Page 99 of 101 FirstFirst ... 4989979899100101 LastLast
Results 1,961 to 1,980 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
  2. #1961
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Use any synthetic oil for your bike they are far far better then any mineral oil you will note huge improvement in performance
    Quote Originally Posted by tarqureshi View Post
    Poured Liqui Moly 10W40 and engine suddenly rocking with musicsound as compared with rough engine sound and feel with Shell AX5 10W40 that I used during running of my GS 150. Engine noise is not reduced too much but gives a lighter feel then before and donot get too hot. Acceleration improves a bit with no difference in gear shifting.
    AX5 was also 10W40 but felt too rough in engine.
    Although its start of summers but opted for 10W40 with small knowledge that i gathered form this thread and others on PW stating that with thicker oil,the engine shall got more hot plus GS 150 done only 1500 kms would not feel good with thicker oil.
    Got LM 10W40 for Rs. 800 from I-8 Markaz from LM shop in city arcade.
  3. #1962
    vkiiali's Avatar
    May 2016
    76
    2 Post(s)
    Dear All
    I used shell ax5(15w40) in my suzuki gs150 in my break in period. odo metre is now 1100 kms(break in period done). My bike still heats alot and vibrates at 5-6 rpm. Also having a a loud engine sound. First oil changed at 300 kms and 2nd oil at 750 kms(both oil used shell ax5)
    I want to move to zic M7 which is 10w40. Need your advise should I change the oil with zic m7 10w40 or stick with shell ax5 15w40? Engine new ha 1100 kms driven only. Is it harmful to move from 15w40(mineral) to 10w40(synthetic) at this stage??
  4. #1963
    a4anees's Avatar
    Jan 2016
    95
    Zic M5 is the best one i have used & its thickness lasts longer than 800km.
    I dont talk much because my bike's engine do it for me.
  5. #1964
    shadowless_33's Avatar
    Jan 2010
    Jauharabad
    57
    the Liqui Moly shop in Muslim Town Lahore is closed due to road construction. Have they shifted somewhere else temporarily?
  6. #1965
    elxlr's Avatar
    Oct 2015
    254
    3 Post(s)
    Quote Originally Posted by vkiiali View Post
    Dear All
    Use good 20w-50 till winter.
  7. #1966
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Quote Originally Posted by elxlr View Post
    GS150 Work's better with 10W40 and 20W40 oil's instead of 20W50 oil.
    I have personally experienced this thing.
    By using 20W50 the engine give a little bit heavy feeling. Like its not working to it's limit.
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
  8. #1967
    elxlr's Avatar
    Oct 2015
    254
    3 Post(s)
    Quote Originally Posted by hassantahir2 View Post
    If your mechanic is experienced in bike field like 20+ or minimum 15+ yrs experience and he is good n honest. Then i accept your point. That gs runs good with 10w40.
    But if mechanic is not good or change mechanics or anything.
    Then i disagree. I use 20-50 in my cd 70 and delux and euro. All are good. Start at first kick.
    70. I put any oil. Havoline or whatever
    Delux. I put havoline and last time i put castrol
    Euro 2 2014. I only put liqui moly for last two years.
    If i had hood mechanic. Bikes ran perfectly. If bad ones. It ran dull while starting up.
    I even used 10-40 liquimoly. Felt not too much viscous and engine used to heat a little higher or quicker than 20w-50.
    Well. Hope u r right. Good luck
    Even though service manual of honda 125 i think recommends 10w-40.
  9. #1968
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    From where the mechanic jumped in...!
    I told what i personally felt...
    That is my personal experience.
    And yeah Honda bikes won't mind thicker oil's even the recommended oil for AHL bike's is 20W40.
    But.
    Suzuki bike's are little bit reluctant to thicker oil's.
  10. #1969
    mansor's Avatar
    Jul 2010
    33
    561
    6 Post(s)
    Quote Originally Posted by valvoline View Post
    Hello again Navqam.
    We very much understand your concern. It has been estimated that 20% of all oil sold in Pakistan is fake or does not meet the specification written on the label. This is why we import all our products seal packed. You will be getting the same quality product as the user in the USA, Europe, Asia or Australia.
    Don't worry. Before listing our products on Online Shopping in Pakistan with Free Home Delivery - Jambo we have done our proper due diligence to ensure that our customers will receive the premium quality Valvoline product that they are expecting.
    Thanks !
    Team Valvoline
    Valvoline Pakistan Official- valvoline.pk
    www.facebook.com/valvoline.pakistan
    Dear Valvoline,
    Jambo didn't allow single bottle order, Kindly share your dealer detail in Lahore region
  11. #1970
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    But.
    +1 to that.
  12. #1971
    vkiiali's Avatar
    May 2016
    76
    2 Post(s)
    I bought these oils from ZIC online website. Previously i ordered 1 bottle zic m5 and 1 bottle m7. Both had no seal on cap. Today i recved my order again with 1 bottle of m5,1 of m7 and 1 bottle of X5 20w50. But strange tat some bottles have sealed on its cap and some bottles dont have seal of sK. i dont know if these are original products or not. Confused :s
    Sharing pictures. Pls check if somone knows.
    This one bottle without seal i had in stock and today recieved with a sealed one
    But here another(10w40) also recived without sealed
  13. #1972
    Newbie Follow
    j_allana's Avatar
    Sep 2016
    Default 0.7 Diamond brand motor bike oil
    Pl let me know if any body interested to try our local brand 0.7 oil called "Diamond" blended with imported base oil. Best for motor bikes n generators. For bulk order pl contact Me at 03167774261 sms/whatsApp.
  14. #1973
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    legend will revive soon
  15. #1974
    vkiiali's Avatar
    May 2016
    76
    2 Post(s)
    Here you go. Shell advance ultra(10w40 - 100% synthatic)
  16. #1975
    shoaib992's Avatar
    Apr 2013
    24
    71
    2 Post(s)
    Which oil is best for new gs 150 with 500km on odo meter?
    Success Is A Mindset.
  17. #1976
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Don't worry its common some have seals and some don't
    you have ordered online direct from company so don't worry
    just check seal on cap plastic locks and seal under cap is ok
    if its tear than don't accept that oil
    THanks for sharing Synthetic engine oil from shell
    its good addition of new product from reputed company
    Quote Originally Posted by hidalgo View Post
    Hidalgo brother thanks for sharing
    You shared good & important info in video regarding engine oils
    Quote Originally Posted by shoaib992 View Post
    Shoaib try Zic m5 20w40 works very good
  18. #1977
    mobeen_iftikhar69's Avatar
    Aug 2016
    5
    Best oil for honda 125 2500kms driven? which is easily available aswell? reply will be appreciated
  19. #1978
    omer.s's Avatar
    Sep 2010
    30
    590
    13 Post(s)
    Quote Originally Posted by mobeen_iftikhar69 View Post
    kixx 20w50 4T semi-synthetic is best value of money
    Sent from my HUAWEI G700-U10 using PW Forums mobile app
  20. #1979
    shoaib992's Avatar
    Apr 2013
    24
    71
    2 Post(s)
    @amjad635 bro is se warranty to void nai hogi as sone one say use suzuki oil during warranty period and 10w40 is recommended in the user manual of gs
  21. #1980
    crase24's Avatar
    Aug 2013
    212
    3 Post(s)
    Its all personal preference
    I am using Honda genuine oil in honda 125 2014 , its 16000km driven ,never had any issue
    Cost is 380/L
    Sent from my iPhone using Tapatalk
