Results 1 to 3 of 3
Thread: carburetor Settings Problem
    hasnatawan's Avatar
    Apr 2013
    Default carburetor Settings Problem
    My bike is 2000 model and its average is 20 km/liter after changing mixture by a mechanic after that i tried different mechanics but no use. what should i do change carburetor ? or need a good mechanic ?
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Bro what is the CC of this bike? Is it 70cc, 100 or 125?
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    bike konsi ha? is it 78cc chonda or 70cc honda? or some other beast ? i think it should be some 200cc two stroke
    however most carb problems are solved if all jets etc are properly seated and torqued and there is no air leaks any where from tank to the carb etc..
    have you tried using a definite amount of fuel to gauge its avg ? may be there would be some leak through which the petrol is evaporating during off time .. and over all you would be under the impresssion that that petrol is used by bike.
    tell us mroe aboute your beast .
