Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Like Tree9Likes
Thread: Sprockets ''35 15''
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Cool Sprockets ''35 15''
    After much hesitation and a lot of thought i finally decided to replace my genuine sprockets 41/14 with 35/15.
    Installation
    Well the installation was fairly simple, obviously the chain had to be shortened. Although the amount of hammering
    involved (''USTAD''), i was afraid the chain might get a little weak.
    Experience
    My experience with the new sprockets gear wise.
    • 1st = Definitely more longer than previous, however a very slight reduction in speed. Shifted to 2nd at 30km/r
    • 2nd= Very slight or almost no change, very minutely longer. Shifted to 3rd at about 55km/hr
    • 3rd = Now this is where the magic started, felt the real power of the engine the bike almost shot. On stock the 3rd gear was almost non existent but now it packed a punch. Went from 55 to 80km/h (GPS speed).
    • 4th = For a moment i had forgotten i had a 4th gear. However when i shifted to it the experience was not satisfactory bike got flat, it was cruising at 85km/hr, the RPM was quite low as if the engine was applying very little force.
    The maximum speed i got was 88km/h(GPS speed not the meter one) and i could maintain it relatively easily.
    Positives
    Phenomenal Power in 3rd gear.
    Low RPM in 4th gear
    Negatives
    Top speed not as much as i expected.
    However I am satisfied with it.
    Moral: No replacement for displacement.
    If you ride like there's no tomorrow, there won't be.
    asdalix's Avatar
    May 2013
    302
    3 Post(s)
    You should change them, change the rear sprocket to 37 and feel the difference, for eg 37/15.
    Add a Cg 125 carb tunning the carb from a good ustad,remove the air filter fully.
    Change your current coil and cdi of 125 china or Honda atlas 70.
    Cheers !
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    no mention of the bike ?
    i hope its chonda 78 ?
    few little mods:
    1: replace the pod air filter .. and get the best of both worlds . frew flow and engine prottection from dirty air. install it the way i installed it .. i had mad a post about it .. thats sweet.
    2: buy an aftermarket qingqi 100 carb and use intake pipe of suitable width and match its openings with that of the carb mouth .. you will get a lot of power.
    3: replace the head gasket with thinner head gasket. if its fiber head gasket replace it with so called janyan mettalic one .. the mettalic one in stock condition is very thick as its 4 metal sheets . just use one or two of them
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    change it to 15/41
    Team DEKA
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    41/16 The best setup I experienced:
    Recently I changed my front sprocket to 16 from 14. The front sprocket is stock (41). I have a Chonda 78cc and the result is awesome. As i live in Karachi, pillion riding is usually banned therefore on a single person's weight the bike feels great. The vibration is gone. The top speed has increased. 3rd gear is where I experience the biggest power band of the engine. You feel a slight decrease in torque when you engage the 4th gear but you will get use to it.
    Changing the sprocket not only increases performance of your bike but also saves you fuel. Try it!
    Bikes don't leak oil, they mark their territory.
    dared3vil19's Avatar
    Nov 2012
    73
    I am also thinking to change the sprockets.
    please suggest me which one to choose.
    i need less vibration and more fuel average.
    my bike is DYL dhoom 2012.
    also from where can i get these installed? i live in lahore.
    thanks
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by dared3vil19 View Post
    thanks
    do nothing.....just change your front sprocket from 14 to 16. I it cost you Rs.200 with labor cost and its a 10 minutes job maximum. Better fuel economy and less vibration is guaranteed.
    usman2792's Avatar
    Jul 2012
    131
    2 Post(s)
    Quote Originally Posted by aximaxim View Post
    Which size of sprocket(front and rear) should I install in cg 125(89)?
    I've also sent u pm.
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by usman2792 View Post
    I too had a CG 89 for quite sometime, however I never felt the need to replace the sprocket set on it, therefore I cant guide you in this matter. Obviously altering the final drive has its pros and cons and if you alter the stock setup you will loose the acceleration but will gain higher top speed and lesser vibrations while cruising.
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    replied
  12. #12
    asdalix's Avatar
    May 2013
    302
    3 Post(s)
    the above information is for 70, for CG 125 tunning if ur in karachi go to
    Waris ustad near cafe piyala he will suggest the best sprockets , best setting for carb for mileage plus pick.
  13. #13
    asdalix's Avatar
    May 2013
    302
    3 Post(s)
    Quote Originally Posted by Chaudhary007 View Post
    in Honda 70 dont do these tunning.
    the above stuff i recommended are for china 70cc.
  14. #14
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    for a genuine ride 15/41 is best try it
    Team DEKA
  15. #15
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    What's the reason for low pick in 4th gear ?
  16. #16
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    am running it on 16-38
    15-38 is the best
    free flow exhaust
    CDI 125
    increase spark-plug gap
    lose weight of ride
    85 mainjet
    pod air-filter
    cursing in 3rd 4th.
    on its meter it did 105 on highway .
  17. #17
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    wrong sprocket matching
    small carborator
    too much increased wheel rotation
    change it to 15/41
    Team DEKA
  18. #18
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by Maggi View Post
    small carborator
    change it to 15/41
    Im running on 16/41........have tried 15/41 too however the difference was negligible. I prefer the 16/41.....the difference from stock is evident. Obviously pickup thora hurt hota hai but I got use to it and now I cant ride a bike on stock sprocket......... They feel under powered.
  19. #19
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Torque reduces as you increase the gears.......... with altered sprockets the overall torque of the bike decreases hence reducing the acceleration of the bike. As 4th gear has the least torque already and with altered sprocket it reduces even further so feel a power decrease......its very evident.......but if your gear shifting is precise .... the difference in acceleration is something you can live with easily..........3rd gear may power band acha hota hai engine ka and it produces highest torque therefore 3rd feels great.
    For longer routes and highways where you need to cruise at decent speed.....an altered sprocket setup reaps its benefits. Lesser vibrations and better fuel efficiency. Not recommended for crowded routes.
  20. #20
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    I did it myself and sprocket cost 70 rs..
    Sent from my GT-I9300 using Tapatalk 2
