Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 303
Like Tree299Likes
Thread: Club 500
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Club 500
    Asalam U Alikum,
    Friends Club 500 thread is for all those who love Bikes, Safety Gadget, Modifications etc.. Being a owner of GS 500 I tried to put all info that i have in my mind & experience that i have wth 500..
    My Traveling Experience with GS 500:
    Well Worlds Best bike in 90s as it was the king & Road Master of its time no dough long as well as short trip give u really comfort at 1st place. My 1st Long tour on 500 is to AJK for 3 days. Really its fun for me & enjoyed a lot on Highway as well as on narrow roads, Sharp turn, Mud, Water, Rocky road etc
    Plus Points:
    No Problem On long run ( even u ride continuous 8 hr)
    Good Grip
    Easy Break
    No Heat Up ( As it is Air Cooled)
    Neg Points:
    Change Handel If u wanna go Long rides its sport edition so have to bear it...
    Don't be smart in MUD..other wise
    Fuel Consumption :
    I am getting 25 @ long & at local 22
    GS500 Manual :
    You can print it really informative.....
    http://www.motorkari.cz/upload/files...ser-manual.pdf
    OIL CHANGE:
    http://gstwin.com/oil_change.htm
    Genuine Suzuki Parts Prices : (Est.)
    Oil Filter = 470/-
    Air Filter = 2400/-
    Disk Pad = 4119/-(Rear) 5671/- (Front)
    Chain Sprocket Set = 17140/-
    Clutch Lever = 750/-
    Break Lever = 750/-
    Tyre Rear + Front Dunlop = 34500/-
    Clutch Cable = 1850/-
    Excelerator Cable = 2440/-
    Battery 11amp Liquid = 3800/- Dry = 1800/-
    Maintenance Schedule
    Club 500 -1186256
    • Initial Service
      • Tighten cylinder nuts and exhaust bolts
      • Inspect valve clearance, adjust if necessary
      • Inspect all fuel lines for leakage
      • (California models) Inspect evaporation canister and vapor lines
      • Change engine oil and replace filter
      • Check engine idle speed; adjust to 1200 rpm if necessary
      • Check clutch adjustment; adjust if necessary
      • Check drive chain tension; adjust if necessary
      • Inspect all brake hoses for leakage
      • Check brake fluid levels in both master cylinders; add fluid if necessary
      • Check brake pad wear
      • Inspect tire condition and air pressure
      • Check steering operation; adjust if necessary
      • Check operation of front forks
      • Check rear suspension operation
      • Check all chassis bolts and nuts for tightness; tighten if necessary
    • Every 600 miles (1000km)
      • Clean & Lube Chain
      • Check Oil level. The distance from Low to Full on the Dipstick is approximately 1 pint (0.6 litres)
      • Check Tire Pressure (33psi Front & 36psi Rear)
    • Every 2000 miles (3000km)
      • Clean & inspect air filter
    • Every 4000 miles (6000km)
      • Check battery electrolyte level and condition
      • Inspect spark plugs; regap or replace if necessary
      • Tighten cylinder head nuts and exhaust pipe bolts
      • Inspect valve clearance; adjust if necessary
      • Inspect all fuel lines for deterioration and leakage
      • Inspect all brake hoses for chaffing, cracks or leakage
      • Check all cable adjustments; adjust if necessary
      • Check throttle grip operation, play and adjustment
      • Check headlight aim, adjust if necessary
      • Check front and rear brake light switch operation
      • Lubricate rear suspension linkage and swing arm bearings
    • Every 7500 miles (12000km)
      • Replace spark plugs
      • Replace Air Filter element
      • Synchronize carburetors
      • Check operation of front brake
      • Check front fork seals for leakage
      • Check rear shock absorber for leakage, looseness or damage. From forum post: "Push on the tail of the bike, and listen to hear if it sounds like the shock is sucking in air. Pay attention to how fast the shock compresses, and how it rebounds - if it feels like it shoots back like a spring, you have a failed shock. If it comes back in a somewhat controlled manor, the stock shock is probably okay. If it overshoots and bounces around a bit, definitely bad shock."
      • Check rear suspension linkage for looseness or damage
      • Inspect tires for excessive wear, cuts or other damage
      • Check wheel rims for damage
      • Inspect drive chain guide for wear
      • Check break pedal height
      • Check center stand for looseness or damage
      • Check side stand for looseness or damage
    • Every 2 years
      • Change Brake Fluid
    • Every 4 years
      • Replace all brake hoses
      • Replace all fuel lines
    FOR PARTS
    Suzuki Gs500 F (usa) parts list partsmanual partsfiche
    Suzuki GS500 Parts & Accessories - Parts N More - Japanese Vintage Motorcycle Parts[page]=3
  2. #161
    JUNAIDMIRZA's Avatar
    Oct 2011
    62
    Quote Originally Posted by vickytulla View Post
    it looks like a cd 70 handle in front of huge fat tank of ur ride.. Color scheme is nice.
    brother handle is of 150 for long rides and cruising see my avatar same handle on yellow one
  3. #162
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
  4. #163
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
  5. #164
    RocketScience's Avatar
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Quote Originally Posted by JUNAIDMIRZA View Post
    Junaid Bro! You r right, during travelling from ISB to LHR, I didn't feel any stress on my shoulders.
  6. #165
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    the day I spotted you on Ring road you were comming from Islamabad ?
    Quote Originally Posted by RocketScience View Post
  7. #166
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Well Travelling on GS500 on long ride dont give u pain in back & shoulders even u have sports bar handle.. Personal Experience
  8. #167
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Yup
  9. #168
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Quote Originally Posted by d3vil View Post
    Sports handle will give u stress...
  10. #169
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Don't know abt others.... But mine is more comfortable did long of 130km continuous & more without a stop on GT Road..
  11. #170
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I agree with you. I too have original clip on bars on mine and before doing the tour I thought that clip on bars will leave me dead tired hardly after 20km ride, but it didn't. Earlier I had plans of getting longer bars, but after the tour ride experience I have no such plans any more
    However, it can be said that with longer handle bar it will get even more comfortable.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  12. #171
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Quote Originally Posted by 7thgear View Post
    Talal bhai how much distance you have covered in one sitting?
    Sent from my Lumia 720 using Tapatalk
  13. #172
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^ A total of about 120km in one day. I have done several tours of Soun valley on my CG125 and hardly an hour's ride would make me tired, but in case of GS500 things are quite different, thanks to soft seat and mono shock which make the ride comfortable.
  14. #173
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Some Changes for more Joyful ride...
    DID Heavy Duty Extreme performance Chain & Spocket set.
    Excelerator cable
    Disk Pads
    All Prices has been updated in 1st Post....
    Club 500 -1306157Club 500 -1306158Club 500 -1306159Club 500 -1306160Club 500 -1306161
  15. #174
    shaty002's Avatar
    Dec 2008
    34
    141
    4 Post(s)
    Whoa, a thread for GS500! I owned a 1996 till Friday which I sold then. But have already struck a deal for a 2003 which I'll be getting on Monday or Tuesday! Looking forward to the GS500 GTG if we can have one.
    Junaid Mirza Bhai: The tail that you have on your GS, it is a custom made, isn't it? It seems wider than the normal one.
  16. #175
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by shaty002 View Post
    Dera dera advance mabrook for 2003... InshALLAH very soon have GTG..
  17. #176
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    @7thgear
    For Kit Details Empty your inbox...
  18. #177
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Cleared for space
  19. #178
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Little More Addition to My Bike Gadgets
    STUDD: SCORPION D4 SS
    Club 500 -1357071Club 500 -1357072Club 500 -1357073Club 500 -1357074Club 500 -1357075Club 500 -1357076
  20. #179
    sH3ikH's Avatar
    Jul 2011
    201
    Default gs500 2001 model police auctioned
    got this babe after loads of struggle nd resources. this bike ws still under use nd due to high resources i got it. am riding it as it is currently and will soon get it restored as a street racer till m done with maintaining my remaining fleet of bikes :p Club 500 -1365930
  21. #180
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by sH3ikH View Post
    Mabrook...... Will See wht this monster come up wth......
Tags for this Thread
