Results 1 to 1 of 1
Like Tree4Likes
  • 4 Post By mtmoghul
Thread: SC3 Adventure- A Dual Sport Modified Bike By Carducci
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    Lightbulb SC3 Adventure- A Dual Sport Modified Bike By Carducci
    Salam Friends,
    Here i am sharing some nice stuff that i found interesting n good. (I don't know it is new here at Pakwheels or not)
    Jim Carducci from Carducci Dual Sport has taken a Sportster engine and frame and performed a wild transformation.
    Teaming up with the team at San Jose Harley-Davidson, Carducci is offering owners of 1200 or 883 Sportsters from the year 1993 to 2003 the opportunity to turn their street cruiser into a fully capable off road machine. Carducci created the kit by himself, using CAD for design while building needed parts completely by hand. The finished product has been crowned the SC3 Adventure
    Features of the SC3 Adventure Dual Sport Motorcycle
    V-Twin Motor/engine The Sportster? motor/engine is proven reliable, air cooled, narrow and loaded with torque
    Frame Stock Sportster? frame with minor modifications
    Suspension Front: Ohlins 48mm USD forks mounted in strong triple clamps. Integrated Scotts steering damper
    Rear: Ohlins twin shocks on extended billet aluminum swingarm
    Wheels 140/80-18 rear, 90/90-21 front. A good combination for off-road handling
    Lighting Front headlight is a 55 watt halogen beam (an LED version is also available from Trail Tech?), and LED brake light and blinkers made to handle the vibrations of off-road riding
    Fly Screen The fly screen frame is made of structurally strong sheet aluminum and supports a tinted polycarbonate wind deflector that reduces wind on the body
    Controls Stock Sportster? throttle, speedometer, tachometer, brake, clutch, and wire harness
    Rear Rack & Fender Structurally strong for strapping down a tool kit, 2x 1/2 gal fluid cannisters on the sides, and more
    Skid Plate Protects the leading edge and underside of the motor from flying debris and from rolling over large objects like rocks, stumps, et cetera
    Crash Bar Steel welded construction crash bar mounts to the frame and protects the leading edge of the gas tank
    Kick Stand Strong Chromemoly steel tubing with a large foot area for soft off-road surfaces. Adapts to the stock H-D kickstand mount
    Stability Long wheelbase and generous rake and trail make the SC3 Adventure stable at speed and it does well in loose sandy conditions
    Riding Position Foot controls and handlebars are positioned for comfortable dual sport off-road riding standing position. Seat is narrow in the front, wide in the back. Good for standing and longer distance seated riding
    Range Hand formed aluminum 6.3 gallon gas tank provides 200+ miles range before hitting reserve. Option for smaller 2.75 gallon aluminum gas
Tags for this Thread
