Page 85 of 101 FirstFirst ... 3575838485868795 ... LastLast
Results 1,681 to 1,700 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #1681
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by ibrarshah1979 View Post
    AOA
    All my brothers im destroying many new bikes engine in experiments of different bike engine oils in light of my experience do not use any other oil grade like API SJ SL SM SN in our local made Air cooled biks just use manufacture recommended oil like API SG and always use manufacture made genuine engine oil bcoz they have better Knowledge about there bikes then us now HONDA give engine warranty of 3 years if ur using AHL engine oil if im wrong plz tell me
    Did you actually destroy an engine using modern grade oil?
    Newer grades are supposedly bad (debatable) for old era engines but no hard evidence i think. Mostly just theories and stuff.
    Gull Bhai LIQUI MOLY 20w50 main ne new Piaggio me use bohat shouq se bcoz MADE IN GERMANY or apney doston ko use ker wa diya mager samajh nahi aayi ke top class engine oil hai mager bikes k engine aag ki terha hot ho gatay they sab doston ne yehi complain ki kya masala ho sakta aap k khayal main
    Well engine gets hot because combustion is going on in there.
    It will be hot with LM as well as with any other oil. I don't think it should get extra hot with LM.
    It should be little cooler with LM in fact as it is thickish oil.
    Motorcycle Engine Oils -1539551Now im using SGO in my NEW Gs 150 and AHL oil In my 2014 Cg and first time im tension free about engine oil
    SGO will do fine in winter but once weather gets hot, you'll feel the need to go little thicker like 20W-40.
    CG is whole other thing. It will go fine with any oil. No nakhra.
  3. #1682
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Zic M5 20w40 API SJ Jaso MA2
    Motorcycle Engine Oils -1540857
    Motorcycle Engine Oils -1540858
    Motorcycle Engine Oils -1540859
    I have been using zic 20w40 from quite good time but recently zic changed packing
    names & specification of their motorcycle engine oil range this is first time i am
    buying this oil with new packing i am impressed its performance is excellent as the
    old one was performing bike is smooth from first startup and i feel slight better gear
    shifts and overall engine feels relax and smooth very good quality zic oils
    in reasonable price
    Bought in 250 rupees i was expecting new packing with new price was expecting higher price
    but i got in 250 rupees i guess price reduction is may be due to patrol prices gone down
    just around two month ago bought it 270 rupees
  4. #1683
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Quote Originally Posted by amjad635 View Post
    in reasonable price
    It is a excellent engine oil
  5. #1684
    tahirahmad13's Avatar
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    I got it through online order and am using in both of my bikes!!
  6. #1685
    valvoline's Avatar
    Oct 2014
    88
    11 Post(s)
    Visit us at Expo Pakistan and get exclusive exhibition pricing, free gifts and a chance to win a lucky draw !
    Motorcycle Engine Oils -1541238
  7. #1686
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by valvoline View Post
    good i will be there in sha Allah.
    Help others so that u can be Helped
  8. #1687
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    I have found this one nearby my house. My RP is liking it very much, its semi synth 10w-40 SL/Jaso MA2 and has good run time (means it wont let you down so easily on a single ride)
    Price 500/- 1L bottle
    Motorcycle Engine Oils -1544136
  9. #1688
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    Motorcycle Engine Oils -1544137
  10. #1689
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    Motorcycle Engine Oils -1544138
  11. #1690
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    to all kindly go through this information prior buying and using any 4T oil.
    kind regards.
    JASO Engine Oil Standards Implementation Panel
  12. #1691
    muhammadayubkhalil's Avatar
    Feb 2013
    Rawalpindi
    139
    dear archon2001 ,
    , should i use it in pridor or not
  13. #1692
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by onefifty View Post
    seems impressive engine oil is it easily available or you found it by chance?
    and why its so expensive?
  14. #1693
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Little expensive may be because it is imported from Singapore.
    Total 20W-40 is Formulated in France, and Made in Pakistan.
    Cost under 400 rupee.
  15. #1694
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by muhammadayubkhalil View Post
    dear archon2001 ,
    go through this document and decide yr self, all oil presented here are good, but u need to now what u are getting for yr hard earn money.
    select Motorcycle Engine Oils - spacerMotorcycle Four Cycle Gasoline Engine Oil
    select Motorcycle Four Cycle Gasoline Engine Oil
    Motorcycle Engine Oils - spacer (JASO T 903:2011) Application Manual (NEW Manual)
    its in pdf and i am sure it will help all the riders.
    It?s important to note that only JASO MA & MA2 certified motor oils have the JASO box ( on the back of the bottle ) and individual certification number located on the top of the MA or MA2 logo.
    most of the motorcycle oils only state that they meet or exceed JASO MA or MA2 requirements ,
    not tested or certified JASO ( Japanese Automotive Standards Organization ) performance.
    as most of them have their own, in house testing facilities to make sure the oil meets the spec.
    WHY? they haven't kept up with getting their oils tested by JASO due to the cost of getting the oil tested once a year as it isn't mandatory and is very expensive .
    regards
  16. #1695
    awaiz43's Avatar
    Oct 2014
    Rawalpindi
    29
    238
    i purchased liqui moli for the first time for my cg125 from F-8 Markaz i think he is a authorized dealer but the pack i bought is bit different in stiker...i will upload image soon..us stiker pe 20-50w k neche Street likha hy the shop keeper said its new packing but the oil is same i had a little trip after oil change about 40KM..engine sound is good clutch and gears are soft but i feel a bit drop in top speed..
  17. #1696
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    Actually I found this by chance... I hope that shop must have more cottons - I liked this oil
    And yes I think it is imported because the performance it is giving is very good.
    No worries, if I dont find more units of this - I will switch to Zic...
    How is Zic M5 and M7 guys? please share the experience.
  18. #1697
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by gull_s_777 View Post
    just checked the links of 20w40 engine oil they are made in pakistan
    on this oil atleast i don't see anywhere pakistan written so i guess its imported
    engine by total pakistan
    price is high but its not very high people are paying for liqui moly 700-750 rupees
    if this oil performs good than its good choice in imported engine oils we already
    have one positive review so far from you but as this oil is not available everywhere
    thus not many people have seen it or may its just introduced on some shops
    I am using Zic M5 its excellent engine oil bike's engine is very smooth performing
    Quote Originally Posted by awaiz43 View Post
    Drop in top speed is indication oil is proving thick for engine thus loss of performance
    engine parts are not moving freely i recommend use 20w40 engine oil
  19. #1698
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    Somebody here had uploaded a pic of Zic M9. Is it available in the market?
  20. #1699
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    Motorcycle Engine Oils -1536141
    This one!!!
  21. #1700
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    Quote Originally Posted by tahirahmad13 View Post
    This one!!!
    So it means
    M5 is mineral
    M7 is semi synth
    M9 is fully synth
