Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Like Tree11Likes
Thread: sort of failed experiment (HID in sprinter)
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Default sort of failed experiment (HID in sprinter)
    As the topic shows, i tried to install an HID in my sprinter cuz i was just fed with the poor light output of stock lights. Got the ballast and bulb. And then i made the mistake of going to a local bike electrician who although does good jobs on Honda bikes, i think messed up the wiring of my bike.
    I got a dry 5.5AMP battery for the increased load. But so far i have been disappointed with the result as soon as the HID is on the other things stop working properly. Horn's sound is decreased. Indicator to bilkul i think urh gaye hain because of the JUGAARs that mechanic did with the wiring.
    What do you guys propose? Wapis stock everything? or should i give the battery some more time to charge fully and then test the HID. Btw, HID lasted 5 minutes on the stock 2.5AMP battery.
    Looking forward to your responses
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    let the battery charge for a while and then check the results. give it a long run in day time so battery will charge and then check the result. my gs also gives trouble with I guess 9 amp battery if the battery does not charge and If I ride mostly at nights. and even if you will be back to stock, the wiring is already ruined so better to enjoy what you have spent on. I have been using hid for more than 2 years now on bike but its not a good idea to use hid on bike if the daily running is less. my bike stays at home on weekends so I face this issue after that if the battery is not charged up.
    people need to grow up sometimes and act MATURE !
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by jadoon1992_vxlimited View Post
    daily running is 20KM. night you can say hardly 2KM everyday on average. a PW member has suggested getting a bigger charger for the battery as he had to do the same on his honda deluxe. 110CC ka to aur chota charger hoga
    afnanSJfayaz's Avatar
    Nov 2010
    Newcastle upon Tyne
    1,164
    13 Post(s)
    A quick question. if you need to install hids in a car do you have to completely detach the headlight and take it out of the body?
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by afnanSJfayaz View Post
    Bro this is bike's section. But if you're talking about replacing the stock halogen then yes you'll have to take it out
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by ammarzahid View Post
    yes a friend of mine did the same with his sp100 and the charging was perfect then. try it and result will be good. but don't install a very heavy charger. daily running of 20 km is more than enough. then the issue might be the charger
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    thanks a lot for your input, has got some disappointment off my mind. will share results after tomorrow's running. will also try to get the bigger charger installed tomorrow. btw can you share which watt HID tube/bulb you're using?
    waqas18's Avatar
    May 2006
    28
    1,501
    23 Post(s)
    3 Thread(s)
    where can I find good HIDs in reasonable price for my GD...?
    People with high ego and unnecessary attitude deserves the standing ovation of the tallest finger..
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Limited back up time is one of the reasons i never gave HID a serious thought
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by waqas18 View Post
    Bro get car hid with a 35W bulb don't get hids from motorcycle shops they're cheap but they have low quality ballasts. A good quality kit ranges from 2500 to 3000. Bike shops say you can get 1800PKR main normal quality HID kit. After that you'll have to get a bigger battery if one's not already installed in your GD. Then you'll have to get a relay and then finally find a good mechanic who won't ruin the original wiring (jo k karni paray gi ultimately). You might be put off by this but im sharing these things from experience so you might not have to face the same problems that i did.
    Quote Originally Posted by gull_s_777 View Post
    R1 said he got 4 hours of continuous run time from HID on a 7AMP battery, so i was convinced mine would work for atleast an hour
    fazalwahab11375's Avatar
    Jan 2012
    Select City
    29,483
    36
    842 Post(s)
    23 Thread(s)
    Pakwheels on the MAP; http://bit.ly/ZVyXcZ
  12. #12
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    I had also the same issue of bad light. I didn't go for HID but for a much simple solution and without any single alteration.
    Just buy (1). Honda 70 head light (round shape) with (2).cowling (the metal cowling). Asked for XANDAU brand. It is the only good brand i know and it has been proved to be quality one. You will get the complete package, glass + cowling.
    Lastly take a halogen bulb. The one with dark blue glass but brake the blue outer glass carefully, underneath there is the actual bulb.
    The total cost will not be more than 400 - 500Rs
    You can see the simple DIY below here -> https://www.pakwheels.com/forums/bik...on#post3785500
    I have got the extra ordinary result. I will try to post you the result may be tomorrow. With high beam you can see ahead atleast half a km believe me.
  13. #13
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by abdulrehmanrauf View Post
    Lastly take a halogen bulb. The one with dark blue glass but broke the blue outer glass carefully, underneath there is the actual bulb.
    Tried this a while back but the result was not satisfactory. Important tip: halogen bulbs consume more power than an equivalent HID/Xenon bulb. Source: Battle of the Headlights: Halogen vs. Xenon vs. LED
    Im using the HID bulb in an old fashioned housing, not a halogen reflector housing the glare is not more than the normal incandescent bulb :-) As a precaution i tilted the headlight assembly towards the ground a bit.
  14. #14
    Oct 2009
    33
    771
    31 Post(s)
    1. Did you use XANDAU glass?
    2. The cowling you used, the holder place is flat or it is little exposed I mean thori ubbri hoi hai ye plain hai? Can you upload the pic of cowling. Kion sara issue glass ka ya phir cowling ka hota hai mainly.
    And about halogen, I have been using halogen buld for last 7 years and never faced issues people reported against an HID.
  15. #15
    venom's Avatar
    May 2005
    26
    548
    13 Post(s)
    I used HID in my deluxe for around an year and it worked flawlessly ...... Now I've installed it in my Piaggio ! The thing is u need to do proper wiring and stuff ! Had a detailed chat with the OP and my personal opinion is that he needs to get bigger charger for the battery.
    Keep ur Friends close ... And Enemies more Closer !!
    Honda CD-100 ==> Honda CG 125 Deluxe ==> Ravi Piaggio Storm 125 !
  16. #16
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by venom View Post
    @venom has been a great help in this regard. I thank him again. And as per his suggestion i'm going to get a bigger charger for the battery, hopefully that will be the end of the HID's issues.
  17. #17
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Can HID be installed in Yamaha Junoon? Would I have to replace the headlight? Is a glass made headlight of Junoon also available?
    Sent from my ST25i using Tapatalk 2
  18. #18
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by Automotorsport_Lover View Post
    Yar 70 main lag jati hai to Junoon main kiun nai lagay gi. But it's a really expensive procedure, here's what you'll need:
    Dry battery 5+AMPS (Rs 850)
    Relay (Rs 100)
    HID Kit (Rs 1800 - 3000)
    Bigger battery charger (Rs 500)
    Mazdoori to get it all fitted and your wiring ruined (Rs 250)
    Misc stuff including wires, connectors etc (Rs 200)
  19. #19
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    duplicate
  20. #20
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Everything solved alhumdulillah.. Wires from my indicators were exposed and were being shorted thru touching the metal headlight.. The problem was diagnosed by the mechanic successfully. Everything working as it should. Let's see how much load the battery will sustain before giving up. The mechanic still advised against a bigger charger, he said agar 2 3 din main problem hui he would fit a bigger charger.
    BTW i fitted a car's HID kit in my bike, do they consume more power? the mechanic suggested i get an HID kit designed for bikes cuz it uses less power. Experts on this matter give me your opinions on that
