Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By aximaxim
Thread: problem
    Majidkhan567's Avatar
    Dec 2012
    413
    2 Post(s)
    abdul_basit007's Avatar
    May 2010
    22
    161
    He had lowered the petrol average thats why the bike is not getting the proper level of petrol!
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Increase the idle engine RPM and the vibrations will stop.
    Bikes don't leak oil, they mark their territory.
    Dec 2012
    413
    2 Post(s)
    can you tell me how to increase bcz i m noob
    Dec 2012
    413
    2 Post(s)
    thnx basit
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by Majidkhan567 View Post
    problem -1184778
    turn the highlighted screw counter-clock-wise. be gentle, 20 degree turn might do the trick. BEFORE you touch the cARB.....PROPERLY Warm up your bike.
    Dec 2012
    413
    2 Post(s)
    ok bro thanx but previous by bike running perfect but problem is that during riding i stop accelerate bike off .
    than mechanic do some thing with carb then vibration start btw thnx
    Dec 2012
    413
    2 Post(s)
    but i ll capture tomrw and show you
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Thats what this screw is for.....it will increase your idle RPM.......when your throttle is not twisted that engine speed is called the idle speed and the screw adjusts the speed. Try it.....you'll learn on the job.
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    tappats might have been set incorrectly ...
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by asjdsm View Post
    really. tappat loose ho tow kya waqai itni vibration hoti hai.......?
  12. #12
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by aximaxim View Post
    What you mean by itni vibration?
    However improper valve clearance can cause vibrations. If the needle is lowered for less usage of petrol then it will scream harshly at peak speed and sound will be changed and top speed will be reduced
    Sent from my GT-I9300 using Tapatalk 2
  13. #13
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    What I meant is.............. if tappats are loose they make a noise and little bit of vibration.....but its really not that significant. Its more like a resonance created by the metal on metal contact which feels like a vibrations but it isnt the significant.
  14. #14
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    @Majidkhan567 you should check the petrol, is it from agency or from a good petrol pump?
  15. #15
    Dec 2012
    413
    2 Post(s)
    pso pump
  16. #16
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    I think if you get the pump changed to good one then it may be helpful.
  17. #17
    Dec 2012
    413
    2 Post(s)
    ok bro i ll go to mechanic than also adjust the carb problem
    and also check petrol from other
