Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By talhabinomar
Thread: bike choke?
    MR.car's Avatar
    Apr 2010
    46
    53
    Default bike choke?
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Which bike are u talking about? specify
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Usually theres a small lever attached to the carburettor. If its a 70, then its a thin long metal lever. If its a 125 it has a small plastic lever. If its a Yamaha it has a choke lever attached to its handle.. below the horn button.
    MR.car's Avatar
    Apr 2010
    46
    53
    i have sp 125 deluxe.
    can you tell me how to use it.
    if some1 have pic that will be very helpfull
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Quote Originally Posted by MR.car View Post
    SP 125 ... well, look at the Left Side of Engine/Carburetter. You'll see a Small Lever.
    There are TWO points in this tiny lever.
    1. half choke
    2. full choke
    (i hope i am not mistaken about the details)
    DOWN all the way ... is OFF.
    Flip it UP 1 Point ... Half Choke
    Flip it UP 2 Points (all the way) ... FULL Choke
    Riders on the storm ... literally.
    MR.car's Avatar
    Apr 2010
    46
    53
    ok.
    How long i have to keep the bike in choke in cold weather.
    Should i just start the bike in full choke and immediate turn the choke off or keep it in choke for short while then turn it off.
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    ok.
    1 - 2 seconds of choke is enough. The purpose of Choke is simply put, to PUSH Fuel to help in cold start. Thats all.
    Flip the choke up, kick/self start, and when the bike does start, flip it back down.
    There is another way to start bike in Cold Weather, and i think its a better way.
    - Keep the Ignition Switch OFF.
    - Kick 4 - 5 times (with swtich off)
    - Turn Ignition Switch ON
    - Kick start
    It helps regulate the Mobile Oil inside the engine so the bike starts easily.
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    Lift the choke up and then start the bike when you feel the change in sound like it will be stop then close the choke and give race to your bike.
