Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 241 to 260 of 263
Like Tree175Likes
Thread: Bikers Lounge (Discussion and Troubleshooting)
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Default Bikers Lounge (Discussion and Troubleshooting)
    Asslam-o-Alaikum:
    Iam starting this thread so that any member can discuss anything related to any bike. We have threads relating to particular bike pertaining particular problems.
    Lets move one step a head and just put all those years experience to help each other. You can discuss anything related to bike.
  2. #241
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Guys, anyone have any idea about prices of Challa Kit for CG125. Are Japenese ones also available in the market ?
    Any way to differentiate between AHL Genuine and Japanese (if it exists)?
    Riders on the storm ... literally.
  3. #242
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Brethren! Kindly check the following spark plug and tell me if there is anything wrong (to me there definitely is).
    Bikers Lounge Discussion and Troubleshooting -1337933Bikers Lounge Discussion and Troubleshooting -1337935
    Do check the engine oil on the outer rings.
  4. #243
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by abobobilly View Post
    Put that on finger and rub it with thumb to feel viscosty of oil, then smell it if it smells like burnt mobil oil if you feel the viscusness and burnt oil smell then I am afraid you need to get it checked sooner or later.... but if it is not viscus at all and smells like addative petrol or kerosene then that means you used a bad petrol pump to refill your tank and now bike is unable to fire it up properly or it is running rich or you have bad ignition.
    Hope it helps! (Y)
  5. #244
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    @vickytulla ! Thanks for replying.
    If you remember, a couple of weeks ago i posted that:
    1. I had to re-do the Engine Valves, Seals & Piston Rings.
    2. After that, bike occasionally, would give smoke on cold starts (doesn't happen very often though, and there is no smoke once the bike gets heated)
    I have been concerned since that day ... that there could be a leakage or the mechanic who did the work have somehow messed up (even when he was very careful). I was told to get my Piston Changed too while the work is being done (to ensure longer life of the rings), but i didn't pay any attention to it because:
    - cost attached to it which would've costed me nearly 10k
    - Piston was fine and the person who did the work did acknowledge that it is.
    I have read about the Plug Conditions and apparently, Plug is Fine and is doing its job properly. However, i am still concerned if there is a leak somewhere. My cousin suspects is to be Valve Guides; a random mechanic suggests bad seals. Either way, i don't feel like getting it opened again. Neither do i like spending any huge cost on it.
    Advice?
  6. #245
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    hmmmm..... if that is the case then I would inspect and try find out if the deposits I found on Plug is really mobil oil, and if it is then I doubt the Valve seals mostly we buy it just of the shelf (which are very poor quality) and end up with every thing fine but wet plugs..
    Yes you dont need to open Head but if the symptoms continue to worse then you will sure have to get the head (atleast) thoroughly checked.
    Advice?
  7. #246
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Quote Originally Posted by vickytulla View Post
    Well it is engine oil. I know it because of the smoke which comes during cold start. Its the same smoke which appears when Piston Rings need changing, plus the burning smell. (which is because of engine oil getting sucked up in piston area -- but that is when the bike is heated up, not when cold)
    So i think you are right. So far, 2 votes for Engine Seals. I think i should get it checked and get the engine seals changed while at it. Do you have anything to add?
  8. #247
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    I wanna ask one question regarding honda cg 125 ....... k honda main kon sa lubrication system use hova ha splash or oil pump .
    Catch Me If u can...
  9. #248
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    If you are going to get the seals checked then lagay Hath Valves bhi check ho jien *** ... they have a liquid (machinists which make valves/guides ) they put it in the valve to detect any leakage also Cylender or Piston bhi check kerny ka moka mil jaye ga k unki health kesi hai!
  10. #249
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    You do know that this would be the 2nd time in less than 1000 kms, after my last work done right? Ab phir se sub kuch check karwana paray ga
  11. #250
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    yes this is very important becuase last time some thing went wrong which is making you lean to get it checked it less then 1k useage, this time fool proof checking is required to avoid re-Opening again .... specially like this..
  12. #251
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Ah, good point. I'll certainly update you once i get it done
  13. #252
    Site Banned Follow
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Costs 350rs.. Genuine can be sourced from AHL Service shop
  14. #253
    jkhan052's Avatar
    Jan 2014
    Question
    AoA to all memebers
    I need a suggestion on installing a security system for motorcycle. There are several options available in market like remote control, RFID and touch sensor etc. Which would be recommended.
  15. #254
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    @Silver_Knife! That doesn't look like the Challa Kit The ones i got are orange colored rubber Rings ... which were replaced in the areas behind Flywheel (left engine side).
    I didn't go to Makhdoom and i was short on time, so i visited my local mechanic who had them, and assured me these are Genuine - Changed them for Rs.550 inclusive of Labor. Is that a good price?
    I wanted the confirmation of you guys if they were really Geniune. I can also post a picture of those orange colored rubber rings if you want. Also, they were in Simple Packing (He claimed them to be Japanese)
  16. #255
    sherry56's Avatar
    Apr 2008
    Rawalpindi
    205
    6 Post(s)
    Aoa frnds I need a geniune mufler for cg 125 chrome one.i already purchased one from muhamdi autos rwp (cost:2500rs) and my machenic agreed dat it was of good quality but still it went out jst in a month. So help frm any member will be appreciated.
    Sent from my GT-I9100P using PW Forums mobile app
  17. #256
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Quote Originally Posted by sherry56 View Post
    If i were you, i would stop wasting money on these things. I have purchased FOUR exhausts over FOUR years of my bike and trust me, they just get screwed after some time. So no need to waste more money on them.
    As long as they are serving their purpose, they are fine
  18. #257
    Site Banned Follow
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Well bro i have no idea about them, but original rubbers come packed in japan sealing like this
  19. #258
    sherry56's Avatar
    Apr 2008
    Rawalpindi
    205
    6 Post(s)
    Bro I have cg 125 euro 2 n I dnt like black exhaust dats da the only reason to buy a new chrome one
  20. #259
    sherry56's Avatar
    Apr 2008
    Rawalpindi
    205
    6 Post(s)
    Aoa
    Did Any of u guy found the solution to reduce vibrations in cg 125 euro 2? My cg vib like hell and my mechenic tried alot to solve this issue but failed. Any mechenic recomended by u guys who can solve this issue in Rwp.
  21. #260
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    it is birth defect
    dont worry
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
