Page 30 of 101 FirstFirst ... 2028293031324080 ... LastLast
Results 581 to 600 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #581
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    Quote Originally Posted by SyedMoazzam View Post
    Kixx is also a good option bro @moons has been using it in his GS150 and he has not complained
    Bhai Kixx is also not available at every oil shop.
  3. #582
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    facing a little problem with engine oil relevant so thought to ask the experts out
    bike is been leaking engine oil in drop form ,from the drain point of engine oil (screw that act as cap)
    it been taken out to mechanic and it tightly sealed
    but daily when i check there are engine oil drops equal to 2-3coins in size drop on ground(making a brown / black spot)
    on the dip stick the level is fine
    but not feeling good about the leak , havn't face any issue in 13880 km before
    what are your suggestion and guidline?
  4. #583
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Change the nut and the washer
  5. #584
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    oil will be drained in some bottle ?
    can we refill the same engine oil back
  6. #585
    Mindless's Avatar
    May 2012
    18
    Sent from my Radar C110e using Tapatalk
  7. #586
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Quote Originally Posted by himmi_Pak View Post
    Yes you can.Drain it in a clean container change the washer/nut and then pour it back in..No issues
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  8. #587
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    It is advised not to put the dirty oil back into the engine but let's see what experts have to say @vickytulla please guide him
  9. #588
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    If oil hasnt aged yet, and from color, smell, and viscosty it feels to put few hundred kilometers more then you can keep it in bottle but if its already smelling like baked potatos and is totally black use new one..
    For the leakage problem visit some good mechnic who can properly tight the screw and check if the O ring is inits shape and not worn off. Dont go to hathora mechnic or the will slip the Bolt and then whole engien will be openend..
  10. #589
    moons's Avatar
    Apr 2013
    33
    1,487
    39 Post(s)
    4 Thread(s)
    @mtmoghul bro use castrol if u cant find kixx if castrol is also not available, then get total from a good reputable petrol pump
  11. #590
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    just 150 km driven with new oil , recently oil change and tunning.doesnt drive bike much in winter
    color is as good as new as do the viscosity , havent smell (its havoline)
    the mechanic tighten with the same O shape driver.and its correctly tight
    will check for morning if any leakage then will go to mechanic. i dont like hathoras mechanic too
    the dipstick shows full engine oil level.
    i have castrol activ bottle spare will use it if case needed
    Quote Originally Posted by vickytulla View Post
    Quote Originally Posted by devilskreed View Post
  12. #591
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Yar once m mechanic drained my LM oil which had clocked only 200 kilometers..I was like WTH ,,got it poured back .The guy thought the gear oil i brought alongside was engine oil .As long as the container is clean you can pour it back no problems.
    but you should always stock a 1L top up oil pack for emergencies.
    For small oil drops you wont observe any sharp change in oil levels but for a drain on 20 ml and above the dipstick clearly exhibits oil drop.
  13. #592
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    throughly check and discover there is no more leakage - problem solved - thanks all
  14. #593
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Ravi Advance 4T Engine Oil 20w50 By Ravi Motorcycles
    Motorcycle Engine Oils -1304762
    Motorcycle Engine Oils -1304763
    RAVI 4T ADVANCE Engine Oil
    PREMIUM QUALITY
    Excellent Driving Performance
    Quick Starts on Cold Mornings
    Maximizes Fuel Economy
    Recommended Engine Oil for all Motorcycles
    Introductory Price: Rs. 260/-
  15. #594
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    I am not sure about this but looking at packing & price i guess they are getting this oil from Castrol
  16. #595
    dr.omair's Avatar
    Aug 2010
    31
    583
    224 Post(s)
    9 Thread(s)
    Alrite people!!!!!
    Today i finally poured liquimoly 20w50 in my gs150 2011 which had clocked 9800 km so far....
    The results were so amazing that i still cant believe that a good quality oil can make such a huge difference..... Honestly, I was expecting some minor improvements in performance that would go unnoticed by a non technical person such as myself
    To begin with, I was a little bored with my post graduation studies, so decided to take a break my doing the oil change myself... I had already purchased 2 bottles of LM when i last went to old town for a discount
    Anyways, I poured in the yellow colored oil(looks like sarso ka tayl unlike the maroonish havoline) and got myself, my bike and the garage dirty because of my inexperience when opening the drain bolt
    i didnt drop LM as it came with an easy to pour nozzle
    To clean all the mess, I gave my bike a long and tiring detailing session
    I was so tired in the end that i forgot much about the new oil and went to sleep
    Woke up in the evening for work
    I drove my bike slowly for a while until i was on main multan road and this is when i realized how ignorant i was for not trying LM earlier
    the bike ran 30?40% smoother, gear shifting was effortless and the bike was alot quieter even at higher rpms
    I honestly believe LM should be compulsory for all gs150 riders
  17. #596
    mansor's Avatar
    Jul 2010
    33
    561
    6 Post(s)
    Quote Originally Posted by amjad635 View Post
    PREMIUM QUALITY
    i think kay ya shell say banwa rahay hai oil
    quality to tekh ho gee i guess
  18. #597
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    ok here is a question can we put 1 litre engine oil in cd 70cc ?
    or 0.7 litre firmly and preciesly ?
  19. #598
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Sir 0.7 liter exact.
    "Imagination is more important than knowledge"
  20. #599
    dr.omair's Avatar
    Aug 2010
    31
    583
    224 Post(s)
    9 Thread(s)
    If its a question of CAN I..... Then yes u can
    If its a question of SHOULD I..... Then a big no....
    The company has specified the desired amount for a reason..... It will create extra pressure in side the engine and damage the valves
  21. #600
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by dr.omair View Post
    The excess will burn off creating carbon, and cause oil seal leaks.
