Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 303
Like Tree299Likes
Thread: Club 500
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Club 500
    Asalam U Alikum,
    Friends Club 500 thread is for all those who love Bikes, Safety Gadget, Modifications etc.. Being a owner of GS 500 I tried to put all info that i have in my mind & experience that i have wth 500..
    My Traveling Experience with GS 500:
    Well Worlds Best bike in 90s as it was the king & Road Master of its time no dough long as well as short trip give u really comfort at 1st place. My 1st Long tour on 500 is to AJK for 3 days. Really its fun for me & enjoyed a lot on Highway as well as on narrow roads, Sharp turn, Mud, Water, Rocky road etc
    Plus Points:
    No Problem On long run ( even u ride continuous 8 hr)
    Good Grip
    Easy Break
    No Heat Up ( As it is Air Cooled)
    Neg Points:
    Change Handel If u wanna go Long rides its sport edition so have to bear it...
    Don't be smart in MUD..other wise
    Fuel Consumption :
    I am getting 25 @ long & at local 22
    GS500 Manual :
    You can print it really informative.....
    http://www.motorkari.cz/upload/files...ser-manual.pdf
    OIL CHANGE:
    http://gstwin.com/oil_change.htm
    Genuine Suzuki Parts Prices : (Est.)
    Oil Filter = 470/-
    Air Filter = 2400/-
    Disk Pad = 4119/-(Rear) 5671/- (Front)
    Chain Sprocket Set = 17140/-
    Clutch Lever = 750/-
    Break Lever = 750/-
    Tyre Rear + Front Dunlop = 34500/-
    Clutch Cable = 1850/-
    Excelerator Cable = 2440/-
    Battery 11amp Liquid = 3800/- Dry = 1800/-
    Maintenance Schedule
    Club 500 -1186256
    • Initial Service
      • Tighten cylinder nuts and exhaust bolts
      • Inspect valve clearance, adjust if necessary
      • Inspect all fuel lines for leakage
      • (California models) Inspect evaporation canister and vapor lines
      • Change engine oil and replace filter
      • Check engine idle speed; adjust to 1200 rpm if necessary
      • Check clutch adjustment; adjust if necessary
      • Check drive chain tension; adjust if necessary
      • Inspect all brake hoses for leakage
      • Check brake fluid levels in both master cylinders; add fluid if necessary
      • Check brake pad wear
      • Inspect tire condition and air pressure
      • Check steering operation; adjust if necessary
      • Check operation of front forks
      • Check rear suspension operation
      • Check all chassis bolts and nuts for tightness; tighten if necessary
    • Every 600 miles (1000km)
      • Clean & Lube Chain
      • Check Oil level. The distance from Low to Full on the Dipstick is approximately 1 pint (0.6 litres)
      • Check Tire Pressure (33psi Front & 36psi Rear)
    • Every 2000 miles (3000km)
      • Clean & inspect air filter
    • Every 4000 miles (6000km)
      • Check battery electrolyte level and condition
      • Inspect spark plugs; regap or replace if necessary
      • Tighten cylinder head nuts and exhaust pipe bolts
      • Inspect valve clearance; adjust if necessary
      • Inspect all fuel lines for deterioration and leakage
      • Inspect all brake hoses for chaffing, cracks or leakage
      • Check all cable adjustments; adjust if necessary
      • Check throttle grip operation, play and adjustment
      • Check headlight aim, adjust if necessary
      • Check front and rear brake light switch operation
      • Lubricate rear suspension linkage and swing arm bearings
    • Every 7500 miles (12000km)
      • Replace spark plugs
      • Replace Air Filter element
      • Synchronize carburetors
      • Check operation of front brake
      • Check front fork seals for leakage
      • Check rear shock absorber for leakage, looseness or damage. From forum post: "Push on the tail of the bike, and listen to hear if it sounds like the shock is sucking in air. Pay attention to how fast the shock compresses, and how it rebounds - if it feels like it shoots back like a spring, you have a failed shock. If it comes back in a somewhat controlled manor, the stock shock is probably okay. If it overshoots and bounces around a bit, definitely bad shock."
      • Check rear suspension linkage for looseness or damage
      • Inspect tires for excessive wear, cuts or other damage
      • Check wheel rims for damage
      • Inspect drive chain guide for wear
      • Check break pedal height
      • Check center stand for looseness or damage
      • Check side stand for looseness or damage
    • Every 2 years
      • Change Brake Fluid
    • Every 4 years
      • Replace all brake hoses
      • Replace all fuel lines
    FOR PARTS
    Suzuki Gs500 F (usa) parts list partsmanual partsfiche
    Suzuki GS500 Parts & Accessories - Parts N More - Japanese Vintage Motorcycle Parts[page]=3
  2. #41
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Quote Originally Posted by d3vil View Post
    MashALLAH je mabrook...nice restore....Give some more info abt model etc...
    Brother thanks for appreciating. It is a UK import bike and was under the use of a private owner. It is not the usual motorway or Punjab police auction bike
    It was a very clean piece to begin with and just a little love was required like new front and rear tyres
  3. #42
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by BlueHorn View Post
    Hmm Nice addition bahi je...UK spec SLING SHOT same as mine...But Model ???
  4. #43
    Faisal_Computer's Avatar
    Oct 2010
    Kamalia
    963
    21 Post(s)
    What is the price of GS500E Clean and Custom paid bike Specially from Lahore ?
    Br
    Faisal_Computer
  5. #44
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by Faisal_Computer View Post
    Br
    Faisal_Computer
    GS500 is custom paid u hardly found NCP.... For the price concern..All Depend upon model...Condition... Estimated cost for Clean & Sound GS having all***** five stars cost you more then 300k..
  6. #45
    Oct 2010
    Kamalia
    963
    21 Post(s)
    Hello brother,
    can you please post more details in 200k which model I can get ? Also as you can read from my profile I am from remote area so I need Bike which run smoothly and not require work after every some time so hat you suggest ?
    Thanks
    br
    Faisal_Computer
  7. #46
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Hello brother,
    Thanks
    br
    Faisal_Computer
    @Faisal_Computer
    Well as GS is concern it is most reliable & toughest bike in SUZUKI history. Parts are locally available & every 4 stoke mechanic can do little checkup no big deed even u can also.. Fuel consumption is very good in 500 Series...Good for long & short tours...Bur not for Mud & Gravel tracks....
    For model in 200k u can get 1992 to 2003 but condition matters... Sealed engine with full power cost u more then rebuilt engine... Then Important parts come in line...Like SHOKES, TYERS, BREAKS,CORROBORATOR, etc..
  8. #47
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    I was reading the maintenance schedule of gs500e and found that the valve clearance has to be checked (and adjusted if required) every 5000 km or so. Are the mechanics here aware of this and do they check it when they do tuning of this bike? And to adjust the clearance, you need a small chip called "shim" of required size. Are shims easily available from spare-part stores here.
    “Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac”
  9. #48
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    also the maintenance schedule says that the oil should be changed after every 6000km. but ppl here recommend changing engine oil after every 1000km. I know some would say that in pakistan we have more dust and pollution and stuff, but 1000km vs 6000km, ab itni bhi nahi hai pollution.
    GStwin.com Wiki - Maintenance Schedule
  10. #49
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by gorkan View Post
    Well Bro A good mechanic always have SHIM ..I remember when i go for tuning my Honda 92 Cd70 In case he want to check gap between valve he use SHIM ...having different in diameter... But for GS is concern if it was well tuned then no need to do it again & again...As for the oil is concern It is same like a car...a good oil will give u better millage if u use poor quality or SASTA oil it u will have to change it quickly...
  11. #50
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    the guy who to change oil at 1000km max, recommended this for caltex havoline. Which is probably among the best oils available in pakistan. as far as car is concerned, I always use good quality fully synthetic 5w40 oil and use it for round ten thousand km with genuine filters. (my car's engine is like new even after 11 years, Alhadmolillah).
    but in case of bike, the engine runs at higher rpms, so I can imagine the drain interval would be shorter, 5000-6000 km seems reasonable, 1000km doesn't make a lot of sense to me
  12. #51
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Correct but for Genuine engine oils if found.
  13. #52
    MONOO's Avatar
    Apr 2009
    29
    1,249
    48 Post(s)
    4 Thread(s)
    bro i used to change it at every 900 to 950km
  14. #53
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    Why, did you feel the need to do so, or you just own an oil refinery.? :-D
  15. #54
    a1ms's Avatar
    Feb 2010
    35
    8,225
    99 Post(s)
    9 Thread(s)
    excellent, ride safe .
    CTRL + Q to Enable/Disable GoPhoto.it
    "Wasting time is worse than death because death separates you from this world whereas wasting time separates you from Allah".
  16. #55
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Quote Originally Posted by MONOO View Post
    Bro which bike do you have?
  17. #56
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by a1ms View Post
    Wo ayah jin ka intazar tha....Bahi loog bhool kar aha he gayh...
  18. #57
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    my friend is looking to sell his gs500e 2001 model islamabad registered registration number is also 500.
    If anyone interested pm me i'll send you the contact number.
  19. #58
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by arsi_mast View Post
    G8...You should post some pics...So if some body interested he will Call him...
  20. #59
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Yes, please do favor and first post the Pics of bike.
  21. #60
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    These are the old pics of the bike now the colour scheme is going to be changed in a week .
    When the bike will be ready i'll post the latest pics with contact number.
Tags for this Thread
