Page 11 of 16 FirstFirst ... 910111213 ... LastLast
Results 201 to 220 of 303
Like Tree299Likes
Thread: Club 500
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Club 500
    Asalam U Alikum,
    Friends Club 500 thread is for all those who love Bikes, Safety Gadget, Modifications etc.. Being a owner of GS 500 I tried to put all info that i have in my mind & experience that i have wth 500..
    My Traveling Experience with GS 500:
    Well Worlds Best bike in 90s as it was the king & Road Master of its time no dough long as well as short trip give u really comfort at 1st place. My 1st Long tour on 500 is to AJK for 3 days. Really its fun for me & enjoyed a lot on Highway as well as on narrow roads, Sharp turn, Mud, Water, Rocky road etc
    Plus Points:
    No Problem On long run ( even u ride continuous 8 hr)
    Good Grip
    Easy Break
    No Heat Up ( As it is Air Cooled)
    Neg Points:
    Change Handel If u wanna go Long rides its sport edition so have to bear it...
    Don't be smart in MUD..other wise
    Fuel Consumption :
    I am getting 25 @ long & at local 22
    GS500 Manual :
    You can print it really informative.....
    http://www.motorkari.cz/upload/files...ser-manual.pdf
    OIL CHANGE:
    http://gstwin.com/oil_change.htm
    Genuine Suzuki Parts Prices : (Est.)
    Oil Filter = 470/-
    Air Filter = 2400/-
    Disk Pad = 4119/-(Rear) 5671/- (Front)
    Chain Sprocket Set = 17140/-
    Clutch Lever = 750/-
    Break Lever = 750/-
    Tyre Rear + Front Dunlop = 34500/-
    Clutch Cable = 1850/-
    Excelerator Cable = 2440/-
    Battery 11amp Liquid = 3800/- Dry = 1800/-
    Maintenance Schedule
    Club 500 -1186256
    • Initial Service
      • Tighten cylinder nuts and exhaust bolts
      • Inspect valve clearance, adjust if necessary
      • Inspect all fuel lines for leakage
      • (California models) Inspect evaporation canister and vapor lines
      • Change engine oil and replace filter
      • Check engine idle speed; adjust to 1200 rpm if necessary
      • Check clutch adjustment; adjust if necessary
      • Check drive chain tension; adjust if necessary
      • Inspect all brake hoses for leakage
      • Check brake fluid levels in both master cylinders; add fluid if necessary
      • Check brake pad wear
      • Inspect tire condition and air pressure
      • Check steering operation; adjust if necessary
      • Check operation of front forks
      • Check rear suspension operation
      • Check all chassis bolts and nuts for tightness; tighten if necessary
    • Every 600 miles (1000km)
      • Clean & Lube Chain
      • Check Oil level. The distance from Low to Full on the Dipstick is approximately 1 pint (0.6 litres)
      • Check Tire Pressure (33psi Front & 36psi Rear)
    • Every 2000 miles (3000km)
      • Clean & inspect air filter
    • Every 4000 miles (6000km)
      • Check battery electrolyte level and condition
      • Inspect spark plugs; regap or replace if necessary
      • Tighten cylinder head nuts and exhaust pipe bolts
      • Inspect valve clearance; adjust if necessary
      • Inspect all fuel lines for deterioration and leakage
      • Inspect all brake hoses for chaffing, cracks or leakage
      • Check all cable adjustments; adjust if necessary
      • Check throttle grip operation, play and adjustment
      • Check headlight aim, adjust if necessary
      • Check front and rear brake light switch operation
      • Lubricate rear suspension linkage and swing arm bearings
    • Every 7500 miles (12000km)
      • Replace spark plugs
      • Replace Air Filter element
      • Synchronize carburetors
      • Check operation of front brake
      • Check front fork seals for leakage
      • Check rear shock absorber for leakage, looseness or damage. From forum post: "Push on the tail of the bike, and listen to hear if it sounds like the shock is sucking in air. Pay attention to how fast the shock compresses, and how it rebounds - if it feels like it shoots back like a spring, you have a failed shock. If it comes back in a somewhat controlled manor, the stock shock is probably okay. If it overshoots and bounces around a bit, definitely bad shock."
      • Check rear suspension linkage for looseness or damage
      • Inspect tires for excessive wear, cuts or other damage
      • Check wheel rims for damage
      • Inspect drive chain guide for wear
      • Check break pedal height
      • Check center stand for looseness or damage
      • Check side stand for looseness or damage
    • Every 2 years
      • Change Brake Fluid
    • Every 4 years
      • Replace all brake hoses
      • Replace all fuel lines
    FOR PARTS
    Suzuki Gs500 F (usa) parts list partsmanual partsfiche
    Suzuki GS500 Parts & Accessories - Parts N More - Japanese Vintage Motorcycle Parts[page]=3
  2. #201
    wonder_guy's Avatar
    Oct 2005
    33
    3,611
    17 Post(s)
    Any upcoming auction?
    Flavor of Life on a 2 Wheeler - Project |Suzuki GS 500e|
    http://www.pakwheels.com/forums/bikes-3-wheelers/220849-project-suzuki-gs-500-a
  3. #202
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    where did your Rocker go bro?
    It seems you never posted any thing about your bike ? did you sold it or you don't use it very often ?
    Quote Originally Posted by wonder_guy View Post
  4. #203
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Quote Originally Posted by vickytulla View Post
    And I think the kid knows the Rocket Science ?
    Yes the new kid has some familiarity with Rocket Science..
    And the kid is quite a mini monster.. Restoration thread with a few pics coming soon.
    Club 500 -1434609
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  5. #204
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Club 500 -1434643
  6. #205
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    'OH' 'MY' "GOD' !!! that is one hot orgasmic bike you got there.... let me guess if its not wonderguy not rocketscience then is it @MONOO ?????
    Waiting for thread to come up... dont forget to tag me
  7. #206
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Its not Monoo either..
  8. #207
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    let me guess .. .. @gorkan lol ...
    Quote Originally Posted by 7thgear View Post
  9. #208
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    I know the answer :-p
    Sent from my GT-I9500 using PW Forums mobile app
  10. #209
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    Not this year.may b next year.
    But u never know
  11. #210
    wonder_guy's Avatar
    Oct 2005
    33
    3,611
    17 Post(s)
    Actually doesn't get time to ride it. Its parked since i restored it just taken out 3-4 times. Have plans to do another restoration project lets see.
    BTW can you tell me how much the battery costs for it as the battery of my bike is gone
  12. #211
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    I dont think you need another bike I think you need to use this one little often .. @7thgear please shed some light on GS500e Batteries we need little help here.
    though I bought a 15Amp battery Chinese dry cell for 2k a year ago its works solid with GS550e and still in use in my 200cc, beside its small, maintaince free and ready to use..
  13. #212
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I have Chinese dry battery 15amp in both bikes. Works great. My blue bike starts on first self even when i started it after a month in last summer vacation, still got same battery in it.
  14. #213
    rulfat's Avatar
    Feb 2010
    Sahiwal
    683
    10 Post(s)
    2 Thread(s)
    From where u got Chinese dry battery? There is space in gs500 of 15 amp battery?
  15. #214
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Quote Originally Posted by rulfat View Post
    The mechanic managed it on his own. I shall post its pic.
  16. #215
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    I bought it from Mcleod Road, there are two shapes of 15/18Amp Dry cell Batteries one is like
    Club 500 -1436454
    and the other shape is like this :
    Club 500 -1436456
    and one can choose according to the space one has in its bike ...
  17. #216
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    by the way ... GS500 battery compartment can easily accommodate a 12V18Amp as well..
  18. #217
    wonder_guy's Avatar
    Oct 2005
    33
    3,611
    17 Post(s)
    For how much you got it. Any specific shop?
  19. #218
    wonder_guy's Avatar
    Oct 2005
    33
    3,611
    17 Post(s)
    Now i want to restore Honda RM as well. Have one in sight lets see wat happens
  20. #219
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Not sure, as I mentioned mechanic managed the battery himself.
  21. #220
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    G2 & GS.... Not a bad result
    GS ATTITUDE
    Club 500 -1457769
Tags for this Thread
