Results 1 to 5 of 5
Thread: I want this thing......
    hisbanirm's Avatar
    May 2012
    Nawab shah
    Default I want this thing......
    Hello PW fellows I have honda 70 model 1982. Bike is okay in all aspects except one that its speed meter is not working.... i also have repaired it 2 times but it works for 1 week and after that it stops again... so i want you guys to help me to buy me a used speed meter for my bike... I prefer to buy it from Hyderabad or Karachi... plz help me guys
    hisbanirm's Avatar
    May 2012
    Nawab shah
    Come on guys anyone can find this thing should let me know....
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,249
    7
    295 Post(s)
    11 Thread(s)
    9
    pay a visit in karachi... go to Rann-Chor Line Area you will easily find one, better take this meter with you any road-side repair wala with fix it for you.
    I am only responsible for what I say, not for what you understand..
    asad01's Avatar
    Sep 2008
    Abbotabad
    53
    326
    6 Post(s)
    We had the same problem with S110 Benly 1980(Japanese), one-unit headlight and speedometer. Had it changed with separate headlight and speedometer. It was much cheaper than the original one-unit(new) and about the same cost as a used one-unit piece. That was over 20 years ago, I doubt you will get a working piece now.
    If you must keep the original housing, take it to Karachi and have an expert replace the speedometer mechanism, it might need internal modification to mount the new mechanism. Ask Karachi members for expert speedometer technicians.
    If keeping the original is not a must then go for separate units or for temporary use. You should be able to get it done in Nawab Shah as well. You will require extra bracket for the speedometer.
    Asad
    hisbanirm's Avatar
    May 2012
    Nawab shah
    Quote Originally Posted by asad01 View Post
    I want to keep my bike's original look so no separation of speedo and headlight....
    I will spare some time to go Karachi for buying a speedo....
