Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By getscorpion
Thread: Bike Carburetor Setting
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Default Bike Carburetor Setting
    Discussion is about missing problem at high rpm and i want to fix it myself.
    Today i tested a local bike "Ghani". It was missing at high rpm and idling was also very poor.
    First i tuned it to rich mixture and it started missing even at low rpms. Then i leaned the mixture and idling became smooth.
    As soon as i gave it full throttle, bike stalled at 60kmph and turned off. I started it by using "choke" and came back home.
    My assumption:-
    1) Air jet is not working. Because at lean mixture i tried to set idle speed but rpm didnt went up/down.
    2) Float position is low and bike starves at full throttle.
    Advance apologies if i wrote something silly/wrong because i am not an expert
    The best car safety device is a rear-view mirror with a cop in it.
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    clean and reset the carb settings all will be good.
    carb needs a thorough cleansing.
    Quote Originally Posted by waqar19 View Post
    My assumption:-
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Quote Originally Posted by asjdsm View Post
    Already cleaned it. Sprayed carb. cleaner through every hole.
    But one thing i didn't mentioned. At correct mixture when i give it full throttle it starts missing and after few seconds bike turns off and little amount of petrol comes out from float bowl drain. means "bike over ho rahi hai"
    So point is that at full throttle the fuel level in float bowl should drop and uncover the emulsion tubes. So that more air comes into the system.
    ^^How can i fix this??
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    coolmisa's Avatar
    Jan 2013
    27
    27
    my bike also facing that problem. mechanic didnt get it. he also change a coil.now i will clean carb and then see.
    getscorpion's Avatar
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    hv u checked the choke function, is it working perfectly? some times it just get stuck ..
    Sent from Mars using Telegraph
    Rise from the ashes,.....
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    @asjdsm, bro plz reply to my pm.
    I Am the Feel
    I Am The Yamaha!
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    these two below could be the possible issues with carburetor
    Either your bike carb float lever is not correct and is disturbed
    and this really causes the issue of overflowing
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Quote Originally Posted by getscorpion View Post
    Choke is working perfect bro
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Quote Originally Posted by amjad635 View Post
    how can i adjust the float level
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Brother settings may vary carb by carb In my pridor carburetor there is no adjustment mechanism for adjusting float height below i am sharing link of video from here you can have an very good idea how to adjust it but becareful as you can damage carburetor while adjusting it require soft hands in for adjustment https://www.youtube.com/watch?v=xBCzVg4kUN0
  12. #12
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    I have always wanted to learn to set carburetter but felt reluctant to do so. Is there any video or something which can teach me that?
    Bike is CG125 2009 model.
    Riders on the storm ... literally.
  13. #13
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    ok. i did everything i could.
    now only two things are remaining to be checked.
    1- float needle working
    2- throttle needle position
    I will do it on saturday
  14. #14
    fazal_11's Avatar
    Nov 2013
    Rawalpindi
    31
    need to lower the float level in float bowl
  15. #15
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    check the jet and cable because I found they often cause variable idle speed.
  16. #16
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    @asjdsm @amjad635
    Today morning i opened the carb.
    Throttle cable was working fine with little play in throttle.
    Then i checked the float needle. It was in rough condition and its tip had rubber coating which was removed.
    Bought another needle valve for 200 rupees. its costly man
    Now its working fine.
  17. #17
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Bike Carburetor Setting -1297800
