Page 83 of 101 FirstFirst ... 3373818283848593 ... LastLast
Results 1,641 to 1,660 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #1641
    qasimjamil's Avatar
    May 2007
    35
    156
    Quote Originally Posted by gull_s_777 View Post
    In 20W-40, not many choices are there i think. It's either Zic 4T or Total 4T and i have good experience with both of them in my GS.
    There is atlas honda genuine oil too.
    But now i am quitting Zic as it's gone API SL now, and these new grades come with less amount of some critical additives necessary for protection of old design engines like ours. I will be using Total most probably from now on.
    My Advice: Use SL only if manual calls for it. Else best stick to SF/SG grades.
    Anyway CG goes happy with 20W-50 too. It's the Suzuki bikes which give a little nakhra on thickish oils.
    Here is piece from "Motor Oil" Article from wikipedia. A must read before you go putting SL in your ancient technology bikes.
    Ok thanks bro
  3. #1642
    moons's Avatar
    Apr 2013
    33
    1,487
    39 Post(s)
    4 Thread(s)
    free mashwarey denay walay log...
    i was asking which oil do you get suggested most outside the "pakwheels biker section" (aka in real world)
    Oh acha acha.Gull bhai ab km hi miltey hen free mashwrey coz bike is now almost 2 yrs old and "Mashwry deney wala" might think,it would better to give opinion to a new GS user.BTW, I have met a GS owner a couples of weeks b4 who had been using Liquy moly 10w40(synthetic) with some titanium in it for Rs.1850/ltr only and he told that this oil is good for 4000 kms.ME TU ITNEY MUSHKIL WORDS SUN K HI DAR GYA and thought "APNA TOTAL E THEEK AE.
  4. #1643
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by moons View Post
    haha
    Anyway, even if i had some super oil, i won't be comfortable using it for more than 2000Km in my bike. Because oil's job isn't only to lubricate but to keep the engine clean as well. And by 2000Km, i think it's full of enough deposits that it should be out and replaced with fresh clean oil.
  5. #1644
    786apps's Avatar
    Dec 2014
    35
    Quote Originally Posted by mikegd110s View Post
    salam guyz.
    two days beforre i have changed oil in my new bike gd 110s.zic m7 10w 40
    vibration incresed???
    its in 740 km.1st time i changed oil at 220km than 700 km both time i am using zic 10w 40sj
    but this time i am using Sl grade with new packing off zic oil.
    any idea?
    thanks
    API SF/SG is recommended in mannual of gd110 therfore its better to avoid SL grade
  6. #1645
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    So couldnt get my hands on LM today and bike badly needed a tune up,so got Zic 4T semisynthetic VHVI one the silver bottle with blue sticker.Lets see how the oil fares.
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  7. #1646
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    Quote Originally Posted by devilskreed View Post
    Yestarday I changed the oli of my bike also to LM formula super 20-50 from i-8 markaz and they have many bottles of street4t available in 10-40 and 20-50 there u can go there for buying LM.
    By the way from where u buy LM products as u r in rwp.
  8. #1647
    devilslayer's Avatar
    Jun 2009
    2,480
    21 Post(s)
    ok... i went through all 83 pages and em more confused. usin Havoline in my bike since day first and bike is nw 13K driven, a time came in this thread when i wz 100% convinced that LM is the best oil and i shud change frm Havoline to LM bt as the thread passes more n more oils jumped in like Kixx, Valvoline ZIC and some othr Spanish Arabic etc etc brands, So nw em totally confused, Should i srtikc to Havoline or change it to LM or any other and i dn wana do any experiments?? Sincere Advice needed here plz, btw i dn use buke mch, like 20/30Km max in a Week or so
    wHaTs NeXt To EcStAsY????nOtHiNgNeSs??WaTs nExt????HELL.............
  9. #1648
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Use LM and be tension free
    "Imagination is more important than knowledge"
  10. #1649
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Quote Originally Posted by altisdualvvti View Post
    Meray bhai i used to study at NUST,it was easy for me buying a few bottles from i8 as the distance was minimal.I reside in pindi bahria town so cant go to I8 markaz for lube.Thereis a LM shop in GT road Pearl Lube which has complete LM inventory.It was closed on friday and i didnt want to w8 so bought Zic instead.
  11. #1650
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Quote Originally Posted by devilslayer View Post
    Bike make/model?
    LM is the best option
  12. #1651
    May 2012
    21
    1,966
    42 Post(s)
    OK bro I see
  13. #1652
    May 2012
    21
    1,966
    42 Post(s)
    How's your zic going and which oli grade u brought and plz a little comparison with LM
  14. #1653
    May 2012
    21
    1,966
    42 Post(s)
    OK guys this question just popped in my mind 4 days ago I went for tuning my bike and the mechanic said that as bike is driven 8000+km so it requries carberator cleaning but as I read sone where on PW that if the bike is going fine than there's no need of opening carb but the mechanic was insisting me to do carb cleaning but I said no to him and said him to do other things which r included in tuning and after he did I came home and searched about carb cleaners and found 2 common brands for carb cleaners one is liquimoly and the other is STP but as I never experienced any of these products so can anyone tell me that is it worth purchasing it and does it works as liquimoly sites says that u can pour this cleaner into petrol tank and it cleans the carb.also tell me about prices of both and which one to use.
  15. #1654
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Actually its very difficult to say as the bike has clocked only 25kms on new oil(Zic 4T semi synth 20w40).Gear shifting is smooth,what i am more interested in is the bikes performance after it crosses the 700 km mark as most of the oils degrade by 50% at this range and shear down from 20w40 to 20w30.
    LM maintains its viscosity for 1000+ kms.One can easily stretch it till 1.5k kms
    On the other hand engine starts whining on local oils after 800,the smoothness vanishes and the engine is begging for an oil change.That was the case with AHL oil.
    For CG/125 cc bikes LM is by far the best choice.
    For GS 150/GD 110 LM 10w40 semi synthetic
    For 70cc bikes any 20w40 oil to be drained before 1000kms( i dont have much experience with locals as my bike was on LM)
    Pridor and other 100cc bikes LM is great,locals can be used as replacement.
    Also note that LM is a thick oil(true 20w50 on paper),it offers protection at the expense of acceleration/speed as compare to local 20w50/20w40 oils and one might feel that the bike is heavy or is not quick enough as compared to 10w40.So its up to the user to decide whether he aims for performance or protection.
    Those interested in performance 10w40
    Those interested in protection 20w50
  16. #1655
    umerchaudhary's Avatar
    Apr 2007
    32
    1,203
    4 Post(s)
    2 Thread(s)
    In 70cc bikes 20 w 50 grade oil good for new bikes or old bikes ? And if in old bikes suggest mileage ( mean to say bike kitna runing kar chuke ho ? )
  17. #1656
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Quote Originally Posted by umerchaudhary View Post
    In 70cc bikes 20-50 grade oil good for new bikes or old bikes ?
    20w50 is a great choice for old bikes but a word of caution.If someone has clocked 40k kms on 20w50 and he then pours a 10w40 bike will emit smoke and it would be detrimental for engine
  18. #1657
    Apr 2007
    32
    1,203
    4 Post(s)
    2 Thread(s)
    @devilskreed thanks. So but if we use 20w50 in new bikes is it bad for bike ? If yes how extent.
  19. #1658
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    No its the other way around.Its the usual practice which people do in cars.They use the standard recommended grade advised by the manufacturer.Like 10w40 for honda civic ex 98 afther clocking 100k kms people switch to 20w50 to retain the old engine.The problem is if a car starts emitting smoke using a higher grade oil helps in reducing smoke/maintaining pressure in the combustion chamber,prevents blowback and helps seal the rings(prevents gap)..
    As our motorcycles have single cylinder blocks,the chamber is not intricate so its better to use a relatively thick oil which helps in protecting engine from wear and tear.Oil has to work 4 times more in bikes as compared to cars so a thick oil is better as it degrades slowly.
    One more thing to add is that oil drain interval depends on 3 variables.The number of miles clocked,number of month oil stays in the block and last but not the least your driving style agressive/calm.LM 20w50 in CG 125 if ra**d like hell would loose viscosity at 1.1k kms but the same oil if driven with care can easily last upto 1.6/1.7k kms.Oil should be drained earlier than usual in summers/withing city commutes with frequent stops.
  20. #1659
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    LM motorcycle carb cleaner is not available in Pakistan.I got my carby cleaned at 14k kms.If the bike is giving good avg no need for cleaning.Install an inline fuel filter .
  21. #1660
    Farhansa's Avatar
    Oct 2006
    8,715
    5
    84 Post(s)
    R u facing any issue with havoline?
    Why u want to change brand?
