Page 46 of 101 FirstFirst ... 3644454647485696 ... LastLast
Results 901 to 920 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #901
    flluffmaster's Avatar
    Feb 2011
    40
    viscosity is the second most important and relevant variable when analyzing the performance of an oil. whereas exact viscosity as measured and expressed in centistokes may not be very handy,,,relative viscosity can be conveniently measured by a home made cup .The Ford viscosity cup is a simple gravity device that permits the timed flow of a known volume of liquid passing through an opening located at the bottom. Under ideal conditions, this rate of flow would be proportional to the kinematic viscosity (expressed in stokes and centistokes) that is dependent upon the specific gravity of the draining liquid.this would give ample idea of what is going on with oil after 500,1000 and more kilometers.Motorcycle Engine Oils -1342213
  3. #902
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Quote Originally Posted by isb_rider View Post
    Liqui moli wasn't available in blue area last month (now its available) so i went to i-8 isb to purchase oil, There dealer charged me 700rs and said price have been increased , update about your area in which price you are getting ?
    Secondly both liqui moli oil dealers i met always say that liqui moli can go upto 2500 to 3000 kms, while i dont go beyond 2000kms,so on how many km's you are changing ?
    and last thing i-8 dealer told me that cd-100 require 800ml not 750
    CD-100 requires 750ml oil quantity..I usually buy 3 packs as they last for 4 oil changes.Hmm you should not exceed 2000Kms on LM..i drain it at 1500
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  4. #903
    isb_rider's Avatar
    Jun 2013
    25
    82
    Thanks for your reply^
  5. #904
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Anybody checked if LM is available at Khan motors(Karachi) . Last time I visited they didn't have it.
    In anybody has their no. Pleas pm it to me.
    Thanks.
  6. #905
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Quote Originally Posted by ahsan95 View Post
    Thanks.
    I also went to shamsi oil trader as suggested by @camry47 bro but they said it was short in market and will be available after 22 jan.
  7. #906
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    No liquimoly at Khan motors.
    Any other place?
  8. #907
    tahirahmad13's Avatar
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    Quote Originally Posted by devilskreed View Post
    What about pridor's engine oil capacity? A Honda 1S service station is near us and they put 1 ltr in pridor. The chief mechanic showed me his CD hundred and told that he was putting one litre in it for last five years and that much oil kept engine 'thanda'! However I didn't let him put more than 800 ml. But people at another 3s centre told that it was allright.
    Sent from my A10 using PW Forums mobile app
  9. #908
    waqasashraf's Avatar
    Mar 2013
    242
    4 Post(s)
    Wich one is for CD70 ?
    (Havoline 20w40 0.7lt OR
    Havoline 20w50 1.0lt)
  10. #909
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    From my side please give a great salute to that cheap mechanic.
    On a serious note, no one know knows about the daily running of mechanics bike, no one knows how many times he repaired his engine or replaced the seals, packing.
    We should keep away deliberate miseries from our already miserable lives.
    Quote Originally Posted by tahirahmad13 View Post
  11. #910
    Oct 2009
    33
    771
    31 Post(s)
    These days I and many others have observed that Havoline only lasts good for 500kms or so.
    You should go for either Castrol Active or ZIC 20W-40 grade.
    Quote Originally Posted by waqasashraf View Post
  12. #911
    atifkh74's Avatar
    Nov 2010
    75
    Any other place?
    Dear Ahsan,
    If you can go to Mukka Chowk (Azizabad), there is a shop, Al-hamd Autos. They have a wide range of LM. I took a pack of Liqui Moly Racing 4T from there, last saturday.
  13. #912
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    because its 2 number and vastly avail in market
    i suffer clucth slip due to it
    Quote Originally Posted by abdulrehmanrauf View Post
  14. #913
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    for CD 70 go for kixxx 20w50 0.7 ML
    or
    shell AX-5 15w40 0.7ml
    or Castrol Activ 20w50 0.7ml
  15. #914
    Mar 2013
    242
    4 Post(s)
    Quote Originally Posted by himmi_Pak View Post
    or
    Bought HAVOLINE 20W40 today.
    INSHA ALLAH next time try another.
  16. #915
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    for your engine safety and bike performance
    keep a eye on engine oil color n smell.
    if you feel a little stink dont waste a min to change the oil
    at start it will perform like normal but after 300-500 km onwards it will start causing issues
    so better watch out for that
    i hope n wish you bought the genuine one then there is no issue uptill 1000 km
  17. #916
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Quote Originally Posted by atifkh74 View Post
    Dear Ahsan,
    For how much did you get it?
    I checked khan motors again. They quoted 1050 rs. I wanted to give the person a slap. Then I gave him a reference he quoted me 900rs. I didn't buy since that was even too much.
  18. #917
    Mar 2013
    242
    4 Post(s)
    Thanks for a good advice.
    i'll be carefull in future.
  19. #918
    atifkh74's Avatar
    Nov 2010
    75
    He was asking 750/- but I bought it in 700/-.
    The shopkeeper told me that this lot of LM has been arrived in the market after a long time. That is why the prices are bit high. 900 is too much.
    One thing I have noticed that after pouring LM, engine doesn't make funny noises which It was used to, while having SGO (may be because LM's high viscosity). One more observation is, in the morning, when applying the first gear (only for first time) , the clutch slips. I don't know why its happening but it was not there when SGO was in place.
  20. #919
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Changed oil and oil filter of my gs150 today. Took LM to 3000km and it worked A1 till the last second but this was its last limit.
    "Imagination is more important than knowledge"
  21. #920
    sherry56's Avatar
    Apr 2008
    Rawalpindi
    205
    6 Post(s)
    Aoa frnds
    I was using lm in my 125 euro 2 and it was ok but last time I tried again caltex and it was a really bad experience as I suffered alot frm clutch slip problem.
    Any other oil recomended by u guys expect lm and caltex coz I wana try new oil but it shud b fine for my bike.
    Sent from my GT-I9100P using PW Forums mobile app
