Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By asjdsm
Thread: salam guys.... need advices...
    Predator1983's Avatar
    Mar 2012
    52
    Default salam guys.... need advices...
    salam to all...i have purchased a super power 125 deluxe bike model 2012. Bike has electric start setup and 5 gears speed. i bought it in slight used form, although bike condition is mint. What i noticed is the vibration while driving. the plastic cover on head lite and the tail lite both are too noisy.
    What should i do to overcome that vibration ? also can i replace the head light hud with any other custom head light for better beam ? also provide guidance where i can get the head light replaced or installed ?
    awaiting for ur responses...
    asjdsm's Avatar
    Apr 2009
    30
    3,465
    57 Post(s)
    3 Thread(s)
    properly tighten nuts and bolts.
    and use metal/rubber washers where you think will be needed..
    these bikes dont use these things where they should..and consequently it causes vibratios/noises
    Farhansa's Avatar
    Oct 2006
    8,713
    5
    84 Post(s)
    this is a common problem.
    re-tight bolts with new washers
