Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 241 to 260 of 303
Like Tree299Likes
Thread: Club 500
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Club 500
    Asalam U Alikum,
    Friends Club 500 thread is for all those who love Bikes, Safety Gadget, Modifications etc.. Being a owner of GS 500 I tried to put all info that i have in my mind & experience that i have wth 500..
    My Traveling Experience with GS 500:
    Well Worlds Best bike in 90s as it was the king & Road Master of its time no dough long as well as short trip give u really comfort at 1st place. My 1st Long tour on 500 is to AJK for 3 days. Really its fun for me & enjoyed a lot on Highway as well as on narrow roads, Sharp turn, Mud, Water, Rocky road etc
    Plus Points:
    No Problem On long run ( even u ride continuous 8 hr)
    Good Grip
    Easy Break
    No Heat Up ( As it is Air Cooled)
    Neg Points:
    Change Handel If u wanna go Long rides its sport edition so have to bear it...
    Don't be smart in MUD..other wise
    Fuel Consumption :
    I am getting 25 @ long & at local 22
    GS500 Manual :
    You can print it really informative.....
    http://www.motorkari.cz/upload/files...ser-manual.pdf
    OIL CHANGE:
    http://gstwin.com/oil_change.htm
    Genuine Suzuki Parts Prices : (Est.)
    Oil Filter = 470/-
    Air Filter = 2400/-
    Disk Pad = 4119/-(Rear) 5671/- (Front)
    Chain Sprocket Set = 17140/-
    Clutch Lever = 750/-
    Break Lever = 750/-
    Tyre Rear + Front Dunlop = 34500/-
    Clutch Cable = 1850/-
    Excelerator Cable = 2440/-
    Battery 11amp Liquid = 3800/- Dry = 1800/-
    Maintenance Schedule
    Club 500 -1186256
    • Initial Service
      • Tighten cylinder nuts and exhaust bolts
      • Inspect valve clearance, adjust if necessary
      • Inspect all fuel lines for leakage
      • (California models) Inspect evaporation canister and vapor lines
      • Change engine oil and replace filter
      • Check engine idle speed; adjust to 1200 rpm if necessary
      • Check clutch adjustment; adjust if necessary
      • Check drive chain tension; adjust if necessary
      • Inspect all brake hoses for leakage
      • Check brake fluid levels in both master cylinders; add fluid if necessary
      • Check brake pad wear
      • Inspect tire condition and air pressure
      • Check steering operation; adjust if necessary
      • Check operation of front forks
      • Check rear suspension operation
      • Check all chassis bolts and nuts for tightness; tighten if necessary
    • Every 600 miles (1000km)
      • Clean & Lube Chain
      • Check Oil level. The distance from Low to Full on the Dipstick is approximately 1 pint (0.6 litres)
      • Check Tire Pressure (33psi Front & 36psi Rear)
    • Every 2000 miles (3000km)
      • Clean & inspect air filter
    • Every 4000 miles (6000km)
      • Check battery electrolyte level and condition
      • Inspect spark plugs; regap or replace if necessary
      • Tighten cylinder head nuts and exhaust pipe bolts
      • Inspect valve clearance; adjust if necessary
      • Inspect all fuel lines for deterioration and leakage
      • Inspect all brake hoses for chaffing, cracks or leakage
      • Check all cable adjustments; adjust if necessary
      • Check throttle grip operation, play and adjustment
      • Check headlight aim, adjust if necessary
      • Check front and rear brake light switch operation
      • Lubricate rear suspension linkage and swing arm bearings
    • Every 7500 miles (12000km)
      • Replace spark plugs
      • Replace Air Filter element
      • Synchronize carburetors
      • Check operation of front brake
      • Check front fork seals for leakage
      • Check rear shock absorber for leakage, looseness or damage. From forum post: "Push on the tail of the bike, and listen to hear if it sounds like the shock is sucking in air. Pay attention to how fast the shock compresses, and how it rebounds - if it feels like it shoots back like a spring, you have a failed shock. If it comes back in a somewhat controlled manor, the stock shock is probably okay. If it overshoots and bounces around a bit, definitely bad shock."
      • Check rear suspension linkage for looseness or damage
      • Inspect tires for excessive wear, cuts or other damage
      • Check wheel rims for damage
      • Inspect drive chain guide for wear
      • Check break pedal height
      • Check center stand for looseness or damage
      • Check side stand for looseness or damage
    • Every 2 years
      • Change Brake Fluid
    • Every 4 years
      • Replace all brake hoses
      • Replace all fuel lines
    FOR PARTS
    Suzuki Gs500 F (usa) parts list partsmanual partsfiche
    Suzuki GS500 Parts & Accessories - Parts N More - Japanese Vintage Motorcycle Parts[page]=3
  2. #241
    honda_roxxx's Avatar
    Jul 2011
    81
    Quote Originally Posted by 7thgear View Post
    Visit Montgomery Road for stickers, you can order any sticker you want.
    For handle bar visit Bilal Gunj, cheaper option....or go to the mechanic Hani Noor at Jail Road, costlier option
    Ok thankss..i will visit bilal gunj..but is se shocks py negtv effect to ni hta koi?plus one thing more i want to increase rear seat height..from where should i get it done?
  3. #242
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Do you want to increase the seat height or the rear end/tail height for better road clearance? These are two different situations.
    For getting more ground clearance you need to raise the tail, which can be done by adjustment of the mono shock. Don't worry it does not harm the mono shock, else Suzuki would not have given the adjustment option at all
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  4. #243
    Jul 2011
    81
    Club 500 -1468748
  5. #244
    Jul 2011
    81
    i guess i want the tail height to rise a bit..can u suggest a good mechanic in lahore for handle change and mono shock adjustment,,dnt want my ride to be messed up by some anari..m attaching pic of my bike
  6. #245
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Any mechanic can do that for you, nothing big.
  7. #246
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    My blue GS. Pics from yesterday with beautiful view of clouds:
    Club 500 -1470520
    Club 500 -1470521
    Club 500 -1470522
  8. #247
    nabeel121's Avatar
    Jul 2014
    46
    Club 500 -1470520
    Club 500 -1470521
    Club 500 -1470522
    What a lovely bike and also lovely pics.
  9. #248
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Club 500 -1470520
    Club 500 -1470521
    Club 500 -1470522
    Zabardast....
  10. #249
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Club 500 -1470520
    Club 500 -1470521
    Club 500 -1470522
    Awesome mashallah how much a gs like this will cost me?
    4 wheels move the body 2 wheels move the soul
  11. #250
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @d3vil, shafin619
    Thanks
  12. #251
    wonder_guy's Avatar
    Oct 2005
    33
    3,611
    17 Post(s)
    Quote Originally Posted by Shafin619 View Post
    PM me if u r seriously looking for GS.
    Sent from my iPad using PW Forums
    Flavor of Life on a 2 Wheeler - Project |Suzuki GS 500e|
    http://www.pakwheels.com/forums/bikes-3-wheelers/220849-project-suzuki-gs-500-a
  13. #252
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Have u ever seen this kind of GS500....
    Suzuki gs500e chop / bobber
    One off frame powder coated
    One off electric box
    Retro ribbed rear guard
    Sportster tank
    Painted in candy orange
    Club 500 -1474702Club 500 -1474703
  14. #253
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    Quote Originally Posted by d3vil View Post
    Sportster tank
    Where is rear shock?
    Sent from my GT-I9500 using PW Forums mobile app
  15. #254
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by MONOO View Post
    Modification I guess under the side cover....
  16. #255
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    Where is rear shock?Sent from my GT-I9500 using PW Forums mobile app
    Bobbers usually have a hard tail, some have springs under the seat. I wonder how its handling would be
    “Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac”
  17. #256
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    The adjustment on the rear shock is only for the preload, it hardly affects the effective ride height, to increase the ground clearance, ppl usually weld something to one end of the shock, but that's not something i'd recommend.
  18. #257
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Even for the pre-load adjustment height will increase. I increased the height of my blue GS considerable only though mono shock adjustment. Before adjustment the bike would touch on speed breakers with pillion riding, and after adjustment it does not.
  19. #258
    Jul 2011
    81
    is there anyone in lahore who can make custom fairings of good quality?i saw many bikes with custom fairings like fzr with new fairings..from where they get it done?
  20. #259
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    Quote Originally Posted by honda_roxxx View Post
    Ban jati hai bro
  21. #260
    RocketScience's Avatar
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Its your bike? When u purchased it?
Tags for this Thread
