Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 261 to 280 of 303
Like Tree299Likes
Thread: Club 500
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Club 500
    Asalam U Alikum,
    Friends Club 500 thread is for all those who love Bikes, Safety Gadget, Modifications etc.. Being a owner of GS 500 I tried to put all info that i have in my mind & experience that i have wth 500..
    My Traveling Experience with GS 500:
    Well Worlds Best bike in 90s as it was the king & Road Master of its time no dough long as well as short trip give u really comfort at 1st place. My 1st Long tour on 500 is to AJK for 3 days. Really its fun for me & enjoyed a lot on Highway as well as on narrow roads, Sharp turn, Mud, Water, Rocky road etc
    Plus Points:
    No Problem On long run ( even u ride continuous 8 hr)
    Good Grip
    Easy Break
    No Heat Up ( As it is Air Cooled)
    Neg Points:
    Change Handel If u wanna go Long rides its sport edition so have to bear it...
    Don't be smart in MUD..other wise
    Fuel Consumption :
    I am getting 25 @ long & at local 22
    GS500 Manual :
    You can print it really informative.....
    http://www.motorkari.cz/upload/files...ser-manual.pdf
    OIL CHANGE:
    http://gstwin.com/oil_change.htm
    Genuine Suzuki Parts Prices : (Est.)
    Oil Filter = 470/-
    Air Filter = 2400/-
    Disk Pad = 4119/-(Rear) 5671/- (Front)
    Chain Sprocket Set = 17140/-
    Clutch Lever = 750/-
    Break Lever = 750/-
    Tyre Rear + Front Dunlop = 34500/-
    Clutch Cable = 1850/-
    Excelerator Cable = 2440/-
    Battery 11amp Liquid = 3800/- Dry = 1800/-
    Maintenance Schedule
    Club 500 -1186256
    • Initial Service
      • Tighten cylinder nuts and exhaust bolts
      • Inspect valve clearance, adjust if necessary
      • Inspect all fuel lines for leakage
      • (California models) Inspect evaporation canister and vapor lines
      • Change engine oil and replace filter
      • Check engine idle speed; adjust to 1200 rpm if necessary
      • Check clutch adjustment; adjust if necessary
      • Check drive chain tension; adjust if necessary
      • Inspect all brake hoses for leakage
      • Check brake fluid levels in both master cylinders; add fluid if necessary
      • Check brake pad wear
      • Inspect tire condition and air pressure
      • Check steering operation; adjust if necessary
      • Check operation of front forks
      • Check rear suspension operation
      • Check all chassis bolts and nuts for tightness; tighten if necessary
    • Every 600 miles (1000km)
      • Clean & Lube Chain
      • Check Oil level. The distance from Low to Full on the Dipstick is approximately 1 pint (0.6 litres)
      • Check Tire Pressure (33psi Front & 36psi Rear)
    • Every 2000 miles (3000km)
      • Clean & inspect air filter
    • Every 4000 miles (6000km)
      • Check battery electrolyte level and condition
      • Inspect spark plugs; regap or replace if necessary
      • Tighten cylinder head nuts and exhaust pipe bolts
      • Inspect valve clearance; adjust if necessary
      • Inspect all fuel lines for deterioration and leakage
      • Inspect all brake hoses for chaffing, cracks or leakage
      • Check all cable adjustments; adjust if necessary
      • Check throttle grip operation, play and adjustment
      • Check headlight aim, adjust if necessary
      • Check front and rear brake light switch operation
      • Lubricate rear suspension linkage and swing arm bearings
    • Every 7500 miles (12000km)
      • Replace spark plugs
      • Replace Air Filter element
      • Synchronize carburetors
      • Check operation of front brake
      • Check front fork seals for leakage
      • Check rear shock absorber for leakage, looseness or damage. From forum post: "Push on the tail of the bike, and listen to hear if it sounds like the shock is sucking in air. Pay attention to how fast the shock compresses, and how it rebounds - if it feels like it shoots back like a spring, you have a failed shock. If it comes back in a somewhat controlled manor, the stock shock is probably okay. If it overshoots and bounces around a bit, definitely bad shock."
      • Check rear suspension linkage for looseness or damage
      • Inspect tires for excessive wear, cuts or other damage
      • Check wheel rims for damage
      • Inspect drive chain guide for wear
      • Check break pedal height
      • Check center stand for looseness or damage
      • Check side stand for looseness or damage
    • Every 2 years
      • Change Brake Fluid
    • Every 4 years
      • Replace all brake hoses
      • Replace all fuel lines
    FOR PARTS
    Suzuki Gs500 F (usa) parts list partsmanual partsfiche
    Suzuki GS500 Parts & Accessories - Parts N More - Japanese Vintage Motorcycle Parts[page]=3
  2. #261
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    New seat cover for my black GS:
    Club 500 -1500360
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  3. #262
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by 7thgear View Post
    Club 500 -1500360
    nice..
  4. #263
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Thanks
  5. #264
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    A recent shot of the blue GS:
    Club 500 -1500929
  6. #265
    honda_roxxx's Avatar
    Jul 2011
    81
    Quote Originally Posted by RocketScience View Post
    Its your bike? When u purchased it?
    About 3 4 months back
  7. #266
    RocketScience's Avatar
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Quote Originally Posted by honda_roxxx View Post
    If you dont mind, pls share ur purchase price via PM
  8. #267
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Khuram bhai, is it the same bike which you once saw before buying your own?
  9. #268
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Jee Talal Bhai, ye wohi bike hai?
  10. #269
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    GS Photo Shoot with Driven team, shots taken by Mubeen near Kalma underpass:
    Club 500 -1501920
    Club 500 -1501921
    Club 500 -1501922
    Club 500 -1501923
    Club 500 -1501924
    Club 500 -1501925
  11. #270
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,249
    7
    295 Post(s)
    11 Thread(s)
    9
    ^^^ Lovely clicks. bike and rider both looking great.
    I am only responsible for what I say, not for what you understand..
  12. #271
    wonder_guy's Avatar
    Oct 2005
    33
    3,613
    17 Post(s)
    Guys i want to sale my GS500. Interested can contact me at 0303-4440254.
    Flavor of Life on a 2 Wheeler - Project |Suzuki GS 500e|
    http://www.pakwheels.com/forums/bikes-3-wheelers/220849-project-suzuki-gs-500-a
  13. #272
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    This is one interesting GS. Brilliant work on this one..
    Club 500 -1503195
    Club 500 -1503196
  14. #273
    nabeel121's Avatar
    Jul 2014
    46
    Cool bike and cool shot.
    Club 500 -1501924
  15. #274
    nabeel121's Avatar
    Jul 2014
    46
    Quote Originally Posted by wonder_guy View Post
    Can you please send pics of your bike and demand?
  16. #275
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Thanks
    Quote Originally Posted by nabeel121 View Post
  17. #276
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    One day trip of 500km
  18. #277
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Keep rolling......
  19. #278
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Quote Originally Posted by juadjee View Post
    Hey guys, I'm a new member of the GS500 owner's club and new to the biking community altogether. Hope to have some good discussions here to help me better take care of my ride.
    Here's my bike:
    @juadjee I so badly miss this bike
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
  20. #279
    juadjee's Avatar
    Dec 2008
    30
    1,367
    12 Post(s)
    Quote Originally Posted by akifjanjua View Post
    Me too!
    The pain of war cannot exceed the woe of aftermath.
  21. #280
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,134
    19 Post(s)
    bro plz tell me the name and model of the camera these pics are awsome
    Club 500 -1501920
    Club 500 -1501921
    Club 500 -1501922
    Club 500 -1501923
    Club 500 -1501924
    Club 500 -1501925
Tags for this Thread
