Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Like Tree61Likes
Thread: Look What I found Inside the Engine
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Default Look What I found Inside the Engine
    What happened on Labor Day 2013?
    I had the opportunity to spent sometime on my bike today. Its a Chonda UD-70 model 2008. I bought it new and since then I had not witness any mechanical failure whatsoever. Finally 35,000 KMs later the clutch finally gave up. I got a sticky clutch! which means either the plates are worn or the bush needs replacement. Wrestled with the bolts to open the clutch cover (really need to buy an impact screwdriver), obviously I drained the oil first.........and this is what I found inside.
    Look What I found Inside the Engine -1179674Look What I found Inside the Engine -1179675Look What I found Inside the Engine -1179676Look What I found Inside the Engine -1179677
    Laying at the bottom of the engine, right next to the inlet of the oil pump was a "STONE" and not a tiny one........
    I'm Amazed, disappointed, relieved, confused and out right flabbergasted simultaneously.
    Bikes don't leak oil, they mark their territory.
    faizandawood007's Avatar
    Jan 2012
    Gujranwala
    25
    2,566
    33 Post(s)
    5 Thread(s)
    Looks like an ALIEN to me
    Can,t think of a better signature
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by faizandawood007 View Post
    Well technically speaking this stone is alien to the engine.
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,277
    90 Post(s)
    7 Thread(s)
    You found it in engine oil???
    which oil you use in your bike??
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,309
    6
    8
    51 Post(s)
    4 Thread(s)
    Quote Originally Posted by aximaxim View Post
    Someone has put these in your engine aka aail wala tapa.
    btw ap ki kisi dost se fight to nhn hoe?
    Just Do It Your Self!!!!!
    Ansee's Avatar
    Feb 2013
    Rawalpindi
    342
    27 Post(s)
    2 Thread(s)
    Mother of Rock! 0_0
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Thats quite some treasure you found in there..
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by gull_s_777 View Post
    hahahaha.... I did not find it in the engine oil.....its so big it would have never passed through the drain hole underneath the engine. It was laying inside the engine....right at the bottom. I always use Shell Advance 20w-50.......ek number oil.
    usmanulamin's Avatar
    Jan 2011
    Sialkot
    21
    7,349
    33 Post(s)
    4 Thread(s)
    Strange ... O_o
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by umarkhan1 View Post
    Sadly so......someone must have slipped it inside the engine through the engine oil fill-up inlet (from where you top-up the engine oil).
    Im really not sure something did it out of jealousy or hostility.... I think some kid did it. Khair no damage was done luckily
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by 7thgear View Post
    Well sadly this isnt the first time it happened to me. Once when I drained the oil I found a handful of "BAJRI" (pebbles) in the oil. This is the second time.....and this time i found something even more outlandish and outrageous in the engine.
    Khair whoever he was......he failed........JISSAY ALLAH RAKHAY...........USSAY KON CHAKHAY.
  12. #12
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Damn very strange you saying this second time happening with you
    i think there is some one who is jealous with you or with your bikes
    lagta hai ab oil filler cap ko bhi lock lagwaana parhega
  13. #13
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,247
    7
    295 Post(s)
    11 Thread(s)
    9
    Seems like a kid while playing put the coin and stone through oil cap.
    Saying this cause at my place family kids try to do this -- cause they see us doing this with bikes/car and other tool works.
    I am only responsible for what I say, not for what you understand..
  14. #14
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by amjad635 View Post
    I think he must have slipped in the stone and bajri at the same time........ I just didnt find the stone when I found the bajri.
    Ab kis kis cheez par taalay lagaye gaaay.
  15. #15
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Unlike fuel cork lock there is no Engine oil cap lock available atm sigh
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  16. #16
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by KamranAslam View Post
    I have no kids at home....... I always have parked my bike inside the garage at home....... even at the office the parking place is high security multi storey kind thing. Khair the important thing is not who did it........but nothing happened
  17. #17
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    yeah right aximaxim lagta aise hi hai
    han yaar kis kis cheez par locks lagwaaye khuch waqat pehle mujhe ek
    mechanic jo mera dost hai bata raha tha aaj kal headlight or indicators ke
    jo button hote hai grips mein enki bhi kaafi choori ho rahe hai kiyonki yeh nahein milte esliye
    aur woh bata raha tha maine ek larki ko dekha jo brand new CD100 ka gear shifter
    le kar ghoom raha tha sale karne ke liye par shops walay nahein le rahe thi us se
    kiyonki cd100 ki kam sale hai toh maine khud hi usko 100 rupee de kar le liya tha
  18. #18
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Treasure
    legend will revive soon
  19. #19
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    The one rupee coin is placed next to the stone just to give you a reference of size of the stone........I just found the stone inside the engine......not the coin.
  20. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    get a machinist to make you a metal plug for the oil dipstick that can be unscrewed with a tool only, no contamination problem.
