Page 21 of 101 FirstFirst ... 1119202122233171 ... LastLast
Results 401 to 420 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #401
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    @Automotorsport_Lover ! Yaar i am in search of a good fork oil these days. Any help?
    Riders on the storm ... literally.
  3. #402
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by abobobilly View Post
    If you're successful in your search kindly inform me as well. Stupid mechanic poured used KALA engine oil into my bike's front forks
    After searching on web a good alternative to regular fork oil is ATF, automatic transmission fluid. Get it in the 5W to 15W range and you should be fine hopefully.
    Fork Oil Alternative - Bike Chat Forums
  4. #403
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by ammarzahid View Post
    You could have asked at least to put some fresh engine oil
    I have seen my local mechanic using fresh engine oil while repairing shocks of 70CCs ...
  5. #404
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Sure. But iss k liye successful hona paray ga na
    ATF is not really a good solution because we have to change it after 5k kilometers or so. Plus, it doesn't have Anti-Foaming materials. It can be used inplace of Fork oils but its not really a replacement for it, which is why i am hesitant.
    I am just surprised seeing the tension and difficulty i faced in obtaining one. Even the "famous" agencies who import barrels of oils don't give any information regarding fork oils. And i am honest, i have lost hope so far. As soon as you tell them you want it for yourself or your own bike, and the bike being "CG125" ... i am given looks which make me feel extremely cheap. Like its a crime to enter those shops and ask for a "small bottle" for our "puny bikes".
    I have had it for now which is why i am retreating to you people and your experience, if any of you have any idea so that i can proceed with my plan of rebuilding my front shock absorbers.
    Quote Originally Posted by gull_s_777 View Post
    Bhai bohat use kar liya hay engine oil. I am looking for supreme damping performance which we just can't get from engine oil. I want to experiment with some good quality fork oil (read my comments on previous page as well) to check the performance not only on plain road but also in bumpy conditions. I am 90% positive that i'll get my desired results with some quality fork oils available.
    Engine oils (even the thinnest) make the shocks performance either too hard or too soft. I have done enough experiment with that and i just don't want to use engine oil for that matter.
  6. #405
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    "I been using ATF (Dexron) for years, in my Harleys too...thing about ATF thats good, is that its non corosive, and anti-foaming, which can be a prob in forks. Try the ATF...if ya dont like it, easy enough to drain it out again and change. In the 70s, I used straight non-detergent 10 weight."
    Fork oil substitute? [Archive] - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
  7. #406
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    indeed it is a big hassle , that's why i didn't try to get Liqui Moly.
    Anyway as i told earlier, even though i found SGO not good after 700Km usage (it goes watery), i still shifted back to SGO after trying few brands as i found it a bit better than others (Havoline,Zic,AX-5). Well now again i am having same experience with SGO as i had first time. It was fine for first 600Km, but after that now i can feel that it's gone watery. Engine behaving and sound is crying for oil change now
    This is too much.. I can't change oil every 600Km
    While with Kixx, i faced bad clutch performance. Though i admire its endurance, it is the only oil found under Rs 500 which can withstand even 2000Km usage.
    Now have both of these at home, and confused what should i put inside my bike.
    Motorcycle Engine Oils -1283444
    Gull bhai i won't recommend kixx you previous time faced issue of clutch slippage from
    first day of using kixx so between these two i would recommend SGO
    my bike pridor does very well with its manufacture made oil AHl 20w40
    it can easily do 1000km without problem and i don't face any issue
    Bro as you are having issue with SGO too i would recommend why don't you give
    try to some other engine oil as gtx 20w50 or any other brand with thicker grade
    as SGO 10w40 becomes water after 600km
  8. #407
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Oh bro sad story... In Pakistan u see very little customer awareness and hence very little proper products..
    I'd ask LQ dealer the next time I go... Bdw u should think of getting it online or getting it imported thru someone. Did u check with filter house bdw?
    @ gull g
    I drained LQ at 1500kms, it wasn't wattery but needed a change now. It worked well, no clutch slippage here.
    U should really try n buy 2,3 packs of LQ semi synthetic 10w-40 with lycetuff, u even have oil filter in ur bike hence 2000kms would be like a breeze for it!
    But use new oil filter with LQ to truely check it's abilities...
    Its available for just 800rs / ltr and if u buy 3 packs... U can enjoy smooth performance till next 6000kms atleast!! Maybe 8000!
    Sent from my ST25i using Tapatalk 2
  9. #408
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Guys for fork oils you will have to import them from USA
    Their is a lahore based website called magiclamp.com
    You will have to deal with high price as this product will be imported
    They have cash on delivery in lahore
    I have tried it since i am not rich but if one of you guys can then order from this website and do give feedback about these importers
  10. #409
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Yar automotosport_lover kia ye liquimoly ka bike wala oil hay ya car wala
    As far as i know they do not import any other oil for bikes other than racing 4T 20w-50
  11. #410
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by SyedMoazzam View Post
    It's suitalble for bikes too, has no friction modifiers. Theres another semi synthetic 10w-40 with MoS2 tech and that has antifriction agents that can cause clutch slippage - price 1200rs.
    800 wala however is suitable
  12. #411
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    They are expensive. But no fraud.
    I bought a 9-cell laptop battery which i wasn't able to find in pakistan. They delivered in 15 days. My friend has also dealt with them.
    Getting fork oil will be piece of cake through them but price will be on higher side.
  13. #412
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    But for an enthusiast this website is a life saver
    Abobobily bro go for it
  14. #413
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    It's a heaven for those who are desperate
  15. #414
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    what kind of desperation?
  16. #415
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    @Automotorsport_Lover! Yaar Pakistan Oil, Haroon Oil & Filter House (Montgomery Road) sub se pata kar liya hay <_<
    And i did share my experience here as well ... in anger & frustration.
    Do let me know if you come to know any info about it.
    About importing stuff, lets get real. I ain't gonna bear the tension and money for this puny stuff. I am concerned it IS available in Pakistan but i just haven't found the right place to look for.
  17. #416
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Now all that is left is to contact the mafia to get you this stuff
  18. #417
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by amjad635 View Post
    well i did put Kixx back again and reconfirmed my doubts
    It's a shi* oil for GS clutch. Except this clutch issue, it's a fine oil in every way
    So bye bye to Kixx forever.
    Back to SGO for now. Will try some other oil at next oil change. Have Castrol Activ 4T in mind.
    Summary of different oils i tried in GS
    SGO: good oil for 600-700Km then it looses its viscosity.
    Havoline: good oil for barely 300-400Km i would say. Degrades very quickly.
    Kixx: Messes up the clutch of GS. In cold engine, behaves like you are putting gears without pressing clutch. Endurance very good compared to other local oils. Bike engine also feels silent and good.
    Zic 4T: Too thin, feels like there is water inside the engine instead of oil. Way too loud engine and somewhat jerky ride.
    AX-5: High possibility of getting fake. Inspite of being suspicious, i purchased and it was behaving just like any oil used more than 1000Km would do.
  19. #418
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Gull bhai i really admire the way you have shared your experience about all oils
    you have used and your reviews are 100% right and very reasonable
    i would recommend from now on you should never look back to these oils
    and thanks to your thoughts i am not going to also
    and yeah bro now should try castrol oils now
  20. #419
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Gull bhai this thing does not qualify as an engine oil
    It id 70% water and rest of it is something else
  21. #420
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    Yesterday after 2100kms running, I did the first oil change for Liqui Moly 4T 20W 50. The snap you can see below.
    Color darkens a bit and had more life still. I got it double check from two mechanics. They were saying that the oil still in good condition, in color and slippery as it should. He took some oil and rub between fingers and he was quite satisfied and surprised with the quality.
    But one of mechanic told me to change it any how. 2100 kms running in a bike is more than enough. Though he agreed that oil is still in good shape. But he was saying that it is due to your engine condition that it is clean better you should keep changing the oil at max 2000kms.
    In this case I also agree to that mechanic. Because the money I spent has been rewarded very well, my engine is saved, my ride become lot pleasant.
    Quote Originally Posted by abdulrehmanrauf View Post
    Today, the Liqui Moly 20W - 50 4T covered a mileage of 1200kms in my Sprinter. You can see the snap below for its condition at 1200 kms running.
    @1200 kms running
    Motorcycle Engine Oils -1276254
    @2100kms running
    Motorcycle Engine Oils -1284592
    Physically, the oil is still fresh and viscous. I also asked my mechanic to check oil condition and he was quite surprise by the quality of this oil even after 1200kms running. He was simply not hesitant in saying that you can easily and safely (with no risk) stretch this oil till 2000 or 2500 kms. Though the oil dealer claimed 4000kms but I am NOT taking the risk as per our traffic conditions.
    There are some other factors for me in getting this good conditioned oil. My Sprinter engine is cleaned Ma sha Allah say so it always used to give me oil in this color when I was changing the Castrol Active at 1000kms mark. Secondly Sprinter has oil filter so definitely it is cleaning the oil.
    My other PW fellows who are using LM, I would like to tell them please do not fully rely on my feedback. You should also provide your feedback especially one who owns bike withOUT oil filter like Honda or bikes with older engines.
    In the end, I have no issue in changing this oil at 2000 kms mark because then it will fully justified its price. 2000km @ 700Rs-(LM oil) is very much equal to 2000kms @ 570(260+260)Rs (Castrol Active).
    And its not just the price. With LM (even after 1200kms) you are getting a smooth, sound, vibration less ride. Soft gear shifting, no engine tiredness on long routes, no heating issue, greater pick, more fuel efficiency (I've observed extra 2-3 kms running per liter) , greater engine protection. And I think this is certainly not a 'Ghatay ka soda'.
    Again, the above is an honest feedback withOUT any exaggeration. I will be getting my second LM bottle soon because I'm very happy and I have no issue in spending 700Rs when I can get oils in just 260Rs.
    Best regards,
