Results 1 to 17 of 17
Like Tree11Likes
  • 1 Post By gull_s_777
  • 1 Post By isb_rider
  • 2 Post By gull_s_777
  • 2 Post By SyedMoazzam
  • 4 Post By Automotorsport_Lover
Thread: Cd 100 Best Battery & Horn
    isb_rider's Avatar
    Jun 2013
    25
    82
    Default Cd 100 Best Battery & Horn
    My cd 100 battery is lmost dead i wanna replace that which is best one in the market
    Secondly what air pressure should be used in tyres with weight on bike around 100kg +
    Thirdly suggest me horn for bike one electrition go to pindi and get KABLI horn set
    mfdarvesh's Avatar
    Jul 2007
    2,806
    30 Post(s)
    Better stick with stock one. The stock battery and Horn from AHL works good. Usually 45 pressure in rear tyre is sufficient ..
    isb_rider's Avatar
    Jun 2013
    25
    82
    thanks for your suggestion darvesh, looking for better then stock like dry battery if something is really better
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    stick to the air pressure mentioned on chain cover of the bike.
    Values are given for solo rider, and with pillion rider as well. Since you have 100kg+ on bike, follow the values given for "Double Sawari"
    isb_rider's Avatar
    Jun 2013
    25
    82
    thats my own weight solo 109 kg
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by isb_rider View Post
    well still you should follow pillion rider values
    I weigh 75Kg and still i follow pillion rider values just to have light feeling bike. But i don't exceed the values mentioned on tyre.
    isb_rider's Avatar
    Jun 2013
    25
    82
    yes thanks for input
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Quote Originally Posted by mfdarvesh View Post
    O bhai manual may jo tyre pressure recommended ho wo use karo and it is mainly 33 psi for the rear and 25 psi for the front tyre
    The manufacturer is not crazy they write what is best for the bike always follow manual 40 psi is too much bhai
    mqsdrana's Avatar
    Mar 2010
    557
    118 Post(s)
    9 Thread(s)
    dry battery of 15amp & denso horn (mostly factory installed in corolla)
    Me also using since 2009 in my honda deluxe
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by SyedMoazzam View Post
    I think for a 2.75 tyre, 40 PSI is recommended for doubling.
    Bigger tyres require less PSI, as 90/90 i am using recommends 35 PSI max.
    Also have a 100/90 tyre which requires 32 PSI max.
    So it varies with tyre size.
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    please install dry battery 15 - 18 Amp (maintenance free)... and get Japanese twin horn (used) as comes in Toyota..
  12. #12
    isb_rider's Avatar
    Jun 2013
    25
    82
    Quote Originally Posted by gull_s_777 View Post
    i got 3.00/18 so what is exact pressure for that
  13. #13
    isb_rider's Avatar
    Jun 2013
    25
    82
    Quote Originally Posted by mtmoghul View Post
    will 15-18 Amp will replace stock one without any modification ? like bigger space etc secondly give me rough idea of price of battery and horns , thanks
  14. #14
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Iv no idea why the hell people are suggesting so big batteries?? Kia apne truck start karna ha ispe? Ya ghar ka ups bhi chalana ha?
    Bro get an AGS battery.. Get its first charging done at slow amperes as mentioned on its leaflet...
    AGS 3amp battery is good enough, get a car's old horn kabli, ask electrician to fit a relay and u would get a loud car horn even with weak battery due to relay installed.
    500-600rs men kam mukao, 15-15,18-18 amp ki battery lagana is funny... I don't think it would even fit! Even if u want bigger battery then find a 7-8 amp battery dry/wet it's more than enough... Ur bikes charging system is not designed to charge a big battery... Wo bhi discharge hojae gi ultimately?
    And if ur wiring isn't short from any where or grounded thru touching the frame/body... Then choti battery bhi fully charged raegi...
    Battery drain Tabi hoti a bar bar jab wiring short ho ya earth milra ho usy aur current waste hora ho!
    Sent from my ST25i using Tapatalk 2
  15. #15
    isb_rider's Avatar
    Jun 2013
    25
    82
    ^thanks bro for your suggestion
  16. #16
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    As you aren't using stock tyre, so follow whatever max is mentioned on the tyre.
  17. #17
    isb_rider's Avatar
    Jun 2013
    25
    82
    Thanks every one for input , I got Kabli Horn set from Sultan ka kho in 500, Cutout in 100 , Result is satisfactory
    Also also replaced my old battery with Dry 5 Amp Battery in 800 from College road
