Results 1 to 11 of 11
Like Tree10Likes
  • 1 Post By amjad635
  • 1 Post By Anyone
  • 3 Post By humayun990
  • 2 Post By devilskreed
  • 1 Post By asjdsm
  • 1 Post By devilskreed
  • 1 Post By Haji__John
Thread: Grease or oil on chain?
    Anyone's Avatar
    Mar 2012
    928
    5
    19 Post(s)
    Default Grease or oil on chain?
    AOA,
    WHich thing is best to apply on chain,grease or oil?my mechanic told me grease is best as compare to oil.so guys which is best according to your experince?and if i go for grease then for how many kilometers it is good to go?
    regards,
    Sada nai banya.......Chalo koi gul nai....mitti pao...its ok..!!
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Oil/ or special greases for chains.. i doubt they will be easy to find locally
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    try wd 40
    legend will revive soon
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Do not use grease its not good for chain. Use Engine Oil
    Anyone's Avatar
    Mar 2012
    928
    5
    19 Post(s)
    hidalgo bhai wd40 is a lubricant?mery khyal se to wo phly se mojod oil bhi saf kr dy ga.
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    ^^ you are correct.
    I guess hidalgo means to say it can help u clean the chain, remove moisture and then re-grease it with a chain grease(its in much liquid form, not normal local grease) or use freash oil.
    humayun990's Avatar
    Dec 2012
    Peshawar
    45
    107
    7 Post(s)
    Please Use any clean gear oil, if not available, use some engine oil but do not use grease, as it add more dust and sand in the chain and sprokets, resulting early damaging of both,, I have faced it already. Although WD40 is a unique item but this removes colours,paints and leave some shades on surfaces,
    So Oil is the best solution.
    1 lakh ki Motorcycle bana li par Chain cover teen wala cheap,,Agar chain covers k nuts ko ziyda tight kia tho slip,,oops,, One of my friend have A sport bike and its chain covers are Superb made from shiny Aluminium.
    Shame on our famous (so called) brands
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Bro use sae 90w140 transmission oil..It is thick and remains on the chain for longer intervals..WD-40 is not suited for bike chain lubrication(they themselves stated it)..Lube your chain once every 1000Kms..The problems with grease is that it does not displace dirt it accumulates it in b/w rollers and thus it gets messier and messier and later it is difficult to remove previous greased layers and apply new ones..Use gear oil
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    i thoroughly tested sinpopec lithium base grease the best after caltex grease in the market .. on chain ...
    i have to say its totall ****.. reasons as pointed above it will make convert into sludge/sakht ho jathi ha.. and jo normal chain kay particles chain sa urtha hain (zaray.. as a result of friction) wo iss grease me store ho jatha hain .. which acts as spraying sand in engnie oil and then applying that engine oil on chain ..
    so grease faxzolllllllllllll ha chain ka lia .. meray tajarbay ma .
    use engine oill. or transmission oil .. and tx oil is recomennded for chain by manual as well
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by humayun990 View Post
    Oay bhai sportbike pata hai kitnay ki hoti hai???Latest model bike 20 lakh ki hai 1000cc main aur 7 lakh say nichay koi bike nai milti 600 aur is say upar category main..Aap is bike ko sports bike say kyn compare kar rahay ho..STupid comparison..
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    I use PSO gear oil on my 70 and gs150 chain. Its been a year or abi tak woi 1L wali bottle nai khatam hui. I re-lubricate after 1000km and clean-lubricate it on 2000km. Gotta say it works like a charm.
    "Imagination is more important than knowledge"
