Page 25 of 101 FirstFirst ... 1523242526273575 ... LastLast
Results 481 to 500 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #481
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    20w50/40 would work in winters..But the issue is cold start up is a pain in the butt..CD-100 has some cold starting issues like coughing etc..So i usually start the bike and let it idle for 10 minutes or so until it gets warm enough..I dont use choke much..In the mean time i eat my breakfast :p..
    A 10w40/50 is obviously a good choice for winters but keep in mind even a 20w50 is designed to instantly lubricate at engine crank for temperatures as low as -15 degrees..That is called pour point of an oil..Less than that oil tends to freeze..So even at 0 degress thicker oil will lubricate effectively..
    10w40 will decrease the warmup times though
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  3. #482
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    MashAllah you are taking an extreme of your bike and it is really great to see
    10 mintues is really long time for warm up of bike it must be drinking good
    patrol in this time i give only 10-20 seconds for warm up this may be shorter time
    but 10 minutes is long long time i think 1 mintue is more than enough for bike warm up
    and all internal parts of engine would easily get well lubricated and warmed up and ready to perform duty
  4. #483
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by devilskreed View Post
    that is long long time
    change to 10w40 and start parking the bike inside the room at night. I think coughing problem will almost go away.
  5. #484
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    If you eat your breakfast before starting the bike then you would not have to wait that long to warm it up
  6. #485
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Price update of Castrol GTX 20w-50 engine oil
    Price:430rs
    Motorcycle Engine Oils - esu8ypu6
    Motorcycle Engine Oils - ru6y9ena
  7. #486
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    last time its been less than month i bought it in 380 rupees
    how come this much huge sudden increase in price
  8. #487
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Quote Originally Posted by amjad635 View Post
    No idea brother.
  9. #488
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    Quote Originally Posted by gull_s_777 View Post
    having any trouble starting the bike or warming up with LM 20w50 in winter?????
    or just changing because it's winter now????
    just coz of winter ... first kick start at mrng
  10. #489
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    Quote Originally Posted by himmi_Pak View Post
    LM 20W50 is for summer but can be used in winter
    not recommended in jan /feb though
    LM synthetic 5W40 is more preferred or 10W40 .
    synthetic engine oil is always preferred over mineral oils ( in this case LM 20W50 is mineral oil)
    I just want to know ...k Minral oil sa synth oil par aany sa koi issue to ni ho ga.. i mean any clutch issue or something else.. coz mn LM product use krna chahta hon .... Q k ..i am fulllly satisfied with LM 20w50..... and right now problem is winter ..
  11. #490
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    @SyedMoazzam no sir they got oil addtive for Motor bikes as well as mention below
    @Eur0_2 sir how much km on the meter? if engine is new meaning not more
    than 6000 km then dont go for the process do it on 9000 KM
    and kindly go for the process under direct supervision and control of qualified mechanic
    Engine Flush:
    With time even the best engine oil deteriorates and contaminates the engine with gums and varnish deposits that a simple oil change just cannot remove. Any new oil may be compromised and be contaminated by deposits left behind.
    Extended service intervals are placing higher demands on today?s engine oils, making it now even more important to ensure that the new oil is given the optimum chance to protect the engine.
    Most engine flushes are solvent-type products, they tend to reduce the lubrication of the oil. If this type of flush is left in the engine too long mechanical damage can occur and engine seals can affected. Damage may not be visible but is irreversible.
    using the correct oil additive is neccessary for Engine flush so use LM oil additive with LM engine oil products onLY
    Motorcycle Engine Oils - 1657 200 100
    Racing Engine Flush
    Cleaning fluid for clearing the engine interior of troublesome deposits. Dissolves sludge and lacquer formers. All types of oil-soluble and oil-insoluble residues are brought into suspension and removed during the next oil change. An engine which has been cleaned of deposits and contamination and which is then filled with fresh oil not contaminated with old impurities can develop its full performance characteristics.
    Intended use
    Flushes out and cleans the oil circuits of motorcycles with fourstroke gasoline engines. The frequency of use is dependent on the degree of contamination of the oil circuit and on the quality of the oil used.
    how to use:
    One 30 ml is sufficient for up to 1 liters of oil. Add the additive to the engine oil at running temperature before changing the oil. After adding the product, allow the engine to idle for approx. 10 minutes. Then change the oil and the filter.
    the preferred one with MOS 2 anti friction
    Motorcycle Engine Oils - 1580 200 100
    Racing Bike-Oil Additiv
    With MoS2-anti-friction. Scientifically proved reduction in wear of up to 50 %. Therefore extends the service life of the engine. The engine runs more efficiently and reduces the oil and fuel consumption. Increases engine smoothness, fewer malfunctions. Tested for compatibility with catalytic-converters.
    Intended use
    Suitable for all 4-stroke and 2-stroke engines with separate lubrication. Can be used with wet multi-disc clutches. 125 ml is sufficient for 4 litres of engine oil.
    During each oil change, add 30 ml per litre of engine oil.
    on metr ....8500km
  12. #491
    sherry56's Avatar
    Apr 2008
    Rawalpindi
    205
    6 Post(s)
    Hi frnds a new question?
    which is best engine oil for Cg125 Euro 2,i had changed my first oil at 290kms and i used caltex havoline,i am 100% sure that it was original as my cousin is distributor of caltex engine oil and they get it directly from compnay's warehouse but i saw here on pakwheels people claiming that liquoy moli is better than havoline,
    Any advise from senior members?
  13. #492
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by sherry56 View Post
    Try Liqui Moly Racing 4t 20w40(german mineral oil)..COsts pkr 650 for 1L..Available at LM brand store in i 8 markaz...Drain interval 2k kmsfor 125 i think(if that is the recommended drain interval by honda)
    Lm is in an entirely different league..I have used caltex havoline 20w50..it is not great but does the job
  14. #493
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Unfortunately parking inside is impossible as the stairs are very steep and cd-100 is a notorious heavy MAJJ..But 10w40 is a good idea..Now the question is,,a good 10w40 premium oil is hard to find..zic is shizz
  15. #494
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by Eur0_2 View Post
    You can go for semi synthetic but not fully synthetic oil..If your engine is new then you can shift to fully synth oils but fully synth oils have a habit of leaking from engine seals.
  16. #495
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    a synthetic product of liqui moly is preffered over mineral one
    uk4455 posted a pic back in posts to see the diff
    the synthetic engine oil keeps engine smoother and keeps on optimum lubrication
    if u see that pic u can see smoother flow of fluid across engine parts
    kiqui moly products are of superior quality
    if u r satisfied with LM 20 W50 then in winters im dead sure u will be double satisfied from 5w40 and 10W40 synthetic one;s
    becoz they are design to meet winter requirement while 20w50 for summer
    please refer to post 449 in this topic for understanding
    temp and engine oil
  17. #496
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    did u try one? and did happen with u???
    then why synthetic engine oil is made for then if they start leaking from seal
    if u doesnt give time to engine idle then seal leaks in winter
  18. #497
    125rider's Avatar
    Aug 2013
    81
    2 Post(s)
    Quote Originally Posted by ahsan95 View Post
    Price:430rs
    Price: Rs. 400 in Faisalabad
  19. #498
    sherry56's Avatar
    Apr 2008
    Rawalpindi
    205
    6 Post(s)
    Thanx for the advice, as its winter now so shud I use Lm 20w50 or 10w40, however I saw that most members here recommend 20w50
    As my bike is new, just 400 km done so I dont want to do experiments on it for now :-p.
  20. #499
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Where's the liqui moly shop in Faisalabad? And what are its timings (opening/closing)?
    Sent from my Nexus 4 using Tapatalk 2
    ChipLoco.com | Anything and everything from the tech world!
  21. #500
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    post 449 will answer ur query in detail
    20w50 is for summer 10w40 or 5w40 is recommended in winters
    Thanx for the advice, as its winter now so shud I use Lm 20w50 or 10w40, however I saw that most members here recommend 20w50As my bike is new, just 400 km done so I dont want to do experiments on it for now :-p.
