Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
for engine oil but guys please bear this one too purpose of creating this thread is to share the range
of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
share engine oils & their pics which obviously will show the specification but i have access to only few oils
which i have used or which are available in my city
i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
bottle you should share here & share your review about that particular oil
Your sharing matters alot as i alone can't collect all info about engine oils available in market
As i just said in last line of first paragraph your co-operation is important in helping me out
to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
if we search on net this subject is too deep so want to know your info about these important terms in engine oils
this thread will be useless if it does not have any details info about specification terms
so kindly if you find some good info on net share here
*API
*JASO
*Viscosity
*SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
*Single Grade & Multi Grade
*Mineral & Synthetic/Semi synthetic
Etc notify if there are some other important terms
The Sole purpose of this thread is to collect info about engine oil available in market
*Specifications/price & *Picture
^Sharing some basic info which i know as par my bike
API in simple word an company which gives certificates of quality to engine oil
so always look for this API label oil but some manufactures recommends JASO
But most motorcycle manufactures in pakistan as the big one
AHl recommends to use engine Oil with API SG,SF,SE or higher grade
you should look your bike manual for the details about your bike
Viscosity of oil is shown in the SAE numbers
most oils nowadays available in market are multigrade
first number which is followed by W (winter) shows the oil viscosity at low temp:
lower this number thinner the oil be at lower temp:
2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
20w40 oil will remain less thick at 100c as compare to 20w50
my bike manual says 20w40 is good all rounder for pakistani conditions
but depending on the temp user can choose which oil suits engine more
Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
Shell
AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
AX5 15w40 1.0lt (Pic on post #234)
Caltex
Havoline 20w40 0.7lt
Havoline 20w50 1.0lt
Castrol
Go 20w40 0.7lt (Pics on #146)
Active 20w50 0.7lt & 1.0lt ( Pics on #155)
Gtx 20w50 1.0lt (Pics on #357)
Atlas Honda
Atlas Engine Oils (Pics on #948, #1054)
Yamaha Lube
Yamalube 20w50 (#1727)
Servo
M2 30/40 0.7lt & 1.0lt
M5 20w50 0.7lt & 1.0lt (Pics on #14)
Dyl Lube
Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
Suzuki SGO Oil
Suzuki Genuine Oil 10w40 (Pic on #106)
Zic Lubricants
Zic M5 20w40
Zic M7 10w40 (#1557)
PSO Oil
Pso Blaze 4t 20w50
Total Lube
Total HI-Perf 20w40 (#1233)
Total Hi-Perf 10w40
Master Lubricants
Master Xtra 4t-MCO 20w40
Imported Engine Oils
Kixx (Korean)
Kixx Ultra 20w50 1.0lt (Pics on #154)
Kixx Semi Synthetic 20w50 (#1406)
Liqui Moly (Germany)
Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,)
Racing Semi Synthetic 10w40 (#1244)
Repsol Moto 4t 20w50 (#1270)
Valvoline Champ 4t 20w50 (USA) (#1040)
