Page 51 of 101 FirstFirst ... 41495051525361 ... LastLast
Results 1,001 to 1,020 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #1001
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    @amjad635, yes Bro you are right ZIC is not good. I have also had bad experince with ZIC 4T in my Raider 110. I switched from GTX to ZIC but its not good. Engine smoothness gone plus engine producing more heat. GTX was better. Next time Inshallah in a day or two I will drain it change with GTX or any other. What about Havoline ?
    Quote Originally Posted by amjad635 View Post
    As its winter so i thought its good time to give a one more try to Zic 4t 10w40
    most of us here don't have very good experience with this oil in Summer
    and i guess its reason was being thinner oil but i think Zic has finally listened to the complain
    and criticism on their product and there is now 20w40 also available from Zic today i bought the Zic 10w40
    as its winter so i thought lets try one more time Zic 10w40 so that is why i chose 10w40
    My bike manufacture recommends to use 20w40 as its all rounder in pakistani conditions
    and no doubt it does work very good and now its good to have 20w40 from Zic also
    Price told by shopkeeper to me today
    Zic 10w40 = 400
    Zic 20w40 = 380
    Motorcycle Engine Oils -1337813
    First ride experience after changing oil its ok ride unfortunate i did not give attention to engine idle
    sound while it was filled with AHl oil but it do certainly feel engine is bit noisy at idle would have been 100%
    sure to tell if i had given some attention to engine sound before switching to Zic but clearly feel its slightly noisy
    baaqi in riding it bike seems smooth as it just has gotten fresh oil will share further experience and update
    this post after riding it for more km's quality wise Zic oils does seems good inshAllah in future will give try to Zic 20w40
    Final Experience About Zic 10w40 Again Disappointed
    Here it is my final experience about this Zic oil again i am very disappointed
    my first ride after changing oil was just 3km drive to my home but in the evening took
    out my bike and went on to check performance of bike i am disappointed with the response of bike
    i checked the acceleration of bike and dragged gears simply i am quite clearly noticing the difference in ride
    when AHl 20w40 API SG oil was in bike its ride was better excellent acceleration and overall response from bike
    was great but now with Zic 10w40 API SJ i can feel its not performing to its best my bike is excellently tuned by mechanic
    and these days its been performing to its best peak performance
    This is going to be quickest change of my bike just 10km
    and these are enough for me to decide AHl 20w40 is definitely better choice as compare to this Zic oil
    from now on its big No to Zic's this particular oil we know how it performs worst in summer but i am not
    satisfied with its performance even in winter obviously i did not feel heat issue i have not went on long drive
    but i guess there would be no issue of heat in winter i felt no extra engine heat from bike its perfect
    but i did not like the performance of bike with this oil and luckily its great time to check engine oil as i said above
    my bike is an perfect mode and it clearly has liked AHl oil more and did not like this ZIc 10w40
    InshAllah tomorrow will drain this oil and go back to AHl 20w40 baaqi in future inshAllah will give try to Zic 20w40
    at this time i can't take risk again to try Zic no matter its 20w40
    15th Jan: Today Drained Oil Switched Back To AHl 20w40
    So today morning went and drained Zic oil believe me guys this is the first time ever
    i have felt this much difference between two local oils we know those who have tried LM
    how much immediate difference we feel in ride but this first time ever i am feeling this much
    difference between two local engine oils this Zic oil highly un recommended from my side to anyone who
    is using in pridor or i will say in any bike specially honda bikes you guys must be little bit confused
    as i have above mentioned quality wise Zic oils does seems good well that i was referring to originality of
    product but performance wise it has really performed poor in my bike and this was the quickest oil change of
    my history just at 10km believe engine was not performing as it should it was not generating the acceleration
    and power which it is now performing when i have again shifted back to AHl oil now things are pretty clear
    for me i am 100% sure about difference in ride when there was Zic in bike definitely with AHl oil
    my bikes overall ride is much better and its performing very good with this oil as it should
    i have tried other engine oils also in my bike as shell & castrol but this was comparison test between
    AHl oil and Zic 10w40 and i can say other oils have performed good also but Zic is clearly spotted as culprit
    in my bike pridor 100
  3. #1002
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    mtmoghul brother you have not faced any different experience than most of pw fellows
    its almost the same experience any one who have used zic 10w40 in their bikes @ pakwheels
    and i personally had very bad experience with Zic 10w40 recently in even in winter
    Zic engine oils quality wise seems good i was very surprised with its terrible performance
    but as we had been complaining the reason behind Zic worst performance was its low viscosity grade
    means its thinner oil
    Zic has now launched Zic 4t 20w40 its been quite good time to its launch
    and i just around week ago gave try to this oil and i am very satisfied with its
    performance so far its working really good and i immediately felt difference
    in gear shifts as switched this oil and overall bikes ride is very good smooth
    But still its quite surprising that who ever used Zic 10w40 felt same bad experience
    And there is nothing wrong in using latest grade or specification engine oils
    in my pridor 100 its written use API SF/SG but along side that also mentioned OR higher grade
    however some one should fear using advance synthetic engine oils in bike as our bikes quite old tech
    it is said regarding advance full synthetic engine oils are meant for latest engines only
  4. #1003
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Quote Originally Posted by ilovecars2 View Post
    Is Liqui Moly 20w50 is good for dhoom 70cc and other 70cc bikes ?
    Yes yes its good. I'm using it in my 70 as well. Par ye apko mehnga parega kyuk ye sirf 1L ki packing me ata ha. No other problem.
    "Imagination is more important than knowledge"
  5. #1004
    Farhansa's Avatar
    Oct 2006
    8,715
    5
    84 Post(s)
    How is castrol.oil for bikes?
    Sent from my LT29i using PW Forums mobile app
  6. #1005
    ilovecars2's Avatar
    Jan 2014
    80
    Quote Originally Posted by Haji__John View Post
    Thanks brother and what is Liqui Moly 1-litre cost nowaday in karachi.
  7. #1006
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    no idea about karachi here in isb its 700
  8. #1007
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Lhr me ek dealer se pucha us ne to 1200 rs quote kie the for 1L LM Oil.
    I Am the Feel
    I Am The Yamaha!
  9. #1008
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    not more than 750 PKR
    Quote Originally Posted by N0m1 View Post
  10. #1009
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    castrol Activ 4T 20w50 is awesome as per my test on my 70cc
    infact in bikes category in castrol oils it is the best avail here in pakistan
    Quote Originally Posted by Farhansa View Post
  11. #1010
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Quote Originally Posted by himmi_Pak View Post
    lgta he main mamu bann gya.
    I Am the Feel
    I Am The Yamaha!
  12. #1011
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Nothing beats LM..My experience..
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  13. #1012
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Quote Originally Posted by devilskreed View Post
    It's everyone's experience
  14. #1013
    tahirahmad13's Avatar
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    Even in cars' category Castrol is far far better than many local competitors. I personally am fan of Castrol Magnetic for cars. I want to use Castrol active for my pridor but using Honda oil due to warranty compulsions!!
    Sent from my A10 using PW Forums mobile app
  15. #1014
    gemini85's Avatar
    Jun 2011
    Rawalpindi
    1,115
    15 Post(s)
    2 Thread(s)
    which oil is good for bicycle chain, gears and shocks.
    Man's heart away from nature becomes hard.
  16. #1015
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    @amjad635 yes, Zic has disappointed me. I think Zic is over rated oil in the market. Hope that this new Zic grade i.e. 20w-40 proved to be best oil.
    Now for the time being I am thinking to use Caltex havoline 20w-40 which is of API SG grade.
  17. #1016
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Quote Originally Posted by gemini85 View Post
    SAE-90 Gear Oil for chain lubrication.
  18. #1017
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Which oil is best for motorcycle foam air filters lubrication?
  19. #1018
    ilovecars2's Avatar
    Jan 2014
    80
    Liqui Moly costs 800rps- 1Litre in karachi, bought today from Hamd Autos.
  20. #1019
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    @Automotorsport_Lover ! Brother, any idea about the on-going price of Liqui Moly 4T?
    Riders on the storm ... literally.
  21. #1020
    ahsan95's Avatar
    Aug 2012
    996
    46 Post(s)
    Any Change in packing?
    New shipment arrived so maybe new packing.
    Btw where is Hamd Autos?
