Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Like Tree11Likes
Thread: need engine help
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Unhappy need engine help
    AOA dear all i am fed up with engine rebuild build engine twice in last 6 months "USING ORIGINAL PARTS" but no output for the money spent and now the problem is it is heating too much in short i want to swap a new engine in it it is a honda CD-70 1999 where can i get a new engine and how much will it cost
    Regards
    All you need in this life is ignorance and confidence, and then success is sure.
  2. #21
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Ok will get it checked :-)
    Sent from my HTC Sensation 4G using PW Forums mobile app
  3. #22
    shazimzahir's Avatar
    May 2013
    Select City
    35
    3,259
    44 Post(s)
    4 Thread(s)
    Quote Originally Posted by makniazi View Post
    Regards
    Dear Bro i think The stamina of ur bike and your`s both are tired, i salute you to have a bike this long, now just sell this man new Engine plus labor will cost you around 22000-25000 so just buy new one,
  4. #23
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    shazimzahir 22000-25000 :O people are saying that engine costs 8-10k and fitting i can do it my self not tough job at all
    vickytulla thanks for you suggestions i searched on internet and found the gap of plug to be .6to .7 mm adjusted it with feeler gauge it was more than 1mm adjusted the air/fuel mixture over all bike is performing better than before starting is improved the other thing tappet clearance for this engine according to manual is 0.05 mm the are way too tight than 0.05mm mechanic adjusted them without gauge once i i adjusted them to 0.05mm before rebuild the mechanic said tappets are too lose should i adjust them to 0.05mm or leave them as it is
  5. #24
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    its utmost impoortant to adjust the clearnce within specs .. so u should set the tappets at .05mm for both ex and in .. if its still not improving then set in to .05 and ex to .08mm ..
  6. #25
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    I am Glad I came usefull ^_^
  7. #26
    afarooqi's Avatar
    Jul 2006
    38
    916
    20 Post(s)
    Adjust tappets according to the manual.
    Also check for exhaust (Silencer) for if it is choked. choked exhaust may also cause overheating.
    Prepare for the worst, Hope for the best.
  8. #27
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    +1 ... thats true ... given the bike is Old its exhaust must be choked too...
    Quote Originally Posted by afarooqi View Post
  9. #28
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    today on the way back home it was too hot and i had a feeling that bike is heating up and then what head gas kit gone bike is missing badly will open the head tomorrow to check for details and gas kit change
  10. #29
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    do post pics
  11. #30
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    here u go with the pics job well done and engine is running good one thing i noticed after adjusting the tappets that tikking noise is increased need engine help -1187717need engine help -1187718need engine help -1187719need engine help -1187720need engine help -1187721need engine help -1187723need engine help -1187724need engine help -1187726need engine help -1187727need engine help -1187728need engine help -1187729need engine help -1187731need engine help -1187732need engine help -1187733need engine help -1187734
  12. #31
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    need engine help -1187740need engine help -1187742need engine help -1187744need engine help -1187747need engine help -1187749need engine help -1187752need engine help -1187754need engine help -1187756
  13. #32
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    catastrophe..
    1: hope you would have cleaned the mating surfaces .. i.e. b/w cylinder and crankcase (which i doubt u have done ) // and head and cylinder.
    2: you have removed the head but not the cylinder .. did u loosened the nut that is holding the cylinder to the crankcase ? its importoant for proper allignment ...
    3: most important .. you are using the shittttttttttttteist every "Head Gasket" do not use this one . use the fiber gasket .. this is damn thick and you will loose a lot on compression ratio .. i had practical experience with it. since you are doint it yourself . i would recomend you to pry that gasket sheets seperate and use first only one thin metalic sheet as a head gasket and if it doesnt the valves doesnt hits the piston or piston doesnt hits the head .. then it will give u awesome compression . and hence power .. do dry run it .. i.e. after proper tightening of the bolts rotate the flywhell then .. if u are sure that there is sufficent clearance then try using few kicks with ignition off .. if there is no bad sound then it means that there is sufficient cleanrnce . then try runing it ..
    if one sheet is not giving you enough clearance . then use two sheets .. ( jo steel type ki hothi hain) .. if you still have issue with clearance with two sheets which in my opinion is unlickely .. then use the fiber one ..
    4: use little but enough curil between gaskets for perfect seal .
    5: tighten the head nuts in a criss cross fashion .. tighten in equal amount .. do not tight them in one go ..
  14. #33
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    1) yes I did clean the surfaces
    2)cylinder was removed will post pics later
    3)mechanic advised to use this gaskit
    4) slicon was used
    5) yes the head nuts were tightened in cross
  15. #34
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    4) slicon was used
    Hmmm. Next time use curil. In my experience is better then silicone.
    Mechanics dont know of compression ratio. Stock gaskets is thinner then this one. Even then the fiber one.
    Sent from my GT-I9300 using Tapatalk 2
  16. #35
    threestars2005's Avatar
    Aug 2012
    48
    bro plz guide us how to adjust valve clearance. upload some pics. thanks
  17. #36
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    threestars2005 its an easy task but if i write the procedure here you will not be able to understand you can go through this video although youtube is blocked i hope you know how to open it ? if not let me know will upload it on some other site and upload the link
    How to Adjust Honda 50/70 cc Valves - YouTube
  18. #37
    Aug 2012
    48
    thanks for ur reply. i'll adjust my yamaha 4stroke according to video.
  19. #38
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Bike was heating up again talked to a friend he told me of his trusted mechanic which was their old mechanic from the time of his father so went to him he said I will need to open the head cylinder and to my surprise he inspected and said 50 number piston is installed and even 100 is lose in this cylinder according to his advice I opted for brand new cylinder and 0 size piston and rings and he said ther is a problem with cam shaft also replaced cam shaft and cam was lose in the head so head has been sent to machine shop he said that if the head comes back today bike will be ready by evening
  20. #39
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    My baby is back on the road running awesome it never had been like this before since it is with me now i am completing its break-in (running) period driving it very very carefully as cylinder piston rings cam etc everything is new tappets are set a bit loose they mechanic said drive it for some time then will fix it so for now the sound is changed but running fine
  21. #40
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    nice to hear that .. also its good to have tappets loose of new engine ..
