Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Like Tree19Likes
Thread: Problems I faced with my Suzuki Sprinter and their resolution
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    Lightbulb Problems I faced with my Suzuki Sprinter and their solution
    1. Rare break screaming issue:
    I was facing an issue of screaming sound in rare wheel brakes. One of mechanic told me to get new brake shoes, another one told me to either change the plate or purchased some local custom made brake shoes.
    Finally issue is resolved by just applying grease. Mechanic did the following,
    1. Took out the plate and remove the brake shoes.
    2. Also took out the lever (including the stud).
    3. Applied grease on brake shoe springs, on the stud surface.
    4. Take a blade (normally to cut iron pipes) and made few scratches on the shoe surface.
    Thats it.
    It has 2 months now and no screaming sound anymore. I hope this will resolve other's problem too.
    2. Clutch handling:
    Some people including myself was facing difficulties with clutch release at bike pick. It has been resolved for me atleast. Mechanic just set the mixture to appropriate level, previously mixture was rich then required. Mixture setting was done after checking clutch setting itself.
    3. Rare tyre touches mud guard.
    I must say that it is not a problem rather than jump adjustment. I normally drive single so I do not face such issue only incase some heavy member is sitting behind me. Recently I adjusted my jumps and no issue face even with heavy person sitting behind. Jumps get little harder but still they are comfortable.
    Yes I do agree that mud guard is too close to tyre but this is benefitial I think in grip wise but not sure. I am saying this in the perspective of a lowered car greater road grip.
    4. Faulty speedometer:
    Generaly people complaint about faulty speedometer but I have not found the same. It is giving me accurate speed and kms readings. I am saying this after comparison with other bikes and cars.
    5. Faulty CDI unit:
    I do not believe in this. CDI unit is not faulty. But I saw people complaining about this and I found the main reason as; bike service at stations and alterations in wiring by some non-expert electrician.
    CDI unit is under the petrol tank and during service water reaches CDI unit. People start their bikes and due to moisture CDI get short. The suzuki bikes specialist told me this and there is no faulty CDI units.
    6. Seating Position:
    I. saw few people complaining about discomfort sitting position on Standard (non eco) sprinter. Well this is upto you, I have no such issue infact it is more upright which reduced strain in your shoulder and at your back and enjoy a much better ride.
    7. Head Light issue:
    Genuine or company fitted headlights are made of plastic so they have shorter life. Melt after after few years or incase of halogen, melts rather quickly. I have replaced company fitted headlight with honda 1982 - 86 (round light). Glass with metal beam. Issue resolved with some good light after installing halogen.
    In the end parts are bit expensive but are quality product as they are genuine. So less visits to mechanics. Lastly, I tried different oils be it Castrol Active, Caltex havoline, Zic but I found Shell and Castrol Active on top. Nice and smooth ride.
  2. #21
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    I had to get fuel tank of Sprinter repaint bcoz. New of old model priced around 4500 and if u want Fuel tank of Raider then u have to pay 6500 and side tapay price is not included ... So i get it repaint in 900 only tapay were ok but one must get it repaint as well to look better... After that u will have problem in finding stickers....
    Dont worry go to number plate and sticker makers.. And get ur own designed stickers... I have done that check pics Problems I faced with my Suzuki Sprinter and their resolution - u6e7umasProblems I faced with my Suzuki Sprinter and their resolution - mu9y8e7u
    Sent from my GT-I9000 using Xparent Green Tapatalk 2
  3. #22
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    I have done another adjust... This time seat of sprinter has been replaced with raider seat.. Which is more comfortable than sprinter...
    Raider seat is more comfortable and i have checked it personally no need to spent or waste money on seat poshish... As seat poshish will not help u in longer run... And there is no alteration required in seat replacement....
    Will try to replace back light and tail with Raider will tell u whether alteration is required or not...
    Here is a pic.
  4. #23
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Here is the picProblems I faced with my Suzuki Sprinter and their resolution - gatyjy4a
  5. #24
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Few days back i got another problem... Suddenly a noise started coming from front tyre... Initiatly i thought... It is Bearing... But when i reach mechanic it ws already night so he open the tyre carelessly and while open and check bearing and Speedometer gharari... He lost the lock for the speedometer gharari... And told me gharari is broken... I asked him to give it me... I will get it changed... When i went to mcloard market i didnt find that lock wich he lost...
    So now i had to go for jugarh....
    So i opened the front tyre and took out plate and went to kharaad nearby and get the custom lock... Wich is more like round ring lock... And i m done...
    There ws no issue of gharari it ws just a lock wich lost its position n broken .... So guys becareful while mechanic checking ur bike... Keep close eye coz parts are now short in the market wen it come to sprinter
    Sent from my Galaxy Nexus using Tapatalk
  6. #25
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    Quote Originally Posted by tucknoloji View Post
    Thats Good. Will u please post a picture from side angel.. how it looks....
  7. #26
    Zeeshan206's Avatar
    May 2009
    38
    1,778
    27 Post(s)
    10 Thread(s)
    SUZUKI please update your standard..
    <<<***ALHAMDULILLAH***>>>Yah ALLAH tera Shukar
  8. #27
    Site Banned Follow
    anti_xarak's Avatar
    Nov 2013
    79
    good thread!
  9. #28
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Standards are fine internationally ... Its only Pakistan franchises who like to play with us... Providing us outdated stuff over decades and for the same we love them :-D
Tags for this Thread
