Results 1 to 4 of 4
Thread: Deluxe Seals leak (help required)
    ZHBabar's Avatar
    Jul 2010
    Rawalpindi
    36
    29
    Default Deluxe Seals leak (help required)
    AoA,
    My Deluxe (2011) Seals leak just after two years, Leakage is not much but i worried about it.
    The location of leakage is near clutch Strip, (up and down side of oil pump), All other area is well.
    When i drive bike oil is flow from here and spread on all engine,if not clean,
    Plz suggest me what to do?
    Leave it or change the seal.
    Ansee's Avatar
    Feb 2013
    Rawalpindi
    342
    27 Post(s)
    2 Thread(s)
    Leave it like this if you think your engine can run without Oil. Otherwise get it repaired ASAP.
    getscorpion's Avatar
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    leakage of oil can be harmful in long run ... plus the problem will only gonna worst in future so its better to change the seals right away ....
    Rise from the ashes,.....
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Get it fixed ASAP, The oil leaking will get increased with the passage of time.
