask some mechanic .
    btw what will be use of seeing the rpms ? just get an idea of the rpm from the throttle position .. and the max rpm of the bike..
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    @ asjdsm 1 question bro..How to set rpm on a bike without rpm meter..I want to set my bikes rpm at 1500 but i dont know how
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    mistri ko patha hotha ha ..
    they judge the idle rpm from sound .. and their experience
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by devilskreed View Post
    Theres a tecometer available for that.. it is installed with the plug wire and then the rpm is adjusted with the help of its readings..
    Is this bolt for rpm cable installation? -1123387
