Is this bolt for rpm cable installation? Can I use 150 speedometer and its rpm cable?
not sure if its for rpm unless one opens it and thorughly inspect it .
or at least ask some mechanic .
btw what will be use of seeing the rpms ? just get an idea of the rpm from the throttle position .. and the max rpm of the bike..
@ asjdsm 1 question bro..How to set rpm on a bike without rpm meter..I want to set my bikes rpm at 1500 but i dont know how
mistri ko patha hotha ha .. they judge the idle rpm from sound .. and their experience
Theres a tecometer available for that.. it is installed with the plug wire and then the rpm is adjusted with the help of its readings..
