as every one is after LM, i thought of diversity and
going to try this soon and will share feedback
[TABLE="width: 807"]
<tbody>[TR]
[TD="align: center"]Gulf Pride 4T
[I]4-Stroke Motorcycle Oil
[/I][/TD]
[/TR]
</tbody>[/TABLE]
[TABLE="class: content, width: 675"]
<tbody>[TR]
[TD="class: h3"]Product Description[/TD]
[/TR]
[TR]
[TD]Gulf Pride 4T is a high quality 4-stroke gasoline engine oil developed specifically to meet the special requirements of air cooled 4-stroke motorcycles. It is blended from highly refined base oils and performance additives to provide protection to engine, gear box and wet clutch used in 4-stroke motorcycles. The product exceeds the international specifications of API SG and JASO MA for 4-stroke motorcycle oils and the requirements of leading global 4-stroke motorcycle manufacturers. It is available in five different viscometrics, viz SAE 10W-40, SAE 15W-40, SAE 15W-50, SAE 20W-40 and SAE 20W-50.[/TD]
[/TR]
[TR]
[TD="class: h3"]Features & Benefits[/TD]
[/TR]
[TR]
[TD]
- Excellent antiwear properties protect vital engine and gear components leading to reduced maintenance costs
- Good thermo-oxidative stability prevents harmful deposit formation and controls oil thickening facilitating extended engine and oil life
- Controlled frictional properties eliminate clutch slippage and improves drivability
- Better detergency/ dispersancy keeps engine cleaner and reduces maintenance costs
- Effective rust and corrosion inhibition property ensures longer life of critical engine components
[/TD]
[/TR]
[TR]
[TD="class: h3"]Applications[/TD]
[/TR]
[TR]
[TD]
- Recommended for air cooled 4-stroke motorcycle engines where an API SG and JASO MA quality oil is required
- Also suitable for small 4-stroke gasoline engines used in portable generators, pumps, garden machinery and other applications
[/TD]
[/TR]
</tbody>[/TABLE]
