Page 70 of 101 FirstFirst ... 2060686970717280 ... LastLast
Results 1,381 to 1,400 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #1381
    nasirjavaid's Avatar
    Jul 2013
    3,083
    8
    77 Post(s)
    Quote Originally Posted by abdulrehmanrauf View Post
    What indications you are seeing in your bike now that you are telling that LM is not what it was used to be. Please give some details.
    You said oli feels like water. What other indications may be? I plus many others would be interested in knowing the details.
    Other indications include the engine noise. My connecting rods and timing chain are loose and produce some noise. First week after pouring LM the sound was vanished but engine felt little heavy to rev as something quite thick is inside engine. after 15 days there was again sufficient noise that I suspected oil level has dropped. So I opened oil screw to level up but it was up to full mark. Couple of days ago sound increased so that I again had to check the level but again it was full but when poured some drops to ground and checked between finger and thumb it felt like some thin machine oil
  3. #1382
    Jul 2013
    3,083
    8
    77 Post(s)
    Only caltex 20w40 used to get this thin when i was using it previously and oil level used to drop after 2-3 weeks. then switched to shell 20w50 and it was good and oil level wasn't dropping till 1-1.5 months. With LM level is not dropping but feels thin.
  4. #1383
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    Quote Originally Posted by nasirjavaid View Post
    can you please tell me its price and is it 1 litre or .7 litre?
    Ita came both on 1 L and 0.7L
    1 L price is around 440
  5. #1384
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    yes only caltex turn into water after just 500 km.
  6. #1385
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Quote Originally Posted by Horse_rider View Post
    A bit offtopic but important, I am new to bike, want to know about the chain wax/grease. I have searched the whole market of RWP/ISB but no one even knows. at international online stores there is a brand maxima chain wax which is suitable and best for bike chains, but from where to find it here in pakistan, and do any other alternatives exist to chain wax?
    please help
    Sir I too am from rawalpindi and till last I was searching that as well but gave up. I couldn't find it anywhere. The only hope is in lahore and karachi.
    "Imagination is more important than knowledge"
  7. #1386
    asm35's Avatar
    Oct 2010
    Rawalpindi
    10
    please help
    LIQUIMOLY chain spray is available and also CRC brand in rawalpindi.
  8. #1387
    aaqil30's Avatar
    Dec 2013
    Rawalpindi
    20
    243
    2 Post(s)
    Sir 4th gear bilkul bhet gya tha. Bike heavy chul ra tha. Load le ra tha. Fuel b bhaut kha ra tha. M n spark plug badla. Spark plig adapter badla. 1 mahinay m 3 tuning krwai. Tappet set krway. Rpm ki tar mei s oil drip ho ra tha. Sub kch kraya kch fark ni para. After 600km of use i changed liqui moly to havoline. And everything went back to normal. Power was back. Liqui moly n hud s buri performance di is dafa. Havoline dal k sub set hogya. Nd did a 4th tuning in one month. The thing is that meray s shuki admi shaid koi ho hi na. Aik aik chiz i notice but it felt like of i kept on using liqui moly more the engine wont be the same. Very bad oil. And ive used the oil 8 times. First 4 great. Last 3 bad and the last one the worst. Every mechanic recommends havoline from which i get checked.
  9. #1388
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Castrol active 4t 20w50 is even better then havoline. Though castrol active 4t 20w40 is not as great.
    My first choice castrol active 4t 20w50 second choice shell ax5 third is caltex havoline 20w50
    My experience.
    Sent from my GT-I9300 using Tapatalk
  10. #1389
    valvoline's Avatar
    Oct 2014
    88
    11 Post(s)
    Valvoline Champ 4T motor cycle oil available in Pakistan. See www.valvoline.pk for more details or facebook.com/valvoline.pakistan
    Motorcycle Engine Oils -1496467
  11. 01-11-2014, 02:16 PM
    PakWheeler
  12. #1390
    Jul 2013
    3,083
    8
    77 Post(s)
    Quote Originally Posted by omer.s View Post
    Thanks bro.. Price looks great if quality is good.
  13. #1391
    Jul 2013
    3,083
    8
    77 Post(s)
    Quote Originally Posted by asjdsm View Post
    My experience.
    Please also share prices. Maybe next time I go for one of these.
  14. #1392
    gemini85's Avatar
    Jun 2011
    Rawalpindi
    1,115
    15 Post(s)
    2 Thread(s)
    Quote Originally Posted by asm35 View Post
    From where we can get lm chain spray
    Sent from my IM-A850S using Tapatalk
    Man's heart away from nature becomes hard.
  15. #1393
    bike_junky's Avatar
    Feb 2008
    766
    17 Post(s)
    Quote Originally Posted by valvoline View Post
    Valvoline Champ 4T motor cycle oil available in Pakistan. See Valvoline Pakistan Karachi- valvoline.pk for more details or facebook.com/valvoline.pakistan
    Shouldn't it also be available in 1 liter packing, and from where we can get the rates.
  16. #1394
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by bike_junky View Post
    Currently its not available in 1 liter packing. But their sales officer said tgey will launch 1 liter packing after 3 to 4 months.right now only 0.7L is available. Now if you are from karachi then you can directly access their main outlet in korangi industrial area. For address i have posted it in this thread just a few days back. Like 2 3 days back
    It is Easy to hate But Love is More Powerful...
  17. #1395
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    @valvoline half hearted launch wont take you anywhere.Firstly you have introduced only 0.7 liter packs,which exhibits you are targeting the chonda market.Peeps with 100/125/150 cc motorcycles have no option..P.s you dealership is in KHI and you have no presence in punjab atm..Increase your dealership network,streamline you products and introduce 1L PACKS aswell..
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  18. #1396
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Champ 4t IS available in 1L packs.. ki gal karday o.
    Sent from my LG-F160K using PW Forums mobile app
  19. #1397
    bhatti007's Avatar
    Dec 2013
    21
    257
    6 Post(s)
    Which engine oil is best for cg zic or lm?
    speed + vibration= cg125
  20. 03-11-2014, 07:46 PM
    PakWheeler
  21. 03-11-2014, 07:48 PM
    PakWheeler
  22. 03-11-2014, 07:59 PM
    PakWheeler
  23. 03-11-2014, 08:07 PM
    PakWheeler
  24. #1398
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    Quote Originally Posted by bhatti007 View Post
    Kixx and zic is necessety and LiquiMoly is luxury :-P
  25. #1399
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    @bhatti007 complete first 2k kms with ahl oil,,then pour in lm 20w50..CG has a poerful engine and LM complements its best.
  26. #1400
    munnapk89's Avatar
    Feb 2012
    Rawalpindi
    122
    6 Post(s)
    Yesterday, I bought PETRO GULF SUPER PG 400 (SAE: 20W-50). 3 litre Bottle for PKR 980/-. Packing claims to be Made in U.A.E. And is for both Gasoline and Diesel Engines. Smells and looks quite better.
    One of the most experienced 2-Stroke mechanics in Rawalpindi has been using this oil in 2-strokes for years.
    Will be using it both as Motor Oil and as Transmission Oil. Will post experience/results after a few days..
    For those who dare, the future is in skies ...
