Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By outlaw92
Thread: Kawasaki GTO-125
    salu786's Avatar
    Mar 2006
    30
    13
    Default Kawasaki GTO-125
    Hi guys do you know if kawsaki GTO125 can be modified to increase its pick and its top speed.
    Thanx
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    GTO 100/110 can be modified with over sized piston of GTO 125 but in case of GTO 125 Itself i dont Think u can do major modifictions. But u can do optimization of ur stock ride for peak performance.
    I had own this Bike for three years & how i do maintain my bike is as below.
    1) Piston/Rings set should be genuine instead of Japanease said in market.
    2) Cylinder also needs to be Genuine doesnt matter what the size is but sleeve shouldnt be rapaired one . (U can also use Indian & Irani Cylinder coz they r also Genuine but if found from relaible person).
    3) Genuine CDI Coils + High performance spark leads along with atleast Denso Spark Plug or u can have Bosh or split fire plugs too if available with same specs.
    4) Use twostroke Engine Oil in side oil bottle/Pump instead of mixing oil in Fuel tank for lubrication. Revtex 2T by Caltex is the best two stroke oil available in Pakistan use that one.
    5) dont try to Use Hi octane fuel just Use Standard Fuel.
    6) Clutch/Presure plates, Carburator, Sproket /Chains shouldbe well maintained & aligned.
    7) Rear tyre profile shoulbe not more than 3.00-18 or 100/80 -18 incase of tube less tyre.
    Dont try to use over sized drive sprokets coz this machine is alredy under touqued so it will die in fifth gear if u use them.
    Just follow these steps & u will feel the diffrence in over all performance i.e. Pick up, speed , & fuel effciency.
    Exploring Machines is my Passion...
    prince_dk's Avatar
    Mar 2006
    Dera ismail khan
    29
    270
    imran modifications possible for cd 70 92 model
    to increase its top speed plz let me know advice frm u
    tell me tips
    Killer...............!
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @prince_dk
    Its very dangerous machine having least road grip So dont try to enhance its speed.
    BTW maximum u can do is slightly advance current timing get hi jet in Carburater adjusted for rich mixture remove rubber enclosure of air filter tappet adjustment will also be required but i dont know about exact measurement then use over sized sprokets that can increase speed of ur bike 10~15Km per hour on straight road. These type of enhancements can be easily done by some mechnics who fix bikes for racing. In most of cities mechanics for these types of jobs can be easily found.
    prince_dk's Avatar
    Mar 2006
    Dera ismail khan
    29
    270
    thanx imran sir only 15 km and what abt points cdi is best or point system what u say abt that let me know abt that also
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @prince_dk
    Performance wise CDI is much Better than IDI (Point).
    enigmatool's Avatar
    Sep 2009
    39
    236
    good information.
    yamaha135's Avatar
    Mar 2009
    34
    403
    Quote Originally Posted by imranbhatti View Post
    @prince_dk
    I would beg to differ Imran bhai. maintenance wise a CDI is better but as far as performance goes Points are the way to go. and there are technical facts to back that claim, a point ignition can be modified to increase pick up or top speed whereas a CDI ignition cannot be modified until and unless the plate is modified, which not only is a pain to do but also disturbs/confuses the CDI.
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @Yamaha 135
    If u consider performance just as increase in speed, accelartion & Engine power then true but the main thing is performance is not all about accelaration, & power of speed & power.
    accord7362's Avatar
    Jun 2008
    44
    8,290
    6
    197 Post(s)
    34 Thread(s)
    Iused to own 1 and still in love with it
    Bhatti sab give the best maintaining details for all the youngsters who own any kind of biks as bhatti sab said "" the secret to get maximum out of any machine is to keep it stock"
    don't try to juggle a lot and you will loose the power and acceleration.
    http://www.pakwheels.com/forums/members-member-rides/266031-accord7362s-merc-thanks-god-loved-ones-who-remember-me-prayers ,199119-thanks-god-2011-ford-edge-limited-awd-3-5-v6
    yamaha135's Avatar
    Mar 2009
    34
    403
    @Yamaha 135
    then what is it all about?
  12. #12
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @Yamaha 135
    If talking specifically Electronic CDI system,
    1. It provides foul less ignition pulse to spark plug.
    2. Very much precise response while advancing spark timing according to engine RPM.
    3. Almost zero maintenance.
    4. Precise spark timing increases efficiency of engine hence its durability & reduces maintenance cost.
    If u r preferring point type Inductive discharge ignition system just bcoz of liberty of advancing & retarding it any time then u r just thinking it for modification purpose to gain short term power while reducing overall performance & durability of engine.
  13. #13
    waseem88's Avatar
    Nov 2009
    Faisalabad
    28
    1,172
    18 Post(s)
    Intelligence without ambition is a bird without wings.....!!!
  14. #14
    outlaw92's Avatar
    Apr 2009
    24
    220
    @Imran
    You say performance wise CDI is better.Then how come a Honda CG 125 point is wayyyyyyy faster than the CDI Models.My bro had a 125 89 model and believe me it was the fastest 125 i have ever ridden no cdi came close to it.It only stayed behind in pick but then as it got hotter it would easily cross those CDI Models even 99 power plus.
    To personally satisfy my own adrenalin needs, I've been racing Bikes a little bit, which has been fun.
